Since the anologue signal was lost i canot retune my goodmans 22'' to pick up any digital channels. It seems to search for them on a blank blue screen then comes up with check aerial. Any help would be appreciated
    Novelist:
  • 144 Answers
When the change was made from Analog to Digital was finally made it made all Analog Televisions obsolete none of them can receive a digital signal. You can get a converter box that you attach your antenna to and the output of that box hooks where your antenna used to go into your TV. With a converter box the box will receive a Digital signal, process it and present it to your Television in an analog form (what previously would be off standard broadcast). That is your only hope of continuing to use your older Television.
Zashiban
Posted on May 30, 2010
When I retune my tv stations how do I get them them in order. Ie BBC1 =no1 BBC 2 = no 2. Other tvs seem to do this automatically ?
There should be an option on the menu screen for the TV or if you are using one of this digital converter boxes, it will be on that menu. Look in the menu and under Channel and you should see add/delete or move option.
However, as you mentioned, usually when you run an auto-scan it is supposed to pick up what your antenna picks up and put them in order. It's especially annoying when it picks up a channel and its blank or no signal. The menu were created so you can delete those unwanted channels. Hope this helps.
Mar 15, 2015 | Televison & Video
I have a goodmans anologue tv in my bedroom I've
Refer its service manual and make a factory reset to it. To downlaod the service manual, google it with its brand name. I don't think there will ba a free download site for this brand TV. All download sites will be paid.
Apr 27, 2012 | Televison & Video
Lost BBC1 BBC2 digital after switchover
You might have more than one transmitter. Some TV's etc only store a certain number of channels and have a max amount!. When weaker transmitters are present sometimes the memory of the TV will only store the stronger signals first from these weaker sites, with the two BBC channels being too weak to be detected.
The solution is to do a manual search on the transmitters you know are very strong. For example if channel 43 has strong signal you would search on that. The auto search will start at 21 and work it's way to 69. But if your area transmitter with the strongest signals is high up the scale the weaker transmitters will be selected first!
Apr 09, 2012 | Electronics - Others
User guide for a technika sc 500172
hi i have a technika tv but when i tune it in i dont know how to lock them in
Dec 28, 2010 | Televison & Video
Problem with digital tv
The Antenna may be in a weak signal area heres a quick cheap fix
Get a Freeview Box and connect it via SCART LEAD to your tv, if the Box picks up a good signal then your tuner may be very weak..
You may want to try a BOOSTER to the TV first, and if that fails go with an external freeview. My neighbor has a 42 and the freeview box WITHOUT an antenna attached resolves all the channels..so give that a try. I have a goodmans too with a slow tuner and I have to retune it sometimes even though it gets a good signal from the antenna. I will be getting an external tuner freeveiw box.
Apr 15, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
Retune process stalls
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Oct 01, 2009 | Goodmans W280NS Television
Samsung digital retuning for 30 September 2009
Press D.Menu on the remote not Menu! Then select 'Channel' and then select 'Auto Store'/
Sep 30, 2009 | Samsung LE37S71 37 in. HD-Ready LCD TV
Lost BBC channels on my SAGEM PVR6200T during a retune
Jul 06, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
Digital channels have stopped working, only blue screen!
Try resetting the TV:
  1. Switch on TV and switch to any analogue channel.
  2. On the TV: Press and hold the MENU button.
  3. Menu screen will appear on the display.
  4. Do not release the MENU until the menu screen disappears.
  5. TV will go blank for about 60 seconds and then display initial set up screen.
  6. Follow the on-screen prompts to re-tune the TV.
If this does not work then the problem is likely to be a loose ribbon cable or main small signals board inside the TV.
May 17, 2009 | Philips 37PFL5332D 37 in. LCD Television
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Electro Med Services...
