Top agitator wont turn kenmore 70 series heavy duty plus
  • 714 Answers
Sounds like your dogears are worn out
Posted on May 29, 2010
I have kenmore 80 series heavy duty/ super capacity plus washer that after it fills with water,hot or cold and it starts the wash cycle, I noticed that the agitator only moves once in awhile and stops
hum either a bad timer sticking the point contacts close. have u tried this in all cycles? and possibly a motor with bad windings not enough power to run agitation? try running in mild or gentle and see what happens? I was tempted to say the cam dogs in agitator but they dont work then stop then work, when they go out they go out.
Feb 17, 2015 | Kenmore Washing Machines
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Dryer wont start.
can you hear the motor or does the unit humm or vibrate when it is turned on
if yes then have a look at the belt
if not it's time sor a service call
Aug 04, 2009 | Kenmore 700 6972 Dryer
Kenmore heavy duty series 70 won't spin
Will it drain ? IF wont drain either , then the lid switch is bad . (The piece on the washer where the lid actuator goes into the washer top ) . If it will drain , then the motor/trans coupling is bad , if it will not agitate/spin .
Jul 22, 2009 | Washing Machines
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
Bottom portion of agitator works, the top portion does not
Pry the agitator top off with a screwdriver (in the little slot provided)and remove the part with a 7/16" socket. Lift out the top part of the agitator and replace the four plastic dogs with parts from RepairClinic.com http://www.repairclinic.com/Appliance-Parts?s=t-110.82870820-%3d%3dc201 for $4.95 plus shipping.
I am replacing mine for the second time in 18 years. John
Jun 05, 2009 | Kenmore Washing Machines
Kenmore 82372110 70 series heavy duty plus won't spin
If it drains and won't spin you have to replace the direct drive coupling.
Feb 25, 2009 | Kenmore Washing Machines
Kenmore 90 plus series: heavy duty super capacity won't agitate
this is the site to find out how to fix your washer.
you have a broken drive coupling.
it probably wont agitate or spin, but will fill and drain.
you need to remove 2 screws from the control panel, hinge it back and then remove the 2 brass colored clips that hold the cabinet to the base. once you do then pull the entire cabinet forwards to a 45 degree angle and pull it off the base.
then pull the 2 clips off pump and then 2 more on the motor. that will allow you to get to the drive coupling. you will find it to be broken.
replace it with part number 285753a for about 15-20 bucks.
Jan 31, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 70 series Agitation and Spin Cycyle clicking
Sounds like you have a broken motor coupler. Not expensive. #13 on the diagram. Part # 285753, dave www.washermd.com
Dec 12, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
140 people viewed this question
Top Washing Machines Experts
