Question about Kenmore Elite 45986 Front Load Washer
F dl code
Can't get it to reset or open the door
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error “dlf” or you can say "F dl" means a door latch failure. This means that you’ll need to replace the door latch assembly however before doing that you can leave the washer unplugged for 30minutes so that it resets itself. In the meantime when it’s unplugged just inspect the door latch wiring to ensure all the connector plugs are intact and not loose or broken. You can access the door latch wiring harness by removing the top panel of the washer. To remove the top panel just remove the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, and then lift off. Locate the door latch assembly behind the front panel on the right hand side. Trace all the connectors from the door latch to the Central Control Unit (CCU) and make sure they are properly seated at both ends. If after doing this still the issue is not resolved then unfortunately you have to get the door latch replaced. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on May 29, 2010
  • terryeubanks May 29, 2010
    Unpluged and waited 30 minutes. Still cannot get the door open or get it to start
  • Rylee Smith
    Rylee Smith May 29, 2010
    This means that you’ll need to replace the door latch assembly, to unlock it you can stick a flat screw driver behind the door latch and then lever it to open so that you don’t have to pry it to open. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
Washer was working.. electicity whet out... when emergency generator came in.. door lock message.. nothin I do works
Why is the "F dl" light come on - Kenmore Elite HE3 ...
https://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...
iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock ... orrepair the following Door Lock Mechanism broken or removed from the Door ... these are usually indications of a failed door latch assembly and will require replacement. ...FdL code would not reset until I turned washer on to start load.
Troubleshooting - Support - Dexter Laundry
www.dexter.com/support/troubleshooting/
Dexter Washer Troubleshooting. Select your problem form the following list to reveal a list of possible solutions and supporting documentation. Constant ... F1 / Door Lock Error Door failed to lock properly. + ... Error Code F13, F15, F17, F19 +.
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Failure Code, Condition, Check/Repair. "F1?, Water ... "F7?, Door lockrelease fault, ?· Bent pull-rod for door latch. ?· Bad door latch ... Water overflow error, Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord. ?· Check wiring ...
Why won't the door open on my Kenmore front-loading ...
Dec 10, 2015 | Washing Machines
CFEF372BC2 - Oven Door Locked
I would replace it. IF you unplug it and set it to clean it is a hazard if someone opens it. If the safety feature is working it should not self clean with the motor unplugged anyway.
Aug 29, 2014 | Kitchen Ranges
Door is locked dl error code
Plug off the mains, remove bottom panel. Reach upwards to lock area to find a chord, pull downwards gently, door opens. Check the lock for loose wire, check small push button in lock area to make sure it is not broken, check latch on door.
May 10, 2010 | Kenmore Elite 45986 Front Load Washer
Whirlpool model wtw6600sw9 If stops with code
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 20, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Code dl-f machine will not start up, usually you hear the door lock and then water enters- but door does not lock which is why im thinking dl stands for door lock? i unpluged machine hoping it would reset...
Hello.
You are correct in that the fault code stands for door lock error. Here's the book answer:
Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.
Try pressing pause/cancel several times to reset it.
Best regards, --W/D--
Aug 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
I am getting an DL F code on my front loader
"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from extending.
Machine/motor control detects open door lid switch when attempting to lock.
Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Cycle wont start then I get Error / dl
the dl code is a door lock error,open door and examine door lock assy mounted on front panel.look for a plastic push pin approx 5inches up from square lock assy.if that pin is missing,replace door lock.if pin is there,you could still have bad door lock or loose wire connected to door lock.
Sep 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
What is the routine for resetting the dl error code?
Hi mate first thing I would do is unplug the machine and turn off the water valves red and blue before you take out the drain hose get a basin and keep it with you at the same time put the hose into the basin bring the two down to the floor when the last of the water is empty you should be able to open the door if you can still not open the door take the top off the machine MAKE SURE THE MACHINE IS STILL UNPLUGED if you have a narrow arm you can feel down where the interlock is and move your fingers around the interlock until it releases the lock maybe the pump is blocked our the interlock needs to be replaced
Jul 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
Sal De
fordexpert
Whirlpool
Whirlpool
