Washing machine hose
Replacement cost for flexi hose from base of washer to pump for kelvinator machine
    President:
  • 1,294 Answers
Try these sites: This is a 'do it yourself' job.
espares.co.uk
RepairClinic.com
AppliancePartsPros.com
Posted on Apr 08, 2008
I have a Kelvinator KL60FLM front loader washing machine. It is not pumping in water on one phase of its cycles what can be the problem. The motor burnt out and I replaced it not not pumping in water on...
the water is not pumped in, its let into the machine through the water supply valve which is located where the supply hoses attach to the back of the washer-this seems strange that it would fill to start with and then not on the rinse cycle-is this what your saying is happening-Denny
Oct 25, 2013 | Washing Machines
Washer is flashing ND and not spinning out
So you'll need to unplug the machine then take the back access panel off and remove the rubber hoses to the drain pump and the drain pump will twist off the washer bottom base, and check for something clogging the drain pump.
Here is the pump if you need to replace it.
Dec 10, 2012 | Maytag Neptune MAH5500B Front Load Washer
My Maytag MAV6000 washer leaks intermittently. In the past 3 weeks it has been used many times but has leaked 3 times. I removed the front panel to look at the pump and hoses and put the washer through a...
Realistically, a 10-year old Maytag is nearing the end of its usual life. The pump may be leaking at random times during a wash cycle. If you put 50% of the cost of a new one into repairs, it is time to thing seriously about replacement of the machine.
Apr 26, 2017 | Maytag Atlantis MAV6000 Top Load Washer
Roper Washer is leaking at the base, It appears to be coming from the water pump.
Its not uncommon for these drain pumps to leak fortunately the are very easy to replace. Place a small pan under pump remove both hoses and then pop off the retaining clips and pull the pump forward. line up the new pumps drive slot with the drive shaft coming off the motor reinstall retaining clips and hoses Good Luck
Nov 14, 2010 | Roper RAS8445KQ Top Load Washer
Leaking washing machine
The leak is probally coming from the drain pump itself or the discharge hose onnected to the pump. This is easy to check and replace. This video should help
http://appliancehelponline.com/topdirectdrivevideo.html
http://appliancehelponline.com/toploadcabinet.html
Jun 04, 2010 | Kenmore 22622 Top Load Washer
Maytag Atlantis top loader washing machine won't spin out water. it spins but the water doesn't go out. it's only about 5 years old. help please!!!
The drain hose is plugged or kinked or the drain pump is not working. Check and clear the drain hose from any debris that might be causing the water not to be pumped out. After checking and clearing the drain hose and the water is still not pumped out of the washer, check the pump to see if the impeller is good or the pump needs to be replaced. Access to the pump requires the top cover and the front panel to be removed. Disconnect power to the washer prior to servicing to avoid the risk of electric shock.
The top cover is attached to the front panel by two clips positioned at about 3 inches from the corners. Use a putty knife and insert the blade into the seam between the top cover and the front panel assembly at the position of the clips.
Push the putty knife blade against the clips, one side at a time while lifting the cover to disengage the clips. Lift the top cover off the front panel then remove the two screws securing the front panel to the upper front corner braces of the cabinet.
Lean the top edge of the front panel away from the cabinet and lift the panel to disengage its bottom from the base clips. Move the front panel away from the cabinet to access the pump.
Disconnect the pump inlet and outlet hoses from the pump then remove the three screws mounting the pump assembly to the base of the washer.
Slide the pump to the rear of the washer to disengage the belt from the pump pulley and pull the pump assembly out of the washer.
Clear the pump inlet and outlet hoses for any debris to ensure water is not blocked from being pumped out of the washer.
Check the impeller. Remove the four screws securing the pump housing to the pump base then lift the housing off the base. Clean the impeller and the pump housing; replace the pump assembly if the impeller is damaged.
To replace the pump, set the pump pulley into the base opening and put the belt on the pulley. Install the mounting screws while holding tension on the belt to keep it on the pulleys.
Connect the pump inlet and outlet hoses and secure it with the clamps.
Position the bottom of the front panel back into the base clips then secure the top to the upper front corner braces of the cabinet with the two securing screws.
Push the top cover down into position to the front panel to complete the procedure.
Note: For Maytag Atlantis MAV8000A, the pump assembly is part number 35-6465.
Mar 22, 2010 | Maytag Atlantis MAV8000
Water wont drain during spin
Check the drain hose, drain pump and the drain sump for any object that might be blocking the passage of water.
Drain Problem Troubleshooting Guide for Frigidaire Front Load Washers
  1. Safety first. Unplug the machine.
  2. Remove the drain hose from the drainage.
  3. Cushion the top rear edge of the machine with a thick cloth then lean it back against the wall.
  4. Remove the two screws holding the front access panel to the base of the machine.
  5. Pull the front access panel down and out.
  6. Lay a towel under the drain sump to prevent flooding the base of the machine.
  7. Remove the drain sump from the tub by loosening the clamp holding it..
  8. Remove the drain hose from the pump by loosening the clamp holding it.
  9. Remove the two screws holding the pump housing to the base of the machine.
  10. Disconnect the wiring harness from the pump motor terminals then pull the pump out of the machine.
  11. Remove the drain sump from the pump by loosening the clamp holding it.
  12. Check the drain sump and the drain hose for any clogging and clean it.
  13. Replace the drain pump if the drain hose and drain sump are not clogged. Install the new pump on reverse of the removal steps above.
Feel free to ask for further assistance if necessary.
Jan 23, 2010 | Frigidaire ATF6000ES Front Load Washer
Whirlpool top loading washing machine not finishing cycle
SOUNDS LIKE A PUMP HAS GONE BAD. REPLACE IT. IT WOULDN'T COST TOO MUCH.
May 14, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Frigidaire front load washer model LTF2940FEO. As
remove lower kick panel and check for leak at door boot and drain pump.
Apr 23, 2009 | Frigidaire ATF6000ES Front Load Washer
LG washer/dryer combo will not drain water
easy first unplug unit..take back remove phillips head screws...now the pump drain hose is the other side of the filter in front just take a pliers remove clamp,,replace hose..close unit plug back in
Aug 18, 2008 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Washing Machines Logo
Top Washing Machines Experts
