Question about Weber Genesis E-310 Gas Grill
The pilot light is on but it won't flame
The grill is clean, full tank of gas, a new batter in the ignition switch the pilot ignites but there is no flame
  • 32 Answers
SOURCE: Kenmore Master Flame Grill
CHECK TO SEE IF THERE IS A SHUT- OFF VALVE IN THE LINE
Posted on Apr 08, 2008
bulldogchief
  • 388 Answers
SOURCE: Gas not getting to stove to ingnite
It sounds like you may be "vapor locking" the grill...after you are done cooking on the grill, how do you shut it off? Do you close the tank valve first then close the burner valves or do you turn off the burner valves then shut the gas off at the tank? If you turn the burners off before turning the gas off, you are creating a "vapor-lock" where air gets trapped in the line and you get the sputtering you are talking about.
Try this first, turn the gas on, then light the grill...once it is lit, turn off the gas and wait for the flame to fully extinguish then turn the burners off. Now try to light it again...if it is still sputtering, repeat the procedure above to purge the air out of the line.
If that procedure does not fix your issue after three tries, go get a new line and regulator and install then do that same procedure again. This should fix your issue once and for all.
If you experience any trouble with this, let me know here. Good Luck!
Posted on Oct 30, 2009
  • 2602 Answers
SOURCE: Low flame burning on CharmGlow 4-burner gas grill,
check burners are not bolcked check orffice is not blocked also check reg is giving right pressure
Posted on May 17, 2010
  • 494 Answers
SOURCE: I am not getting any gas from my tank to the
Make sure you didn't turn the gas tank valve on too fast. Some gas hoses have a built-in excess flow valve that stops the flow of gas to a trickle if opened too fast. Close the tank valve, disconnect it and reconnect it. Turn the tank valve on very slowly and then try lighting it again. Let me know if it solves your problem.
Posted on May 20, 2010
Testimonial: "Thanks for the info. This definitely helped."
  • 494 Answers
SOURCE: i have a charbroil commercial gas grill that won't
Hello, here is my check list for your most common gas grill lighting problems:
1) Check your tank. Is it empty or nearly empty? The tare weight (T.W.) of your cylinder is stamped on the collar. This is the weight of your empty cylinder, usually around 18 lbs. Weigh it on your bathroom scale2_bing.gif. Propane weighs 4.25 lbs/gal. If it weighs around 20 lbs or less - Refill it. If not, go to #2.
2) Make sure you didn't turn the gas tank valve on too fast. Some gas hoses have a built-in excess flow valve that stops the flow of gas to a trickle if opened too fast. Close the tank valve, disconnect it and reconnect it. Turn the tank valve back on very slowly and then try lighting it again. Make sure all your grill gas knobs are turned to off when you turn on the tank valve and that you only light 1 burner at a time. If it doesn't help, go to #3.
3) Is the igniter sparking? Some are battery2_bing.gif powered-check the battery or replace it. If you have a standard push button piezzo igniter or a rotary style2_bing.gif igniter, check for spark. Can you hear or see the spark? It's hard to see the spark in bright daylight. It's easier to view the spark at dusk or dawn. It should spark an "arc" at the burner. If not, adjust it if necessary. The igniter wire may have a short, causing the spark to arc somewhere else along the wire and not at the burner. Replace igniter wire. It's also possible the igniter tip where it sparks has a cracked or broken porcelain portion of the igniter, causing the spark to not arc at the tip where it's supposed to. Replace the igniter piece. If not, go to #4.
4) You may have a rusted, clogged or damaged burner or venturi tube. With a flashlight, check for spider webs, wasp nests or dirt (mud) dauber nests in the opening of the venturi tube where it connects at each gas valve orifice. Clean it out manually or blow it out with air compressor. Make sure the air adjustment opening (on the end of the burner's venturi tube) has not been changed. If it's closed too much, it will be difficult to light and cause lazy yellow flames. If it's not clogged, the burner may just be old and rusted and the burner holes are not allowing very much gas through anymore. It's also possible the burner has rusted so bad, the burner holes have been enlarged, it is falling apart or has cracks along the burner seams. If so, replace the burner(s) immediately. It is unsafe to use. Your local propane co can usually order the parts you need and some will even do the work, if you are uncomfortable doing it yourself. Bring with you the Make, Model and Serial number of the grill, so they can order the correct parts for your specific grill. Also specify whether it's natural gas2_bing.gif or propane.
