Question about DXG Technology DXG-572V Digital Camera
The camcoreder keeps saying card lock when ever i try to press the record button and the memory card is in right and it comes out and evrything
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • DXG Technology Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Posted on May 29, 2010
It keeps saying card protected everytime I try to record. I downloaded my videos on my computer and tried to earase the card and it keeps saying card protected.
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 04, 2011 | Aiptek IS-DV2 Camcorder
I am trying to record and when I press the shutter button a nessege comes up on display window that says card is locked.
Take the memory card out of teh camcorder and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 06, 2010 | DXG Technology DXG 3.3MP Digital Camcorder...
The Olympus DS-330 read only memory lock
You may need to format the recorder to clean the file system on the recorder. Follow the directions below to format: If you format the recorder, all function settings will return to their defaults*. All files** stored in the recorder will be deleted. If you have important files that you want to save, connect the recorder to a computer and transfer those files from the recorder to the computer before formatting the device. * Date and time settings won't be cleared, so you won't need to set them again. ** Locked files will also be deleted. 1 Press and hold the FOLDER/MENU button for 1 second or longer. The menu opens. 2 Press the up or down arrows button to choose "FORMAT". 3 Press the REC/SET button again. 4 Press the FF or REW to choose "START". 5 Press the REC/SET button. Formatting starts. "FORMAT DONE" displays when formatting ends.
Jun 11, 2009 | Olympus DS-330 Digital Voice Recorder
I have a used GR-D270U JVC camcorder, can't record w/it?
You can get a free membership on this site and download a manual, where, on page 18 of the pdf
document you will discover that the recording button is at the rear of the camera, at the top right hand
corner of the battery and at the lower right hand corner of the viewfinder, you can get tapes anywhere, even drugstores, and simply select memory card recording to record to your chip.
Apr 10, 2009 | JVC GR-D270 Mini DV Digital Camcorder
Lost Instructions for Little Tikes My Real Digital Video Camera
I also recieved a prompt reply, with attachment - here's paste of the text only:
INTRODUCTION
CONTENTS
Item no.: 608728
Ages 3+
ADULT BATTERY INSTALLATION REQUIRED
Get ready to make your own movies with the Little Tikes™ My Real Digital Video Camera! This
durable and fun camera is easy to use and really records video and takes pictures, even up to a
depth of three feet under water!
Illustrations may vary from actual contents.
IMPORTANT: An adult must remove and discard the plastic label from the LCD Display before use.
• Little Tikes™ My Real Digital Video Camera
a. Microphone
b. LED Light
c. Lens
d. Power Button/Mode Selector
e. Mode Display
f. Edit Button/Edit Mode
g. Trash Button/Delete Mode
h. Volume Selector
i. Zoom Button
j. Record/Confirm Button
k. Speaker
l. Left Button
m. Right Button
n. LCD Display
o. USB Port
p. TV Out Port
q. SD Card Slot
r. TV Out Cable
s. USB Cable
t. Adjustable Neck Strap
u. Carrying Case
WARNING
Constant, competent adult supervision
is required at ALL TIMES when small
children are near or in water.
m
g
t k
a b
c
j
d f i
hl
e
p q o
(inside the cover)
n
s
r
u
BEFORE YOU BEGIN
Battery Installation
An adult must install batteries. Here’s how:
1. Using a Phillips screwdriver (not included) remove the screws and Watertight Cover from the
bottom of the camera.
2. Remove the screw and Battery Compartment Cover .
3. Install two (2) AA alkaline batteries (not included) making sure the (+) and (-) ends face the
proper direction as indicated inside the battery compartment.
4. Replace the Battery Compartment Cover and tighten the screw.
5. Replace the Watertight Cover and tighten the screws firmly to ensure a good seal.
Optional SD Card
Your Camera will hold approximately 10 minutes of video or 250-1000 still photos. Since portions
of the free memory space indicated in the Menu Mode are used to store the photo program, the
available space for storing photos etc., may be reduced. These numbers may also vary depending
upon the camera mode settings and the images being captured. To enlarge the memory, an
SD card (not included) may be purchased from your local camera store. To install the card an
adult must:
1. Make certain the camera is turned OFF.
2. Using a Phillips screwdriver (not included) remove the screws and Watertight Cover from the
bottom of the Camera.
3. Slide the SD card (not included) into the slot until it clicks. (DO NOT force the SD card. If you
feel resistance, remove the card, make sure it is facing the correct direction, and try installing
again).
NOTE: SD card label must face toward the Camera Viewfinder and the edge of the card with the
copper contacts must be inserted first.
4. Replace the Watertight Cover and tighten the screws firmly to ensure a good seal to keep
water from entering the card slot.
IMPORTANT NOTES:
• If the Watertight Cover is not completely sealed, water may enter the compartment causing
irreparable damage to the camera.
• USE CAMERA IN FRESH WATER ONLY. DO NOT USE IN SALT WATER.
• Using the Camera at a depth of more than 3 feet is not recommended.
TIP: Keep an eye on your battery level by checking the Battery Gauge in the top-right corner of
your screen. If the Gauge is red, new alkaline batteries need to be installed.
1.5V AA/LR06
1.5V AA/LR06
unscrew
TV Out Port
USB Port
SD Card Slot
unscrew
unscrew
1.5V AA/LR06
1.5V AA/LR06
Battery
Compartment
Cover
Watertight
Cover
IMPORTANT: To save your photos and videos directly to an SD card, you must go to the Storage
Section of the Menu Mode (see Page 5) and change the setting from internal memory to external
memory.
NOTE: Never insert anything other than an SD card into the card slot as doing so may damage the
camera and the SD card. To remove the card, press in on it and it will pop out.
