Question about Hampton Bay 24750 Huntington III Ceiling Fan
Wiring diagram for a 3 way ceiling pull switch.
    Guru:
  • 351 Answers
These fans are manufactured by a number of overseas companies and sold exclusively by Home Depot. They do not have a standard color code for the fan switch. What you can do is turn off the power, keep the white neutral connected. Then using the black power wire fro the ceiling, take one of the switch wires and connect to that black, turn the power on and observe the speed .. low mark it 1, medium mark it 2, high mark it 3. Repeat untill you have identified all the speed wires. Then connect these wires to the 1,2,3, terminations of your new switch
Questions?
Please Vote !
Posted on Jun 04, 2010
    Problem Solver:
  • 5 Answers
GRAY from rev. sw. to GRAY from motor and #1 on velo. sw. WHITE from rev. sw. to WHITE from ceiling, capacitor, & light ORANGE or PINK from rev. sw. to ORANGE or PINK from motor YELLOW from rev. sw. to YELLOW from motor RED from capacitor to RED from motor BROWN from motor to #2 on velo. sw. PURPLE from motor to #3 on velo. sw. BLACK from light to BLUE from ceiling BLACK from velo. sw. to BLACK from ceiling
Posted on Jun 25, 2010
SOURCE: wiring pull chain 3 way switch for ceiling fan
I am in the middle of doing this now. 1 = Yellow; 2 = Blue; 3 = White; and L = Black.
Posted on Oct 06, 2009
SOURCE: I need a basic wiring diagram for a 3spd, 3 wire
Try L-BLACK 1-GRAY 2-BROWN 3-PURPLE. IF THIS COMBO DOESN'T WORK. BLACK WIRE GOES TO L , 123 IS YOUR SPEEDS YOU WILL HAVE HOOK THEM UP BY PROCESS OF ELIMINATION FIGURE OUT WHICH IS HIGH MED & LOW. IT SHOULD BE 1-HIGH 2-MED 3-LOW.
Posted on Jul 27, 2010
  • 235 Answers
SOURCE: Need a wiring diagram for a HamptonBay ceiling fan pull switch
Black is hot-white is neutral-blue is your light kit and goes with the black- yellow? should be a green for ground.
Posted on Jun 30, 2009
SOURCE: Ceiling fan capacitor hook up problem. I have a 3
The reverse switch on my Hampton Bay ceiling fan didn't work. I cut the 6 wires; 1 white, 1 gray, 2 pink, 2 yellow. Here's what I did. Removed reverse switch. Had 6 wires white, gray, 2 yellow, 2 pink. Connected gray to yellow, connected white to pink and fan runs fine. Is this OK? I do not need to reverse fan. It's been running for 1 hour now with no problems. Don S.
Posted on Jun 11, 2010
SOURCE: pull switch wiring schmetic
Call an electrician
Posted on Feb 12, 2009
Need a KTE 3A-250VAC ceiling fan pull switch wiring diagram for a 3 speed Harbor Breeze fan UL model HST52-II
They are all wired the same, just go for color for color when changing the switch. It can be a testing job to release the old wires and installing them into the new one. Not much room.
May 28, 2017 | Dryers
How do i hook up 3 function switch
1) Copy following link to see wiring diagrams:
http://waterheatertimer.org/How-to-wire-switches.html#triple
2) There are two basic wiring type, depending if power wire and neutral arrive in switch box first, or power wire and neutral arrive in ceiling box.
3) Most homes, the power wire is in ceiling box.
In this case, a minimum of 4 wires are needed between ceiling box and switch.
Dec 09, 2012 | Leviton 1755 Triple Rocker Switch Decora
Westinghouse fan wiring diagram
Copy following link for general assistance wiring 4-wire ceiling fan switch:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Jul 14, 2012 | Electrical Supplies
I have a 3 speed fan switch with 4 wires. The wire colors are grey,black,yellow,and brown. Where do they go such as L,1,2,3 on the switch?
Did you get a wiring diagram with the switch/fan? This should tell you which is which.
Each manufacturer has different color coding. If you didn't get a diagram, contact the manufacturer for instructions.
Good luck,
Handie Andie
Mar 25, 2011 | Solar Fan Impressions 3 Speed/4 Wire...
Wiring pull chain 3 way switch for ceiling fan
Jun 28, 2009 | Kenroy International Ceiling Fan - 10660
I'm trying to install a used Shell Electric Manufacturing (Holdings) Co. LTD. model U42 ceiling fan, however it appears that the internal wiring has been moved around and in some cases cut off. I am...
the black rectangle is a capacitor! there is no diode in a ceiling fan, usually the white wire is the common or neutral , the blue is for lighting and the black one is for the fan
Mar 10, 2009 | Dryers
WIRING OF 3-WAY SPEED SWITCH FOR HAMPTON FAN
1 - Red/Pink
2 - Purple
3 - Yellow
L - Black
Mar 11, 2008 | Oasis Hunter 54' Ceiling Fan
Hampton Bay 24750 Huntington III Ceiling Fan Logo
6,165 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
