Question about Sharp R-530BS Microwave Oven
Will not operate. Does have power as the clock works.
Started by to keep running once you have finished and closed the door. Now it will not do anything! Clock is working. Have no patrs manuel.
  • Sharp Master
  • 9,098 Answers
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
Since this is posted under R-530BS, I'll assume that's your model number.
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you.
If that's not your model, feel free to contact me directly with your model number.
If you only need a switch, you can order a universal type here for $5 postpaid.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on May 30, 2010
How do I turn on the microwave and set the clock
well setting the clock comes first if my memory is right
Jan 14, 2016 | Microwave Ovens
Why would the microwave keep running if we just close the door and no time is set?
Good Afternoon Friend,
I understand that your Frigidaire microwave continues to run, when you close the door and no time is set. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power. You might need to set your clock before doing anything else. Put a cup of water inside your appliance and try to heat it up. If you are still noticing your microwave continuing to run, even after no time is set, I suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire Microwave Ovens
Why does the fan keep running on a kenmore spacemaster 300?
Check those 3 micro switches in the door latch assembly. A bad microswitch can blow the main fuse. This usually ruins the microswitch.
Nov 13, 2017 | Kenmore Microwave Ovens
I have a GE profile spacemaker xl 1800 microwave. I used it once this morning but then upon a second use some time after, there was nothing on the display, as if power was lost on it. I opened the door and...
The door switch may have become defective, cutting off power completely. When the oven restarts, it prompts you to set the clock just as it would if there had been a power interruption. It is possible that something has failed in the control logic and that probably will require attention from a repair technician.
Oct 31, 2013 | Microwave Ovens
Kenmore 401.80083700 won't turn off
It is one of two things, a defective door switch, or the keypad control board has failed.
Apr 18, 2012 | Kenmore 68361 Microwave Oven
Maytag microwave MMV4205BAW interior fan continues to run when door is closed
One of the micro switches has malfunctioned, and must be replaced for normal operation.
Apr 02, 2012 | Maytag Microwave Ovens
MH3184XPS-3 started humming last night. I unplugged it. I later plugged it in and it was still humming. There is power because the clock worked, but the microwave would not start.
You should keep the oven unplugged until it is fixed or unless it is being tested.
I would first check to see if the oven is heating when it should not be.
You can place a cup of water in the oven, close the door, and let it set for about 30 seconds. (No longer or it may be damaged from overheating).
If it is, then I would suspect door switch trouble (see this text file) or an issue on the control circuit board, which we regularly repair with our $39.95 repair service.
For more information on door switches, see these help files:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
Once you've checked it out, if you need further help, feel free to contact us here.
Jun 21, 2011 | Whirlpool MH3184XP Microwave Oven
Keypad Problems
Sometimes a keypad may not work because the door switches are faulty. When the door switches are working correctly it will allow the keypad to operate. They tell the microwave that the door is closed and the unit is dafe to use.
Many models have 3 door switches, it's wise to get all 3 replaced at once.
Mar 27, 2009 | Samsung Microwave Ovens
When we close the door the motor keeps running.
This just started happening on my Kenmore microwave because the door latch broke off.
Mar 10, 2009 | Samsung SMH7178STD Microwave Oven
No heating, no clock, no timer, otherwise fine!
One of your door interlock switches is defective . I would suggest having it repaired by a qualified repair tech in your area.
Oct 04, 2007 | Sharp R-1500 Microwave Oven
Sharp R-530BS Microwave Oven Logo
80 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
