Need to reset clock. - Audio Players & Recorders
    President:
  • 2,923 Answers
You need to reset the clock? Is that a receiver? What is the brand and model number of it?
Kindly provide me the information, so that I could check it out.
Thank you and good luck!
Posted on May 29, 2010
How do I reset time and date on SioScan Atomic Clock? I need Arizona time zone - i.e. no daylight savings time
Put it into settings and then adjust time/date. It's not related in any way to temperature.
Apr 24, 2015 | Home
I have a Coaster Grandfather Clock. I lost the manual. I need to find out how to reset the chimes.
Hi Wanda....call Coaster Furniture national call center -
1 877 221 9666. They can tell you how to reset the
chimes. Ask them for a manual.
Regards,
Dennis
Oct 21, 2014 | Coaster Furniture Large Traditional...
My stove panel went blank.
You will need to replace the clock/timer on the unit. Here is that part to order.
Frigidaire 316557114 Clock timer AppliancePartsPros com
Mar 22, 2014 | Kitchen Ranges
Chimes do not work
Check for loose wires between the clock Movement and the chime box. If those are good (and the batteries have good solid connection-not lose) you probably need to replace the chime control box or the whole movement.
Timesavers.com carries replacements.
Mechanical clocks, while more in cost, will live a much longer life with proper care than battery clocks. Plus, an actual chime (not noise through a speaker) is much more pleasing to the ears.
Jan 11, 2014 | Seiko Mantel Clock
Clock reset code ford focus 2000
There are many different clocks installed in vehicles depending upon the options listed. Check your owners manual for directions. One common error people make is trying to set the clock when it is on. It should be off when you use the set feature.
Jan 18, 2013 | 2000 Ford Focus
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
How do i reset clock for the taylor clock timer 5851-21?
my Taylor 5851-21 has Hour Min Then under thatt Timer/Reset abd Start/Stop. How do I set the time. I know how to work the timer and reset the timer, but I need to set the clock. But it does not have a clock button label as you describe above.
Nov 20, 2009 | Taylor Hardware & Accessories
Easy one...93 Lincoln...need to know how to set the clock on the radio/cassette as well as the stations. Thanks in advance!
assuming this is the digital clock, you hit the clock button on the dash, followed by the reset button followed by the clock button. at this point, you should be able to hit the clock button to advance numbers, and the reset button to change the numbers you are setting. if its the analog clock, pull on the knob and turn it
Nov 01, 2009 | 1993 Lincoln Town Car
Need help changing the time on my clock
hi from uk to reset clock ? there are two buttons/stalks? on the speedometer clock the left one is for trip reset and the right one is for clock reset/alter time to alter twist left for hrs reset and right for minutes it springs back to neutral when you let go hope this helps ?
Jan 27, 2009 | 1999 Hyundai Accent
Needles flying around the clock
I have a mantle clock version and to set the clock to recognize the radio signal, I need to hold down both the ET and PT time zone buttons for a few seconds. The clock hands will then continue to move until they reset themselves to the correct time.
Nov 03, 2007 | La Crosse Radio Controlled Atomic Clock
16 people viewed this question
 Grubhead
Grubhead
