Question about B&K AVR-307 Receiver
Making a loud buzzing noise coming from the receiver AVR307 not through the speakers??
  • rhecht May 29, 2010
    So how do you look for the fault inside the receiver? Anything noticeable?
  • B&K Master
  • 11,800 Answers
 Either some shielding baffles are loose and are vibrating or the transformer itself is generating too much sound . This happens when the power extracted thru it exceeds its capacity - there's a fault/short somewhere in the electronics. You will gonna have to open it and check for the fault.
Posted on May 29, 2010
Testimonial: "I will check it out and see if I can figure it out. Thanks for your help..."
  • 3 more comments
  • Azrael SRL May 29, 2010
    First of look for deformed capacitor or something that has a darkened color - signs of overheating. If you find some try to replace the damaged parts.
    Next put a pair of rubber gloves (some thicker ones) and start touching components to feel the ones that vibrates the most - if it's a baffle look at its fixings, they are probably loose; if it's the transformer then it's overstressed, you will have to test the voltages to identify witch part takes more power than it should (the voltage of the line powering that part will be lower than normal) then fix it.
  • Nessy Oct 13, 2011
    Did you fix it? I have the same problem.
  • connie Oct 16, 2012
    I have the same problem too
    Can anyone remcommend any place to fix this problem? I am not handy to fix it myself, I did open the box, and find a bad caps, but the posistion of the buzzing sound come from the speaker input side, not the transformer. I am confused.
  • Azrael SRL Oct 16, 2012
    When the cap is damaged it's no longer performing its duties - to filter the current. Because of that thecurrent that goes to the amplifier, and from there to the speakers, is full of ripples from the mains = hence the buzzing. All capacitors (not just the visibly dead one) must be replaced. It's a simple job that can't be too expensive - any person with basic soldering skills can do it.
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
10 years and first problem to repair. When you turn on and select DVD or any other selection a very loud cracking noise comes through right speaker only. So loud (with volume tuned off too) that I fear...
I think your receiver is damaged.
Try this.
Mark the speaker wires on the back of the receiver. label the speaker connected to the left channel "Left" and the speaker connected the the right channel "Right"
Also pay attention to the polarity (positive an negative) making some type of marking on your speaker wire so you can reconnect them correctly.
Disconnect both left and right speakers.
Connect the speaker wire that is labeled "Right" to the receiver's left speaker connections only then turn your receiver on.
IF the loud noise comes back, this speaker is damaged. I am guessing that the speaker is fine.
Now connect the speaker that was labeled "Left" to the receiver's right speaker connections and turn the receiver on.
IF the loud noise comes back like it did before but now playing through the "good" speaker there is a problem with your receiver.
If so, your receiver is 10 years old. Isn't it time for an upgrade? Try ebay for good used equipment deals.
May 01, 2014 | Onkyo TX-DS787 Receiver
Samsung 4663w rear projection tv loud buzzing
Hai,
Buzzing can be caused by a bad ballast, colorwheel, or cooling fan... Nothing else makes a noise, unless it's comming from you speaker.
Hope it Helped U!
Aug 04, 2009 | Samsung Televison & Video
Alot of loud feedback through speakers, a loud buzzing noise
What sources make it happen or which do not? All buzzing = something in the amplifier end. is it from all speakers or just one?
One external source= RCA cables not grounded. Reconnect them tightly with a twisting motion to wipe off oxidation.
Apr 10, 2009 | Onkyo TX-SR606 Receiver
A couple of weeks after initial setup of my brand new Onkyo XT-SR606 receiver, I noticed a loud buzzing noise that starts up approximately 10 min after the receiver is turned on. The buzzing is definitely...
The "buzz" you hear is a power hum made by the power supply transformer. It's technically called "Lamination hum" caused by the revering of electrical current through the power supply transformer. In some cases the hum can vibrate the chassis causing other loose material to vibrate. If you can, go to your dealer and check to see if other units of this same type typically make a hum this loud, and if not, see if he can solve the problem for you.
Feb 27, 2009 | Onkyo TX-SR606 Receiver
Loud buzzing at the first volume setting
Check all your wires and make sure that none of the wires that are powering any equipment (including extension cords, power bars, and power cables on the unit itself) are running parallel to any of the audio cables going to your speakers or from your inputs to your unit. This could be what's called AC hum, which is caused when the electrical current causes interference that gets picked up by the audio cables and amplified by your system. Just make sure you move the power cords as far away as possible from the audio cables.
Jan 08, 2009 | Sony STR-DE345 Receiver
Speakers Make a Very Loud Noise that Increases
try uninstalling drivers and reinstall them.
also remove latest M.S update as some update cause more trouble than they are worth
May 21, 2008 | Audio Players & Recorders
Distortion/noise and buzz in front left speaker
Try to see if the reciever will make the buzzing/noise without anything connected to it except power, and speakers. Tune into a local radio station and see if the noise continues. If the noise has stopped, then you know there is an issue with the player or cable.
Dec 28, 2007 | Onkyo TX-SR503 Receiver
Speakers making loud buzzing noise
From your alternator, Make sure none of your RCA's are near a power wire, check your grounds as well.
Jan 09, 2007 | Pioneer TS-D690R Coaxial Car Speaker
B&K AVR-307 Receiver Logo
698 people viewed this question
Top B&K Audio Players & Recorders Experts
shaun taylor
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a B&K Audio Player and Recorder Expert? Answer questions, earn points and help others
