Question about Panasonic DP-C213 Color Copier
Hi could you help me the technician access code panasonic copier cp 213 (simulation) access glad I do not know if you can help
  • habib_kyocer May 31, 2010
    I want the code do not get questions answered manitenancetime
    Brigadier General:
  • 3,917 Answers
Have you checked the manual that came along with this. If you donot have it download one from the link provided bellow:
http://www.retrevo.com/support/Panasonic-DP-C213-Copiers-manual/id/2914ag315/t/2/
If this is not mentioned then its only the Panasonic technicians who can guide you. Please call any of the numbers mentioned here:
http://www.yext.com/copierrepair/ca/los-angeles/
Let us know if you have something more to know else please accept the suggestion.
Thank You.
Posted on May 31, 2010
    hello,
    maintenance password please
I what to know how to input simulation program to clear maintanance code CA on Mx2610 sharp copier
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
Main code 14 Start key Sub code 0 Start key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Feb 10, 2016 | Sharp Office Equipment & Supplies
I just replaced all the moving parts in my Sharp AR-M620 copier including the finisher and drum etc...I have the service codes and sub codes to reset the print counters, drums, developers etc but don't...
* Entering the simulation mode
1) Copy mode key ON ? Program key ON ? Asterisk (*) key ON ?
CLEAR key ON ? Asterisk (*) key ON ? Ready for input of a main
code of simulation
2) Entering a main code with the 10-key ? START key ON
3) Entering a sub code with the 10-key ? START key ON
4) Select an item with the scroll key and the item key.
5) The machine enters the mode corresponding to the selected item.
Press START key or EXECUTE key to start the simulation opera-
tion.
To cancel the current simulation mode or to change the main code
and the sub code, press the user setup key.
* Canceling the simulation mode to return to the normal mode
1) Press CA key.
Sep 06, 2010 | Sharp AR-M620N Copier
HOW CAN I REMOVE Key Maintenance MARK BY USING THE PROGRAM and How quantaty of devolper which requier
What is the "key maint mark"????
Do you mean its asking for a user code or is it asking for maintenance.??
The Developer comes in a bottle...all of the developer is replaced and then you need to access the Simulation modes to be able to run the developer set-up or the machine will not know you have replaced the developer.
Jun 23, 2010 | Panasonic FP-7735 Black and White Copier
DP 2500 displaying E04-01
You have a failure in the Fusing Unit:
E4- 01 Fuser warm-up temperature
1. Fuser Thermistor is dirty.
2. Thermistor position is incorrect.
3. Fuser temperature is low.
4. Thermistor is defective.
5. Fuser Lamp connector is disconnected.
6. Fuser Thermostat is defective.
7. Fuser Lamp is defective.
8. HTC PCB connector (CN716) is disconnected
You can try resetting the error by using this key sequence:
enter simulation mode by pressing keys ''Function + Original Size + 3 ''
go to f9 mode ,06 (ram initialize ) sub code 04 to reset fuser error.
If the code comes back you will need a service technician to diagnose which part is bad.
Oct 20, 2009 | Panasonic Office Equipment & Supplies
Cp error code in toshiba
the error code CP indicates that the Main Motor is locked,
**** do not try any of this while the power is plugged in****
****Do Not touch the surface of the drum and do not leave it exposed to light****
Try:
  • opening up the copier and look to see if the fuser unit (under the red cover) is not melted together.
  • if you know how remove the drum and developer unit. (please ask if you need instructions on this) check that everything in there turns freely.
Please let me know if this helps or if you need further help / any parts for this model.
Dec 16, 2008 | Toshiba 1370 Black and White Copier
Gestetner-2412Z copier-error code UF
UF is a panasonic code,the u means user fix.If you have an users guide it will tell u what to do.
Mar 03, 2008 | Gestetner DSm515pfd Digital Copier -...
Panasonic 7735
Hi Yes can help but need to know the code. If you open and close front cover machine should reset.If not need the code
Jul 15, 2007 | Panasonic FP-7735 Black and White Copier
Help me urgently on DP6030 panasonic photocopier
I have a problem with a DP6030. code says J87. checked but can't find any paper misfeed.
May 15, 2007 | Panasonic Workio DP-150PA Copier
Panasonic DP-C213 Color Copier Logo
75 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
