Question about Refrigerators
CAUSING THE FRIGIDAIRE AND FREEZER NOT TO WORK
  • 1 more comment
  • jwise7j May 29, 2010
    freezer coil freezing up causing the freezer and refrigidaire not to work if i use a hair dry to he coil the fridge to work help
    freezer coil freezing up causing the freeze refrigidair not to work if i use a hair dry to defrost the coil the fridge to works for a day help
    mrs22wngw6 frigidaire freezer coil freezing up causing freezer and frigid not to work if i use a hair drier to defrost the coil the frigid and freezer works for a day
    Guru:
  • 415 Answers
Please offer a more thorough explanation of your problem and your observations and I will happy to assist you with your problem.
Also offer a make and model of your unit. :-)
Posted on May 29, 2010
  • laura Newman May 29, 2010
    I hope this is not a duplicate post. It did not appear to take my last post.
    Here is a link for Troubleshooting Refrigerator Defrost Problems. My personal experience has been problems with the defrost switch/thermostat. The defrost switch/thermostat is located on the freezer coil and will have two wires on it. I recommend marking the location of the thermostat with a piece of wire (you don't want to change the location of the switch). Take the switch with you to your local appliance parts supply house. They will provide a replacement part for you. You'll need wire nuts and electrical tape. After you wire nut the wires, wrap them well in electrical tape.
    Of course, there are two other components that can be the culprit........the defrost timer and the defrost heater. Use the troubleshooting guide to help you diagnose.
    You also want to ensure the vents in the back of your freezer are not getting blocked (my kids do that all the time and I have to constantly remind them not to). Make sure your drain is free and clear..........After thawing with a hair dryer, you should notice some water in the bottom of your refrigerator near the compressor area where it will eventually evaporate.
    Let me know if you have any questions, problems, or concerns. Good Luck! :-)
    President:
  • Refrigerators Master
  • 2,923 Answers
For most refrigerators and freezers:
If the fridge and freezer are not working because there's no power, first, you must check if the power cord is properly connected to the wall socket, or you have to make sure that the socket is working.
If there's a power on the unit, but fridge and freezer are not working, go to the back panel of the fridge and listen to it. If you hear a "hizzing" sound, then there could be a leak on one of the copper tubes, and it's out of refrigerant or freon.
If you're not hearing any hizzing sound, try to adjust the defrost thermostat. Or check if the condenser is working.
If you're not sure how to test it, it would be better to call a technician, and have him test the compressor. If there's a part or components that needs to be replace, the tech and estimate the cost, and estimation should be for free.
Thank you and good luck!
My Frigidaire commercial freezer model LFFH2067DW1 makes a loud, almost rhythmic, knocking sound. What can that mean?
Could be a compressor on its way out, a warped or clogged fan could cause similar sound issues, the valve plates in the compressor could be worn causing pressures issues.
Nov 15, 2014 | Frigidaire Freezers
Describe your FFU2124DW12 Problem The freezer works very good and gets very cold, But the outside walls and top gets EXTREMLY hot
Freezers have tubes that run inside the walls and top of the case, these carry the refrigerant thru the heat exchange process, this will cause the outsides and top of the freezer case to get warm/hot some times, this is normal, but I recommend you to make sure there is at least 1 1/2" of ventalation clearance around the entire freezer so that it can exchange heat efficiently.
If you don't think the amount of heat present at the outside of the freezer case is NORMAL, then I recommend contacting Frigidaire directly and discuss this with there customer service people.
1-(800)FRIGIDAIRE
GOOD LUCK !!
Aug 03, 2010 | Frigidaire Freezers
I have a Frigidaire refrigerato with top freezer that I keep on the back porch. The freezer has quit working completely. The temperature has been below freezing lately and I was wondering in this has...
Good day,
Yes, Frigidaire specifically states any temperature below 55 degrees will unbalance the machine causing the freezer to warm.
This is due to the fact that the thermostat that runs the entire machine is located in the fresh food section. When it reaches it's normal temperature it shuts the entire machine down.
In cold weather it could stay off for the best part of the dy, if not the entire day.
As well. on some model Frigidaire's, they makes a winterizing kit.
It is wired to the thermostat in a manner that heats the thermostat artificially in cold weather to cause it to cycle more.
Contact your local appliance parts house to see if they carry the kit for your machine.
Feb 17, 2010 | Frigidaire FRT21H8 Top Freezer...
Frigidaire top/bottom fridge is on, but not cold in either the fridge or freezer.
We bought a small used Frigidaire refrigerator-freezer on top--Freezer is cold but items in frige are not...what could cause this
Feb 09, 2010 | Frigidaire Refrigerators
Only the freezer works
could be defrost problem or fan not working or damper control
Mar 18, 2009 | Frigidaire FRT21H8 Top Freezer...
Freezer door opens
its air pressure between the wo doors that cause it to open the freezer door.take some soapy water and clean the sels aroundboth doors to see itf thet dosent help use dish soap and a little water to clean the seals with it should stop it
Jan 07, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
Sep 22, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
