Question about Splendide 2000S Vented Washer/Dryer
The door on the machine does not open
door on machine does not open when dry or wash cycle complete
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with if the door lock is stuck and wont unlock then you can pry it to open, and just don’t try too hard. The issue can be with the door latch that is stuck, to unlock it you can stick a flat screw driver behind the door latch and then lever it to open so that you don’t have to pry it to open. Once it’s done, please make sure to replace the door latch assembly to avoid any further issues. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 29, 2010
SOURCE: Washing Machine Door won't open
I had the same problem. I went through all the steps on this thread to no avail. Finaly I just pryed the thing open - with no damage, thank goodness.
Once open I saw that the latch in the door didn't move when I pulled the handle. The problem it seems was in the latch on the door itself. If you end up this problem and want to get wet clothes out, just stick a flat-head screwdriver, behind the door latch into the horseshoe-shaped metal bit and lever it open - no prying necessary.
Not sure how I'm going to fix this permantely but at least I got my wet clothes out and can do laundry as long as I keep the screwdriver near by.
To fix - I'll either need to figure out how to disassemble the door and replace the latch mechanism, or just buy a whole new door.
Posted on Sep 21, 2008
gittos73
  • 244 Answers
SOURCE: Broken door handle for a Thor washing machine
there r 2 ways to get the door open 1)use a normal knife and place in front of the door handle push it in and it should open 2)pull the plug out take the lid off now place your hand down to where the catch goes into the washer using your fingers u should be able to pop it open with a bit off fiddling
Posted on Dec 16, 2008
  • 56 Answers
SOURCE: Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Posted on Feb 11, 2010
SOURCE: LG Tromm Front door won't unlock
I have this exact problem!!! Did anyone ever figure it out??!! HELP!!
Posted on Jul 19, 2010
blueextc3221
  • 15935 Answers
SOURCE: Washing machine door won't open
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Why am I not able to open the door of my front loading washing machine?model WD7652CBW ?
filter chocked clean and make shure that pump turns by fisically moving it
Aug 13, 2014 | Washing Machines
Whirlpool frontload washing machine door will not open after the
if there is still water in the washer you can use a wet dry shop vac and attach it to the end of the drain hose.Once all the water is removed from the washer you should be able to open the door.
then you need to check the drain pump for anything that may be obstructing the pump. make sure to check the hose that leads from the bottom of the tub to the drain pump.
Jun 21, 2010 | Washing Machines
Rid of Mildew Smell?
Make sure there are no leaks from the machine. look behind it and check the water inlet hose and connectors for any damage. Also look under the machine for any water as this may indicate a leak from the internal hose and pipe work and / or water pump. Also check that the outlet hose is completely clear of debris and soap scum build up and check that the filter is clean.
To keep the machine clean of waste build up and to keep any bad odours away
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure monthly
Aug 22, 2009 | Bosch Nexxt 500 Plus WFMC5301UC
I have a front loading washing machine that smells inside. Any suggestions ???
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Jun 22, 2009 | Daewoo DW500M Top Load Washer
Sewer gas smell
Apr 29, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
A mold smell from my washing machine
Dec 28, 2008 | Bosch Classixx WFO 2466 Front Load Washer
My washing machine has a bad smell and wont work
Oct 20, 2008 | Whirlpool AWM5125/1 Front Load Washer
Smelly washing machine
Oct 10, 2008 | Kenmore 24832 Top Load Washer
Washing machine has a musty smell
Jul 29, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Smell coming from washing machine
Apr 18, 2008 | Hotpoint WMM39 Front Load Washer
Splendide 2000S Vented Washer/Dryer Logo
76 people viewed this question
Top Splendide Washing Machines Experts
Doug Adams
Doug Adams
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