5) If none of these resolve the issues you are having, it is also possible you have a faulty or defective regulator, which may mean replacement. If the pressure still seems too low and none of the above has helped, and you have a silver/gray regulator; many have an adjustment screw on the top center of the diaphragm. Remove the outer cap and turn the inside screw clockwise in 1/4 turns to increase the pressure until the desired flame size is accomplished. Flames should be as blue as possible, but will burn orange if there is food or drippings on it. Yellow flames are not good, and will soot up everything and not cook as hot as blue flames do. Yellow flames could mean you do not have the right air shutter adjustment, clogged burners, or possibly defective burners, as mentioned above in #4.
6) Also make sure you have the hose connection tightened snugly to the propane tank valve to ensure the inner valve seat is fully depressed allowing gas to exit fully without any restriction. The black plastic female fitting should be hand tightened only. Older versions that use a left-hand male brass POL valve, requires a 7/8 open end wrench or adjustable wrench to tighten.
Hope this helps! Good luck in your trouble shooting! Douglas
Posted on Jun 08, 2010
Why won't the burners light even when I smell gas and hear igniter clicking?
Bill, two things possibly going on here that are common with an aging grill. First you need to turn off the fuel tank and set it aside. you mention that a clicking can be heard when pushing the igniter button which usually indicates good battery but if you have never changed it you may want to just as a good measure. Unscrew the bottom and you should find AA or AAA battery behind it. Now with battery good and the igniter generating a fast load clicking sound you want to get down and follow the wire that runs from the the back side of the igniter push button down inside and usually under the burner tubes ending out at one end of each burner. What happens when you press the igniter switch is, an electrical current is sent down the wire and when it reaches the end the current jumps to the closest metal it can find creating a spark.so you need to insure that the end of the wire is close to where the flame is generated but not so close that that you cant see a spark. Make sure the end of the wire is bare and clean as is the area on the burner where it arcs Now do this to all for burners. Turn all the knobs on the grill off and connect the tank. Make sure the lid is open now, and slowly open the valve on the tank. I say slowly like a ten count from close to full open. what can happen if you crank the tank valve open too quickly or with the grills valves open a vapor-lock effect can be created greatly reducing the flow of fuel from the tank. Iv'e seen many of the uninformed return 1/2 full tanks due to this problem. If you notice week flame or no flame but smell gas ALWAYS SHUT OFF VALVE ON TANK IMMEDIATELY KEEP LID OPEN AND LET THE AREA VENT BEFORE TRYING AGAIN lest you be the one being barbecued. Good Luck
Apr 27, 2014 | Kenmore 16225 Grill
Full tank, igniter clicks, i hear the flam come on but it wont light. What to do?
I am not sure which flame you hear light. The pilot light flame or the burner flame? In any event, the burner and the pilot assembly need to be cleaned. Insects love to build nest in these types of heaters, when they're not in use. When that happens, the pilot and/or the burner get's clogged.
A shop vac with a hose and brush attachment work well in cleaning the heater parts. Canned compressed air with a straw nozzle (like you clean your computer with) does well in blowing out the pilot tip and around the entire pilot assembly.
Be sure to turn the gas tank valve OFF and disconnect the hose and remove the tank, before attempting to clean the unit. When you replace the tank and reconnect the hose, be sure to open the gas tank valve VERY, VERY SLOWLY (Slow motion slow).
Hope this helps you solve the problem. Thanks for choosing FixYa.
Sep 21, 2011 | Endless Summer 200209 Open Flame Patio...
I have not used my endless summer patio heater since last fall. I bought a new tank of propaned, cleaned out the cobwebs checked all connections and tried to light up the heater. It does not work. I can...
Mike, the problem started when you turned the new tank ON. But, it is correctable most of the time.
Turn the LP tank valve OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Open the gas valve VERY, VERY, SLOWLY (Slow motion, slow). Once the tank valve is fully open, light the pilot and hold the gas control valve in for 30 seconds to 1 minute. Release the control valve and turn it to the ON position. Did the burner light and does the flame height look correct? If so, you solved the problem. Just remember to always turn the tank valve on Very, Very Slowly.
If the above didn't solve the problem, you will need to replace the heater's Hose/Regulator Assembly. A gas Grill's Hose Regulator Assembly should work and you can purchase one from any hardware store of home center that sells grills & accessories for about $30.00. Take your old one with you for comparison purposes.
Hope this helped you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Sep 18, 2011 | Endless Summer Heating & Cooling
My uniflame has two burners and one does not ignite. Everything seems to be tight. What can I do to get this to ignite when turning ignition knob? Thanks!
