Question about Onkyo Audio Players & Recorders
My Onkyo CR-315DAB receiver keeps losing its DAB presets but never its Fm presets. What am I doing wrong?
5 Suggested Answers
SOURCE: Onkyo receiver playing in mono only
sounds like a reception problem. Is there a visual meter for the reception? Check your antenna.
Posted on Feb 02, 2007
SOURCE: Losing memory settings
On remote control before you shut off yor receiver press "TEST" button to save the memory. It will save every setting. Make sure to do that all the time after you change the setings.
Posted on Feb 04, 2009
SOURCE: onkyo tuner
The manual is pretty easily accessible on Onkyo's website. http://www.ch.onkyo.com/files.download/tx-sr605_manual_e.pdf
Setting a preset is as easy as pressing "Memory", using the arrows to select a number, and pressing "Memory" again.
To DELETE a preset, press and hold "Memory" then press "Tuning Mode".
Posted on Nov 08, 2009
  • 1116 Answers
SOURCE: I have 6 preset DAB
You can download your manual for the radio at this link:
http://lowryelectronics.webeden.co.uk/#/gsdab0904/4536733630
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Posted on Jun 01, 2011
How do I set the fm volume to be the same as dab?
This depends on the Music System. Check the manual, check in settings and see if there is volume normalizer or try keeping the eualizer in defult, or reset the system.
Oct 04, 2014 | Car Audio & Video
Fm radio works fine but the dab will not find any stations, I have tried different aerials and still no good
What's the make & model of the radio?
Most DAB/FM radios work from the same antenna, so if you receive FM stations, you should receive DAB stations in your area.
It should be noted that DAB transmitters work on lower power than conventional FM transmitters, and so you may be in a weak reception area (for DAB). It should also be noted that DAB uses different frequencies than regular FM stations and household appliances such as laptops,WiFi, microwave ovens, etc can affect DAb reception.
Nov 18, 2013 | Audio Players & Recorders
I have SR 307 onkyo A/V receiver home theatre system. the remote control has stopped working. i checked with a local dealer and that the remote is okay and something has wrong in the receiver,
Did you check the remote with another Onkyo system at the dealer ??. If its OK try resetting the system. Remember you will loose all your stored presets ( FM and customized settings ) and the Amp will go back to factory settings.
While in standby mode hold down the DVD button and press the Standby/On button., the display will show Clear and the Receiver will go into standby mode. Turn it on and try the remote once again.
Jun 01, 2011 | Onkyo TX-SR307 A/V Receiver
RE: OnKYO CR-305TX CD RECEIVER Why do the "saved"
There shouldn't be a battery inside but a super capacitor that is supposed to keep the station memory...may be the capacitor is defective...it should be located on the tuner/radio board and may have a high value such as .47Farads at 5 volts...you may need a tech to replace if you have no working knowledge of circuits , but if you do , you should be able to obtain one at radio shack...they sometimes call these capacitors memory backup capacitors
Apr 27, 2011 | Onkyo Audio Players & Recorders
Hi, my ONKYO CR-545 no longer plays audio from my ipod nano when docked. It recognizes the ipod, charges it, changes tracks etc.. just won't do anything when i press play, The song title scrolls across the...
Hi Annebeth9, had the same problem with an ipod nano 5th gen.. After reseting the ipod with itunes (sorry i am from germany, in german its "wiederherstellen" in the version wndow beneath the "search for updates" button) everything worked fine again. These little electronic devices steal more of your time than you like, i am thinking of switching back to vinyl. Helmut from Berlin
Mar 30, 2011 | Onkyo Audio Players & Recorders
The DAB on my CR-515 has stopped working and says 'no stations'. What's hapened?
Just had the same problem. Had a power cut in the area and it's wiped everything on my CR515. You need to reset it to the factory defaults.
On the actual stereo (not remote), switch it on, then hold the stop button followed by the on/off button. Clear will appear on the screen and it'll then turn itself off, When you turn it back on, it'll ask you to wait. Your DAB should be restored.
Bear in mind, this will reset all your presets and any other preferences you have set on your system. It should also, however, restore your DAB.
Mar 19, 2011 | Onkyo Audio Players & Recorders
Have bought a Technika DAB 109 CRF radio and no instructions. 1. how do I tune it and SAVE to presets 2. How do I set the alarm? Thank you
To set alarm mode :- press Alarm 1 or 2 briefly to swtich between choices of Alarm On-Beep / DAB / FM / Off, keep pressing this alarm button until you get to the mode you want then stop pressing and leave to settle.
To set time: Press and HOLD Alarm 1 or 2 to change time. Minutes will flash first, use dial to change numbers, when you've got to the number you want press jog/select to change hour, use dial to change hour number. If you just leave it alone once you've reached the hour you want it will set where you left it, but...
If you want to specify preset channel/volume/beep tone etc keep pressing jog/preset after setting hour and use dial to set your preferences.
Feb 20, 2011 | Audio Players & Recorders
Onkyo tuner
the model is at the back panel it usually starts with a TX or a T. go to onkyousa.com or call 1-800-229-1887 were here to help.
Oct 29, 2008 | Onkyo TX-SR605 Receiver
Power Loss Onkyo TX-SR674
Hi LuckyLady1
Yes, some units lose their presets quickly with the power disconnected. Most lose all memory presets within 10 days. They are designed this way. You may have to get someone in to sort it out for you if you cannot do it. Or ask me for a chat session and I can talk you through it. :)
regards
Graeme
Apr 09, 2008 | Onkyo TX-SR674 Receiver
100 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
