Question about GE WJSR2070B Top Load Washer
Washer thas not emty watter out
My washer thas everything but emty the watter ou.t
  • 714 Answers
Sounds like a bad drain pump
Posted on May 29, 2010
My washer makes alound grindin noise wen trying to empty
1) most Noises coming from washing machines coming during the cycles of SPIN .Clothes load can be un-balance. Stop the machine and balance the clothes.Start again, and repeat the step if necessary.
God bless you
Jun 28, 2012 | Washing Machines
Low watter on wash cycle is there a setting to add more watter to the wash cycle
Try checking the pressure switch. If adjustments are there try. Otherwise you have to check with another switch assy.
Try cleaning the small water hose connected to the switch assembley body.
Mar 30, 2010 | Maytag MAH6700AWW Neptune Front-Load...
I was using the iron and then there was no heat even thought it was still plugged in--the light on the iron went out while still plugged in
there are 2 possibilities what could be wrong
First one is that you didn't use distilled watter (you could use regular) by doing so a small coat of watter stone is covering all internal parts
Mix some vinegar with watter (ration 5 watter 1 vineger) and putt it in iron and than it will start breaking watter stone, you should use some cloaf that u don't need to wipe off exces watter stone, don't get burned!
DO NOT IRON WHILE DONG THIS
Second one is that there is a cable problem, but this is a big problem...
Oct 18, 2009 | Rowenta Irons
My may tag washer will not let me wash clothes and it say contols locked i cant even turn it on??? was working fine then just stopped
by the door there should be a limit switch. With your washer emty, program it as if you had it loaded and with your hand push that switch.
Oct 09, 2009 | Maytag EPIC MFW9700S Front Load Washer
Kenmore washer mode
thas exactly correctits amotor coupling part number 285753A, probalby $25 and you can find complete tear down of unt on you tube
Dec 08, 2008 | Washing Machines
My washer will not fill, it just drains stright out so the watter will ran for three hours. I just did a load the night befor and everything was fine. I did not move or disturb the washer in any way...
Candy, check the drain hose, make sure it has a air gap and that it is not down too far in the drain. Sounds like a siphoning problem....Catriver post back.
Oct 05, 2006 | Roper RAS8244KQ Top Load Washer
GE WJSR2070B Top Load Washer Logo
85 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
