Question about Samsung SyncMaster 204B 20.1" LCD Monitor
Monitor on/off button flickers
On/off button will not turn monitor on or off. It just flickers while screen is black.
    President:
  • 1,138 Answers
Hi!
The reason why the button of your monitor flickers is because the 12 volts output supply for your inverter board is not stable..
If you have the skills and the right tools for this, Here's what you need to do
1. If your monitor comes with a power supply adapter, open it..check and replace blown capacitor with same value..
2. If your monitor is using a cable power cord..open the back cover of your lcd..on the power supply section.. check and replace blown capacitor.
3. Check and resolder the terminals for fixing possible loose connections.
4. On the inverter board section...check and resolder the terminals for fixing possible loose connections, the high voltage inverter usually loose connections when overheat.
5. Other things to check if step 1 to 4 did not resolve your problem. Check and replace burnt high voltage transformer.. Check and replace busted backlight inverter..
Hope this fix your problems..
thanks.. much appreciated if you rate this help.
Posted on May 29, 2010
Screen Went Black
If you want to fix it, then you will need to buy some tools and basic knowledge of electronics, common problem with this monitor is the failed transistors and fuse in the inverter circuits, see pictures here as a guide: http://s807.photobucket.com/home/budm/allalbums
I would give the monitor to someone that is learning electronics to practice troubleshooting.
Mar 26, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor is flickering and go black severel times before coming.
i feel, you try go to control panel,, and display settings,, from there.. click on screen saver tab, there you can find power button,, click it and change all to never ,, and also dont forget to make screen saver to none.. and see..
Sep 27, 2009 | Samsung SyncMaster 203B LCD Monitor
Monitor flickers then goes to black/blank screen.
have you tested it for gone conponments
Aug 14, 2009 | Computers & Internet
Monitor turns off and power button light flickers on and off and
When does it do this? Is it a power saving mode? Check the connections to the VGA cable are secure.
Jul 20, 2009 | CTX S762A 17" LCD Monitor
HELP ME FIX MY MONITOR PLEASE
same thing is happening to me except when i turn on my computer, you can see the screen and its flickering then a few seconds later it turns all black.. :( !!
Dec 04, 2008 | Computers & Internet
Samsung 940 BW Monitor Not working (Black screen)
Hi...there,
That's indicated your backlight inverter are busted. Need to replaced a new one or repaired it. To repaired look for a bad capacitors with a bulged on top of each caps. Not sure, just replaced all the caps... Have a nice weekend!
Oct 09, 2008 | Samsung Syncmaster 940BW LCD Monitor
Monitor went black
Same with mine a couple days ago. I've been told the contacts have oxidized and need to be cleaned. It was going to cost about $80 to fix and no guarantee how long it would last so I just bought a new monitor.
Jan 04, 2008 | Dell E173FP 17" LCD Monitor
Acer AL1716 monitor flickers
i Have the same problem, this screen is used on the spare computer we have in a loft conversion and the room does get rather cold, Warming the screen up with a fan heater for a couple of minutes gets rid of the problem. When the fault occurs the buttons on the front to adjust the picture quality don't work they just turn off the monitor.
Dec 08, 2007 | Acer AL1716 17" LCD Monitor
Samsung SyncMaster 204B 20.1" LCD Monitor Logo
240 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
