Question about Canon PowerShot G9 Digital Camera
Will not power on, lens never closed Replaced with new battery and charger, still no luck
  • 5 Answers
This particular Canon Model has a very common problem with some screws coming loose inside of the camera. You'll just need to have it fixed and it will work great again. It's most often an R Fuse on the DCDC Board but sometimes it's something else after that common short. The best place for help with this would be: www.camerasandparts.com They're the ones for service for the Powershots, that's all they work on. Your G9 No Power Problem is right there on their site and all it costs is $89 to have fixed and the camera serviced too. That even covers your shipping back if your in the US. The neat thing with their service is that they do the correction to the G9 so this problem doesn't ever happen again with those two inner screws. Good luck, your problem is posted on that site, their the place for help with these. All the best with getting this no power problem looked after.
Posted on Jun 27, 2010
  • Chuck Roast Jun 02, 2012
    You wouldn't happen to work for www.camerasandparts.com would you? Because that would be like spamming people who want UNBIASED information. CanonASSIST would only be a ********* if that were so.
Camera keeps opening and closing, orange light comes on
Wow, Not even the manual knows this error. Must be serious. It can mean two things in my mind. The lens is obstructed some how. Inside or outside. Or the battery is not ok. If you can't see anything on the lens barrel outside, please try to charge the battery. The camera will shut down without warning, when the power is low. Be aware the camera won't work as you expect, when a USB cable is attached. Actually you are not allowed to connect the charger, when the camera is still switched on. Look how the charger reacts. See if the battery is charged as before, because if the signal battery full does not appear it could be you have to buy a new battery.
Success.
Jan 13, 2014 | Olympus Stylus 700 / 700 Digital Camera
Camera has brand new batteries... when you turn on the power, the green light comes on, then nothing happens... and after a few seconds... there are three beeps and its shuts off
its probably that this is a motherboard error, if the camera are dropped or have received a pressure. this is not a good signal. have you see if the lenns prove to open in the moment taht you turn on the camera??
if you hear a little rumor of the lens....is probably that this is a lens damage. if you hear nothing its possible that is lens damage or motherboard damage. to first control better that the batterie charger dont are faulty??? it s possible that the batterie are new but the charger dont charge the batteries proper . if batterie and charger is ok. this is a charatteristic, lens or motherboard failure. its important to find a onest camera repairer. to open the camera and look if the camera have eletronic damage, or only a faul contact problem, from a internal contact flat. good luck
Jun 03, 2010 | Samsung S1050 Digital Camera
Digital camera defect.
the focus lens inside lens assembly is out of time . will not fully power on till lens assembly is replaced.
Apr 16, 2009 | Cameras
My L200 samsung camara is frozen and the lens are stuck out
I had the same problem - and wondered if if might be that the battery didn't have enough 'grunt' to close the lense - so I am charging it via the actual charger (rather than through the computer) and sure enough, I turned it on and then off, and the lense closed. The green light comes on when I plug the camera into the computer to download photos, and I thought this was therefore charging the battery, but maybe it doesn't charge it properly. Anyway, my lense is now closed and the battery is still charging (light is still red). Good luck.
Jan 06, 2009 | Samsung L200 Digital Camera
Locked up
Try removing your memory card. I had the same problem and this worked. You might need a new card. Good luck.
Oct 01, 2008 | Gateway DC-M42 Digital Camera
Locked lens
You have to replace whole lens block,the zoom gears are probably causes your problem but as I know they can't be replaced separately
Feb 29, 2008 | Casio Exilim Card EX-S100 Digital Camera
Kodak Easyshare CX7530 won't stay powered on
SOLUTION: Fot the past two years, fully charged NiMH and new alkaline (generic and fresh Name Brand batteries) in my CX7530 always gave a red light and immediate power off -- symptoms of low batteries. Today I tried it again with the same problem. This time, I folded up a small piece of stiff paper to depress the small Lithium battery module detect switch in the battery compartment, and put my NiMH batteries back in -- it WORKED for the first time in two years! After removing the paper and reinserting the batteries, it still works. I suspect this somehow recalibrates the low battery detect circuit. I hope it helps you as well.
Oct 18, 2007 | Kodak EasyShare CX7530 Digital Camera
Will not charge battery
Please contact the nearest Authorized Sony Service. If you need more info please advice. Arpi
Feb 16, 2007 | Sony DSC-T7 Digital Camera
Canon PowerShot G9 Digital Camera Logo
122 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