IMPORTANT: Should water or any foreign object get into the Battery Compartment or the Card
Slot, turn the camera off immediately, remove the card and/or batteries, and allow the camera to
dry out completely before attempting to use again.
QUICK START
ATTACHING THE NECK STRAP
An adult must attach the Neck Strap. Here’s how:
• Place the clip on the end of the Neck Strap into the
opening in the connector which is attached to the camera
and press firmly until it clicks into place. (Fig. A)
• Repeat the instructions above to attach the remaining
end of the strap. (To detach the Neck Strap squeeze the
clip edges and pull apart.)
• Adjust the length of the Strap by using the plastic buckle
located along the strap.
NOTE: To attach or detach camera portion of connector,
see Fig. B.
CAUTION - DETACH NECK STRAP FROM CAMERA
BEFORE ENTERING WATER.
CAMERA MODES
VIDEO MODE
In this mode the Viewfinder will show what the camera sees in real time.
• Set up your shot in the Viewfinder then press and release Record to take a video.
NOTE: A red “RC” icon will appear in the top-left corner of the screen, and the elapsed time will
appear in the lower right corner.
• To stop recording and store what you have recorded, press the Record button again. The screen
will switch to the beginning of the film you just recorded with a big red Play arrow in the middle.
• Press the Record Button and the video will play back.
• Press the Left Button (or wait 5 seconds) and the camera will go back to the live image.
TIP: You can zoom the camera in and out by pressing the Zoom buttons! The Zoom Indicator on
the right side of the screen will tell you how far you are zoomed in or out!
NOTE: There is no zoom function in 640 X 480 video mode.
Video Mode
Still Picture Mode
Playback Mode
Fig. A Fig. B
ADDING SOUND TO YOUR VIDEO
• Before recording, press the Edit Button. You will see Sound and Image icons. (Fig. 5)
• Use the Left or Right Buttons to select Sound then press Record to confirm.
• Press the Left or Right Button again to hear the available sounds. (Fig.6) Stop at the one you
like, then press Record to add it to your video. The camera will then return to the live image.
Press Record to record your video with the sound included. Press Record again to stop
recording. (Press edit to exit edit mode.)
NOTE: Turn the Volume up high so the microphone can hear and record the sound!
ADDING IMAGES TO YOUR VIDEO
• Use the Left or Right Buttons to select your choice then press Record to confirm.
• Press the Left or Right Buttons to see the available images. (Fig.7) Stop at the one you like,
then press Record to add it to your video. The camera will then return to the live image with
your selected graphic. Press record to record your video with the image! Press Record again to
stop recording. (Press edit to exit edit mode.)
IMPORTANT - images on videos will only appear when viewed on camera viewfinder or on
TV screen.
Fig. 5 Fig. 7
L R
Fig. 6
L R
Construction
TURNING THE CAMERA ON
Once an adult has installed the batteries:
• Press and hold the Power button for 2 seconds. The Little Tikes™ logo will appear on the screen.
• Once the logo disappears the camera will automatically be set to Video Mode.
NOTE: To change modes, press and release the Power button. To turn the camera off, hold down
IMPORTANT: Before making videos or taking pictures, see Page 4 (MENU MODE) to set picture
quality. Also, camera must be at least 2 feet away from subject for best focus.
1 2 3
Jan 03, 2009 | Little Tikes My Real All-Ter Digital Video...
Memory card is write protected
you can see a tiny lock (kind of sliding button with the label ("lock") in memory card. Try it
-Saran
May 06, 2008 | Motorola Mobility ROKR E6 Smartphone
Memory card locked
I noticed that this camera does not work well with cheaper memory cards. The only brand that works without fail is the SanDisk brand.
Jan 04, 2008 | Casio EXILIM Card EX-S770 Digital Camera
How do I use the memory stick?
Recording Still images To The Memory Stick M.REC mode (Memory RECORD mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to CAMERA. 3. Press the PHOTO button. The still image is recorded to the Memory Card. To View photos on the Memory Card M.PLAY mode (Memory PLAYBACK mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER. The last recorded image appears. If there are no recorded images on the Memory Card, NO STORED PHOTO! or NO STORED MPEG4! will display on the screen. 3. Using the (FWD) and (REV) buttons, search for the desired still image. * To view the next image : press the (FWD) button. * To view the previous image : press the (REV) button. * Pressing (FWD) when you are on the last image will take you to the first image and pressing (REV) when you are on the first image will take you to the last image. * Keep pressing (FWD) or (REV) to search for an image quickly.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
How Do I Make An MPEG Recording?
You can record video with audio onto the Memory Card. Follow the instructions below. Recording moving pictures onto a MEMORY CARD 1. Insert a Memory Card into the slot on the camcorder. 2. Set the mode switch to MEMORY CARD position. 3. Set the power switch to CAMERA mode. 4. Press the START/STOP button, the images are recorded on the MEMORY CARD in MPEG4. * You can record 10 ~ 20 seconds continuously. * You can record a still image on the Memory Card by pressing the Photo button instead of the START/STOP button. 5. Press the START/STOP button to stop the recording. Notes: * Moving images that you recorded are saved in *.asf file format on the Memory Card. * The moving picture images on a Memory Card are smaller size and lower definition than those on a Tape. * The sound is recorded in mono. * The following functions cannot be operated in M.REC Mode. - DIS (Digital Image Stabilizer), Digital Zoom, Fade, Program AE, Digital Special Effect, Slow Shutter. * Don't insert or eject a tape during Memory card recording as it may record noise. * Don't eject the Memory Card during recording as it may break the data on the Memory Card or the Memory Card itself.
DXG Technology DXG-572V Digital Camera Logo
Top DXG Technology Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a DXG Technology Camera Expert? Answer questions, earn points and help others
