Watching tv and it turn off
My tv shut off by itself what can i do ....it make a little noise before it shut off
My TV started turning on and off by itself and has become more frequent with time to the point where it is a constant. It will turn off and come right back on, but when it does, it changes to channel 3. If I manually turn it off and then back on, it will return to the proper channel it was on before I shut it off.  There seems to be a large "static" noise just before it does it's thing.  Any Ideas?
  • BoognishDG Apr 08, 2008
    Thanks for getting back to me Dan..The make and model number is as follows:  27" Phillips/Magnavox (flat screen) model number: 27RF505125.
    As far as the other question you had, it gets increasingly worse as it remains on.  Used to happen once or twice after being on for hours. Now, it starts in less than 5 minutes after it has been on.
     Thanks again for your time,
     Daniel G
  • 4,234 Answers
Please update this with a make and model number. WIthout that information there is little assistance I can provide. Also, does this occur all the time or only after the set has been on for a while?
Thanks,
Dan
Posted on Apr 08, 2008
  • ABRsvcs Apr 08, 2008
    Lets start with the simple stuff. This sounds like it could be just a bad connection on the board. If you have any soldering experience, open up the set and resolder any connection that looks grainy or has rings. Report back here with your findings. In the meantime, I'll lopk up your model to see if there are any common parts failures that would account for this. (I know some, but certain models are prone to some problems.)
    Dan
Just shut off and now no power going to it., unplugged and try powering it up with button on tv not remote and still nothing.
TV Appears To Turn Off By Itself
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 12, 2013 - There are four cases in which your TV either turns itself off or appears ... If you are using the TV as a monitor and the Stand-by light only blinks ...
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I just watch your video my tv won't stay on it keeps turning off I have a ... My Samsung 55" Smart tv suddenly turned off and won't come back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Samsung PN64 just started randomly shutting off and on usually with ...
Samsung Smart TV turning off - Forums - CNET
Jan 05, 2016 | Televison & Video
Did my tv just blow up?
Yes, I think you have lost the bulb and maybe the color wheel is on the way out too. But try a bulb first. If the old one has a broken "glass tube" in the center--be assured it is bad.
Oct 10, 2009 | Samsung Televison & Video
Samsung hls5086wx/xaa turns off at random
Go to website Encompass Electronics.com type in your model number it will list part and part number ,you can also look for Lamp on E-Bay Encompass 1-800-638-3328 Also ck Color Wheel remove lamp take a flash light to watch when you turn TV on see if the color wheel is turning if it is defective set will shut OFF. But most likely its your Lamp.
Oct 05, 2009 | Televison & Video
When turning on the TV, I hear a banging/grinding sound.
If you hear a grinding,whirling,spining or buzzing sound, that sounds to me like the COLOR WHEEL,the reason for that is because your color wheel spins at 5,000 rpms(revolution per minute) and something that modifies the balance of the disc can cause different things,Unfortionatelly the only way to check that the color wheel is working properlyis you need to check it out physically
I did some research and I found the color wheel at DM;http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm?CLICK=52978
Please keep us posted.
Jun 14, 2009 | Samsung HL-S5087W DLP TV
Shuts off by itself, then makes weird noise in back of TV
have a tech check your flyback conection in side the set some times thay come loos during shipment.
regards
daniel.
Jan 05, 2009 | Sony KV-32S42 32" TV
Turns off by itself!!!
The flyback transformer are damaged .
May 26, 2008 | RCA TruFlat 27F520T 27" TV
Rca tv
I had this happen to mine and I had to have the high voltage transformer replaced. I took it all apart my self to save money and it only cost me about $285
Jan 14, 2008 | RCA P52926 52" Rear Projection Television
My RCA TV turned itself off and started making chirping noise
You have poor solder connections these sets are famous for this! Solder Flyback transfomer pinns this should fix it.
Oct 07, 2007 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
127 people viewed this question
Top Televison & Video Experts
