Question about Envision H170L Monitor
Display probs My monitor display goes hazy or out of focus ( can hardly make out what is on the screen) after a few minutes of being on then it fixes itself and does it all over..That keeps happening the entire time am using it.Help pls
    Brigadier General:
  • 10,406 Answers
Try the monitor on another computer; if it works fine, then the video-card on your computer is the problem.
If it does not work, then it's time to buy a replacement LCD monitor.
Posted on May 29, 2010
My lcd is hpl1908w its display goes of 5 minutes on first starup and when its displays goes off i on and off the monitor display comes for fews seconds and then goes off again lcd light is green but...
well if your lcd has no bulge capacitors test your tft lamp both top & down of the screen( particularly top) with spare tft lamp. or use another screen to test it. secondly, test the c5607 transistors in the inverter section but if you know how to use spare tft lamp very well , you will easily detect between your screen & the inverter
Aug 06, 2015 | HP L1908W 19" LCD Monitor
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
Nokia n95 dark hazy negative like display on & off after pressed
your phone need a general service. please contact service technician
Sep 22, 2009 | Nokia N95 Cellular Phone
My Acer 22" AL2223W monitor display goes black after a few seconds, How can i fix it my self?
try hooking it up to another computer to ensure
it is not the graphics card that makes trouble...
if still the same prob, check the net if there are
known overheating problems for that model,
i personally recommend to see a technician, as repairing a monitor could make things worse...
up to u, good luck then
Sep 01, 2009 | Computers & Internet
Mw22u monitor has white screen.
Manufacturer out of business. Local repair shops want more $ to fix than the cost of a new one.
Solution --- Trash old and replace with new display.
Mar 25, 2009 | X2Gen MW22U Monitor
When switched ON, my Compaq Presario Desktop PC, a very bright and sharp blue line appears on the screen of monitor for few seconds and then goes of. Further no display. CPU led are ok. bip sounds normal....
sounds like a new monitor is in order or try another one and adjust the display settings in case the monitor cant handle what you have it set at, but i suspect its a new monitor
Dec 19, 2008 | Computers & Internet
IBM MONITOR ON SCREEN DISPLAY
This is a problem in the monitor itself. The computer has absolutely no control over the On Screen Display. Most likely the button that controls contrast is stuck. You might try blasting the button with canned air. Sounds like it might be time to buy a new or used monitor.
Jul 31, 2007 | Samsung SyncMaster 551 15" CRT Monitor
My samtron 55 monitor becomes hazy and out of focus
Focus and brightness (sometimes called screen control) are usually adjusted in the flyback transformer. Check for a bad connection where the flyback is soldered to the board. This could also indicate a problem with the CRT.
Sep 06, 2006 | SAMTRON 55V 15" CRT Monitor
Envision H170L Monitor Logo
108 people viewed this question
Top Envision Computers & Internet Experts
Cleverer2
Steve
Martin Murray
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
