Question about Dell Inspiron 6400 Notebook
My Dell Inpiron 6400 has just died.
Was working with & it suddenly shut down.
Now it wont power up & will not do anything on pressing the start button.
Power supply & battery register ok.
Any ideas on what i going on.
Only know the basic functions of the pc.
Thanks
  • 428 Answers
Most probably a power unit, mother board or a processor failure. Any of the three can happen. I recommend you to take it to a tech. If there is a Dell service station take it there. If it just shut down while you were working: Have you checked the battery. Have you tried it using the direct power? Any burning marks or smell? Have you checked the Adapter also? Check them. IF you use direct power were you using a surge protector? Have you dropped it? Does the start button work well? Any abnormal thing related to the button? Have you spilt water on the machine? If all are fine then you have to take it to a tech.
Posted on May 29, 2010
Testimonial: "Very prompt response. Will take the advise of getting a techy to have a look as with all things electronic, is worth getting fixed or just biting the bullet & upgrading anyway."
Dell Dimension 2350. After I shut it down and try
Check that the computer is not hibernating rather than shutting down. It will be in the power settings.
Mar 06, 2010 | Dell Dimension 4600 PC Desktop
Got a new battery for Dell Inspiron 6400 but it won't charge
well if it's a new battery and you're having issues send it back, you may need to calibrate your new battery with the laptop
Nov 06, 2009 | Dell Inspiron 6400 Notebook
Screen wont turn on , i have a inspiron 6400 .. I rang dell & my extra 3yr warranty ran out just 6 weeks ago & * They WONT HELP*
when you say screen will not turn on it means we do not have display right? now, try this. turn off laptop, press and hold D key then press power button, check if the LCD will display colors if yes then it might be your video card causes the problem which needs motherboard replacement. if no colors appear then LCD needs replacement.
Oct 15, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 8100 Motherboard Problem?
if the processor fan is off or removed processor heat and its work for 1 or 2 second thats why change the fan and then try again
Oct 02, 2009 | Dell Computers & Internet
I have dell inspiron 6400, Suddenly system doesn't recognize my genuine Dell 65W power suply which was working for 3 years
Please open Bios by pressing F2. If in Power settings it shows the ac type unknown ur system board needs replacement. If it is showing ac type none then the ac adapter needs to be replaced
Jul 16, 2009 | Dell Inspiron 6400 Notebook
Cannot get by dell screen to come back on once it hibernates
sounds like a power scheme setting is shutting off your monitor after a time-out period. sometimes monitor will not return without re-boot. change your power options settings in control panel.
May 16, 2009 | Dell Inspiron 6400 Notebook
Facing problem with battery of Dell Inspiron 6400
1. Shut down the system, remove the battery and the Ac adapter from the computer.
2. Press the power on button for 10 seconds
3. Reinsert the battery
4. Power on the computer and as soon as you see the dell logo press the f2 key a couple of time
5. Using the up down arrow keys , go to the option that says battery info. If there is an error message listed kindly post it back
6. Otherwise shut down the computer reconnect the ac.adapter and check if the problem is solved
Also the battery has a diagnostic lights on it , remove the battery from the computer and press the button on the battery a set of lights would glow. If they are steady and come in a series the battery is good , If some lights are missing the battery is bad and may need replacement
Thanks
Proton
May 15, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Screen turns black Problem
Could you please run the diagonistics on the computer?
Turn on the computer. When the DELL logo appears, press <F12> immediately. Select Diagnostics from the boot menu and press <Enter>.
NOTE: If you wait too long and the operating system logo appears, continue to wait until you see the
Microsoft Windows desktop. Then shut down your computer and try again.
b Press and hold the <Fn> key while powering the system on.
Make a note of any errors that you get after running the diagnositcs on the computer.
Mar 08, 2008 | Dell Inspiron 6400 Notebook
Laptop suddenly won't start
It could possibly be a bad motherboard. But before having the mobo replaced, I suggest you swap out parts from a working system to eliminate points of failure. if you don't have the parts, just remove the parts not needed for posting. this includes the hdd, optical drive, modem, bluetooth card, wireless card, and external devices. once you see the dell logo, install these devices one at a time and see what causes the problem. If you decided to have the mobo replaced, you can send your system to the depot for repairs. before this try pushing F12 when booting see if you can get onto the dell diagnostics.
Jan 11, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
156 people viewed this question
Alun Cox