When you say two burners, I believe you are referring to the pilot flame and the main burner. The pilot flame has to light and heat the thermocouple befoe the main burner will ignite. The pilot flame will not light if: there is not enough gas in the tank, the pilot jet is clogged, or the regulator is bad. Check the tank to make sure it has gas. The next thing to check is the pilot jet. You have to take the heater apart, somewhat, to get to the pilot jet. The tube and the orifice need to be cleaned out, compressed air in a can and a pipe cleaner make the job a little easier. If this does not work, replace the reglator and hose.
Jul 22, 2011 | Uniflame GWT501A Open Flame Patio Heater
When I try to light my brand new Q300, it won't ignite. I can hear that the tank is on and gas is being sent to the grill. However, it doesn't light. When I shut the grill off and the gas tank...
What you have is delayed ignition. It's being caused by the gas regulator. It is solvable, though.
Turn the gas tank valve OFF and disconnect the hose from the tank.
Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
Once the valve is fully open, light 1 burner and turn it to HIGH. Did the burner light and does th eflame height look correct? If so, light the remaining burner the identical same way. Now, to both flame heights look correct? If so, you solved the problem. Remember to always open the tank valve Very, Very Slowly. And always light the burners with the Lid/Hood Open.
If the above did not solve the problem, you will need to replace the Hose/Regulator Assembly. Since your grill is brand new, the Hose/Regulator Assembly will be covered under Warranty. Have your Proof of Purchase handy and call Weber 1-800-446-1071. Also, if you haven't done so already, register your grill before calling http://help.weber.com/register/ even if you don't need a new Hose/Regulator Assembly.
Hope this helped you troubleshoot & solve the problem.
Jul 06, 2011 | Weber Q300 Grill
New petit grill will not ignite
If it won't ignite, because gas is not getting to the burners. Turn the gas tank OFF and remove it from it's holder. Wait 5 minutes and reinstall the tank. Turn the tank valve ON VERY, VERY SLOWLY (Slow Motion, slow). Once the valve is fully open, try lighting the burner(s) again and turn them to their highest setting. If the burner(s) light and the flame height looks normal, you solved the problem..
Hope this helped you solve the problem. Please let me know. Thanks and Happy Grilling!!
May 17, 2011 | Cuisinart Grilling
Coleman heater model 5445c700 propane camp heater wont light. It did work fine. When I hold the knob in the light position you can hear gas but it barely ignites then goes out. I've tried new gas and...
If you're using a 20lb propane tank (Gas Grill Tank), that may be the problem. Turn off the propane tank at the tank valve and disconnect it from the tank. Wait 5 minutes and reattach the heater hose to the tank. Turn the propane tank valve on very,very slowly until it's all the way open. Try lighting your heater now. If the pilot flame height returned to normal, that was the problem.
FYI - The Thermocouple has nothing to do with the length of the pilot flame. It's a safety feature that stops the gas if the pilot flame goes out for any reason.
Hope that solves your problem. Please let me know.
Rich
Feb 07, 2011 | Coleman Heating & Cooling
Charmglow gas patio heater
Your thermocoupler seems at fault. The thermocoupler is that probe that sits in the pilot flame. It controls the main fuel valve. Make sure that probe is in the pilot flame, better at the tip of the flame and hold the button down for a minute or so after lighting the pilot. If pilot extinguishes, the coupler is faulty. If pilot stays on the heater should fire up when you let up on the pilot button.. Good luck
May 30, 2009 | Coleman (5040B750) Patio Heater
OVEN WON'T STAY LITE MOST OF TIME & DOESN'T HEAT WELL:
Most problems with gas ranges have to do with the flame—either it isn't quite right or it's nonexistent. Many new gas ranges have "electronic ignition," a spark igniter that starts the flame as gas flows through the burners f, when you turn on a burner, it fails to spark but you hear sparking at other burners, the igniter or the burner switch probably needs replacement by an appliance repairperson. If your range has a pilot light, be sure the pilot light is lit.
have nice time..!! arte the solution!!
Apr 17, 2009 | DCS 24-24G-1 Gas Kitchen Range
My charmglow heater is a yeAr old and the pilot will ignite and stay lit for ever,but when you let up on it it goes out! What cam I do?
Mar 16, 2008 | Coleman (5040B750) Patio Heater
Weber Genesis E-310 Gas Grill Logo
49 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
