Question about Brother PC-6000 Pacesetter
Thread bunches at the bobin and ruins embroidery
    President:
  • 1,070 Answers
Hello Friend,
Check Whole Following Link... 1.Link 2. Link 3. Link 4. Link 5. Link...
Here is also Guide available for your Product Click here[This may take Several minutes according to your Connection Speed]...
Hope you make better...Thanks for Contacting FixYa...
Posted on May 29, 2010
  • 560 Answers
Hi. You may have a buildup of lint and dust in the bobbin case. Clean the bobbin case, if problem persists try a different bobbin. Please visit the links for more troubleshooting and embroidery tips: http://www.annaboveembroidery.com/trinmaem.html http://www.emblibrary.com/EL/elprojects/SimpleProduct_ELP.aspx?CS_ProductID=PR1238&CS_Catalog=Elprojects
What is wrong when the underside of embroidery has bunched thread
Hello
The bunched-up thread on the underside is the needle thread. Check that the upper thread is threaded correctly, passing through all the required thread guides and that the thread is securely lodged in the tension assembly ... there should be reasonable tension when upper thread being pulled by hand.
Also check that:
- there are no 'dust bunnies' or a piece of thread hiding in the tension assembly, and that
- the needle is inserted correctly and that it is a system 130/705H Embroidery needle.
Happy Stitching
Sewingirl/
Apr 23, 2017 | Sewing Machines
Top thread bunching under fabric when sewing
tension could be too loose. start with bobbin tension- should allow thread to pass with SLIGHT resistance. then adjust top tension at about 2-3 to start.
Jun 01, 2010 | Singer 8280 Mechanical Sewing Machine
How to stop bobin thread from knotting
When loading the bobbin there is most likely not enough tension on the thread letting it overlap incorrectly. Try wrapping thread around a tensioner when filling and that should help. That way the bobbin is rolled as tight as the tension on the upper thread when sewing.
Apr 13, 2010 | Brother LS-2125 Mechanical Sewing Machine
How can you fix the under threading of a sewing
Check the ovious things first make sure you needle isnt broken... then make sure there isnt any thread twisted inside your bobin housing. make sure bobin is inserted correctly if those things dont help it could be an issue of timing in your machine... I work as an embroidery operator in a factory setting and those things usually help..
Apr 08, 2010 | Singer 3116 Simple
The uper thread dose not catch the bottom thread
If there is a screw on the side of bobbin case try tightening it up.This usually worked on my old machine.
Sep 18, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
Machine is not sewing properly
use larger needle, check bobin thread, bobin should go one way, if it bunches up switch dirrection the bobin turns
May 23, 2009 | Bernina Virtuosa 160
Problem with my Babylock embroidery machine
I think you may have forgotten to put on the Q presser foot.
Feb 16, 2009 | Baby Lock Esante
Thread from bobin doesn`t leave smooth sewing on bottom of fabric
hi make sure pressure foot is raised before you start to thread machine ortherwise thread will not slide between tension discs this will cause bunching underside of fabric ...good idea to replace needle good luck
mary h
Jan 05, 2009 | Husqvarna Viking 1
Thread bunches from the bottom while sewing.
Hello, sewing is a part of my income and I've encountered this problem before and managed to fix it on my own, by trying out these different things. I re-threaded the machine and checked to make sure that the tension is not too loose. Check the bobin and the sack the bobin fits into, sometimes it comes loose too, click it back into place and re-do the bobin. adjust the tightness of the stiitches, I usually put it on 2 .5 - 3. Hope this helps. Good luck to all. Nefishakh@hotmail.com
Nov 16, 2008 | Singer 5050 Mechanical Sewing Machine
I have model 8280 and the bobbin thread keeps bunching up on the bottom. I have tried to rethread it but it keeps happening.
i think your putting in your bobin backwards,
to check put your bobin in and hold bobin , and bobin case by thread if it unrolls its backwards,
hope this helps!!
Jul 26, 2008 | Singer 8280 Mechanical Sewing Machine
Sewing Machines Logo
26 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
