Question about Bissell 35755 CleanView Bagless Upright Vacuum
I have a Bissel Cleanview Helix, model #82H1. The
I have a Bissel Cleanview Helix, model #82H1. The brush does not turn. Can anyone help me? I would also like to have a manual. Thanks!
Vac Belts
  • 701 Answers
SOURCE: New Bissell Cleanview Helix is aking a high
It most likely is a worn drive belt. Here is a link to the belt you need and the manual:
Bissell Cleanview Helix Belt and Manual
Posted on Nov 24, 2009
  • 389 Answers
SOURCE: need manual for bissel powe steamer brush select
User Manuals can be downloaded from the Bissell website
Posted on Feb 07, 2010
hmerchant110
  • 7191 Answers
SOURCE: I need to download an instruction manual for
You can download the instruction manual by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Posted on Jul 21, 2010
  • 377 Answers
SOURCE: my bissell helix cleanview vacuums brush doesn't
Sounds like the beater brush is frozen and won't turn. Remove the beater brush and clean off all debris, especially at both ends. You will find a square(?) piece at each end of the beater brush that holds it in place. This need to turn freely. Put a little WD40 on these where the center rod of the beater brush enters the small holders and turn by hand until they turn freely. Once this is done, assemble with new belt, making sure the belt is put on properly. If the belt is missing and you need to replace, I would still do the cleaning on the beater brush. It should move freely when you turn it by hand.
Posted on Sep 12, 2010
  • 903 Answers
SOURCE: the turbo brush attachment on
The turbo brush may just need to be cleaned. If hair or other large debris gets wrapped around the brush, it can prevent it from spinning. Since the top of the turbo brush is clear, you can look in and see if there is a lot of hair wrapped around the brush. If so, you can open it up by removing the two screws on the bottom of the brush and popping the clear cover off, then cleaning all the debris from the brush (scissors work well if its hard to get dog hair off). Be careful to see how the brush goes back together as you take it apart.
If cleaning the brush doesn't fix it, the belt might be broken. As you're looking at the top of the brush, there is a little belt that goes from the brush itself to the large blue/green gear (it's red on some models) so that if you reach your hand in and turn the gear, the brush should spin. If this belt is broken or missing, it will need to be replaced. You can probably find a replacement belt online, or you can order a whole new turbo brush from the Bissell website for $24.99.
Posted on Apr 07, 2011
Walmart return policy
It probably has hair and dirt in the endcaps which has seized the brush roll. You will need to. Buy a new brushroll and. Belt
Jul 31, 2014 | Bissell Cleanview Helix Upright Vacuum...
Need to replace release lever
Hi Rita! You may want to have one of BISSELL Authorized Service Centers to assist you with replacing the release lever.
Here's a link to assist you in locating one in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
Feb 18, 2013 | Bissell 82H1 Cleanview Helix Bagless...
My bissell helix is blowing out the dirt it picks up
sounds like you have a blockage in the suction hose --- 9 times out of 10 the blockage is at the area of the machine where the hose kinda bends down to the floor unit. remove the bottom plate ( like you were going to replace the belt ) and look up into the hose and see if it is clogged -- use a wire coat hanger to fish out any debris. also check the main filter and tap out and use a brush to clean as good as you can ( a air compressor works best for this ) .. ( some filters are made to be washed in the dish washer,, check to see if your filter can ba washed ),, after all is clean and clear your vacume should be running like new again.
c...
Feb 02, 2011 | Bissell 82H1 Cleanview Helix Bagless...
The turbobrush for my cleanview helix 22c1 is not working
It's probably either just dirty, or the belt is broken. If it's dirty, you can just take the cover off (two Phillips head screws on the bottom) and clean everything off the brush.
If the belt is broken, you can tell by turning the large gear at the back of the brush -- if the brush turns when you spin the gear, the belt isn't broken -- then you'll need to replace it. You can buy a new belt online, or you can buy a replacement Turbo Brush directly from Bissell ($24.99).
Hope that helps!
Jan 10, 2011 | Bissell CleanView Helix 22C1 Bagged...
My vacuum brush wont rolling when I use it, so I think when I use it, it seems it doesnt work at all, what can I do to fix this machine, so I dont have to buy the new one? Thanks a lot for the answer..!
the belt that drives the brush may have came off and twisted jamming brush,or could be jammed with a string off carpet edge, you will have to remove cover from bottom of unit and clean debris or replace belt. good luck
Jan 06, 2011 | Bissell 82H1 Cleanview Helix Bagless...
Bissell 35755 CleanView Bagless Upright Vacuum Logo
132 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
