Question about Brother XL-2600
Brother XL--2600 Sewing Machine not picking up Stitches at all!
Brother XL--2600 not picking up any Stitches at all! Have taken out the bobbin case and dusted, but to no avail. Also, needle is straight and installed correctly, but every time I sew, no stitches at all pick up. I am under the gun to get my project completed before I leave town. Please help!! Hope I can fix this myself.
  • 36 Answers
Take the thread out, Take the needle plate out Watch as the needle comes comes down, make sure the hook is just above the eye of the the needle as it makes its pass by the scarf of the needle if not refer to my post on timing.
Posted on Jun 02, 2010
Skipped bottom stitches
try changing the needle
make sure the bobbin is inserted correctly
make sure the bobbin is not warped
make sure the bobbin is turned the right way in the bobbin case
make sure the top tension is adjusted correctly
make sure the top and bobbin thread is the same
Feb 01, 2013 | Brother XL-5130 Mechanical Sewing Machine
My bobbin thread is straight
try adjusting the top tension and see if that help the bobbin stitches
to look normal
here is a 2 links for a free manual, check and see with is the right one
for the machine
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_XL_2600_2610_3500_3510_EN_206.PDF
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_XL_2600i_ENES_1478.PDF
Dec 23, 2012 | Brother XL-2600
How to put the bobbin case back together on a brother xl 2600 i
I would go to a sewing machine store with it and ask them it it looks right .if I wasn't sure
Oct 10, 2012 | Brother XL-2600I
My Brother XL-5021 sewing machine has stopped working and won't pick up the thread from the bobbin.
it's called being out of time,,and the machine can only be timed by a sewing machine repair technican,, because they have the tools for job
Feb 01, 2012 | Sewing Machines
Does the brother 2600 come with a bobbin case?
All machines have a bobbin case, if you have a drop in bobbin it drops into the bobbin case,
Aug 13, 2011 | Brother XL-2600
Brother xl-2600 As I am sewing ( not thick material) the thread keeps breaking, also over seams it is not sewing through. Then, when my bobbin ran out, went to change it and when pulling the needle down...
try changing the top thread tension to 3 or 4
also rethread the machine just in case the thread is hung up somewhere
take the bobbin out & put the bobbin in reverse of what you did before
you said you changed the needle, check to make sure it in correctly,, the flat side goes to the back of the machine, push it all the way up before tightening the screw
Aug 06, 2011 | Brother XL-5340 Mechanical Sewing Machine
The original bobbin provided with the machine is 11.5mm. But I could get only 11.4mm bobbin. Can I use that because in the manual it is said that we can't use other model bobbins.Please help.
Don't use it. The bobbin cases are designed to work with the specified bobbin size, see if you can track them down on Ebay or through a sewing machine dealer in your area.
Feb 28, 2011 | Brother XL-2600
Brother XL3030 SEWING MACHINE ..STRAIGHT STITCH LOOKS GOOD ON TOP OF FABRIC, BUT BOTTOM STITCHES ARE SKIPPING AND LOOPS FORM IN PLACES..YOU CAN PULL THE THREAD RIGHT THROUGH AND UNRAVEL ALL STITCHING! I...
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 19, 2011 | Brother XL-3030 Electronic Sewing Machine
I place the fabric on the machine, lower the foot and apply pressure to the foot peddle, when the machine begins to sew fabric is pulled down and the lower thread tangles, the machine make a crunching...
This is easily solved. Before you start sewing make sure your upper and lower threads are long enough for you to hold before lowering the presser foot. If these threads are too short they both get carried down into the bobbin along with the fabric and cause a big tangled mess. Always hold your threads at the back of your work with your left hand then lower your pressure foot and don't release the threads untill you have taken several stitches. Keep holding these threads during backstitching at the beggining of a seam too. Works like magic.
Dec 21, 2010 | Brother XL-3500
Brother XL-2600 Logo
968 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
