Question about Pentair 3hp Whisperflo Pool Pump In - Ground
Wirng connecions for 110v pentair pool motor???
    Guru:
  • 351 Answers
There shopuld be a diagram on the nameplate of the motor, or on the cover for the wiring compartment, or there is some stamped indication at the wiring lugs that tell you where to put your feed and what position the internal wires are to be in or the jumper .. for 110 volts or 220 volts.
Posted on Jun 01, 2010
    Scholar:
  • 78 Answers
Next, as a suggestion. Purchase an Emerson Pool motor. The electrical connection is the same for 110/220 volts. All you have to do is move the switch by the electrical connections and select 110 or 220 volts. They usually come preset on 220 but I would check anyway. Also, don't forget the ground wire (green) and also connecting the bonding wire on the outside of the motor near the plastic cover for wiring. If you don't have bonding I would get it real soon! Hope this helps..
Posted on Jun 06, 2010
Pentair Intelliflo vs. Need bearing replacement for front and back bearings
Pentair WhisperFlo Pool Pump Motor Bearings Replaced ...
? 2:03
www.youtube.com/watch?v=qYRNMCh_7kM
Jul 10, 2012 - Uploaded by Pump Repair Supply
More Help & Information: https://pumprepairsupply.com Watch as Joseph shows you how quite your Pentair
Sep 27, 2015 | Pool & Spa
Low voltage and hi voltage is just 220 and 110 can i still make the pump have two speeds
The 220v / 110v are the two wiring options on that motor. They usually come pre- wired for 220. The wiring can be changed to where it will run on 110. Be sure to get it right. if you wire a 110v motor to 220v it will go bang and die.
A two speed motor will have two hot wires, one common, and one ground (4 wires). Single speed will have three wires. You can't make a single speed motor a two speed motor.
Mar 01, 2015 | Pentair Pool & Spa
What is the difference between 115volts and 230volts pumps?
Effectively, not much, although 220 v is preferred for pool pumps over 1.5 HP (it's a bit more efficient). The smaller pumps may be able to run on 220v or 110v. There should be a wiring diagram on the side of the motor giving details.
Dec 18, 2013 | Pentair Pool & Spa
What prongs do I use in a hayward supr. Pump for the input pwr. For 110v?
check side of motor move the brown wire then move the white wire to F2 black wire goes on F1 and white wire goes on F2 with other white wire green goes to the case
Aug 16, 2013 | Pentair Pool & Spa
New pump motor smoking 1 minute into running
see side of motor make sure brown on correct lead and white also
Sep 24, 2017 | Pentair Whisperflo 1 1/2 Hp Pool Pump...
Wiring 110v on wf-28
see side of motor for diagram you have to move wires or turn a switch to 120 volt then wire double check before turning on
Mar 15, 2012 | Pentair Whisperflo 2 Hp Ur Pool Pump Wf28...
Does the pump come with the wiring set up for high voltage? I am referring to the brown and white internal wires. Pentair Challenger 346206. thank you
If you look at the wiring diagram on the motor plate it will show you where these wires go for 220v power, and where they go for 110v Power. If you know the supply voltage just place these wires as shown on the diagram and you should be fine.
Sep 17, 2011 | Pentair Challenger High Pressure Pool Pump...
Pool pump does not start
Well, this could be caused by several different problems. The first step would be to make sure the breakers are not in a half-trip condition in the breaker panel. You should turn the breakers off and snap them back on. If the breakers are OK, you need to check and see if you have the proper voltage coming into and out of the time clock. Some pumps run on 110v and some on 220v. The proper voltage can usually be determined by the type breakers. Single Pole is 110v, Double Pole would be 220v. You would need a meter to test the voltage at the time clock. If you have the proper voltage, you next need to make sure the shaft is spinning freely by trying to turn the impeller with your finger. If this is free, you may have a blown start capacitor on the motor itself. Hope this helps.
Jul 19, 2011 | Pentair Superflo 1 Hp In Ground Pool Pump
Ghart106 asked:
There is a wire diagram on the inside or outside of the motor housing. There is a simple wiring switch that you can do to change the motor from 110 to 220 or vice-versa. Everything you need to know is on the motor.
www.cpo2go.com
Sep 06, 2009 | Pentair 1.0 Hp Whisperflo Pump
Pentair 3hp Whisperflo Pool Pump In - Ground Logo
1,049 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
