Question about GE Profile Harmony DPGT750EC Electric Dryer
Runs but no heat
GE profile electric dryer model DPGT750EC1PL runs but no heat.
  • GE Master
  • 43,501 Answers
Hi, If you have a gas dryerruns but no heat - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is ..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
Posted on May 29, 2010
2 Suggested Answers
garing
  • 998 Answers
SOURCE: DescrI have a GE profile harmony electric dryer
you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor.
PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
Posted on Aug 07, 2009
GE profile dryer,Runs fine but no heat
need to have the heat element checked with a multimeter and visually if u can and look for burns and corrosion and breaking of the wire connections. Also have the thermostats checked, Im assuming its electric and not gas? the thermal cut off may be bad and the hi-lo thermostat, these can shut heat off from the dryer. Ive replaced the element on my G.E profile and it wasn't all that hard rather simple.
Sep 13, 2014 | GE Profile Gas Dryer Model Dpsb513gb0ww
Ge profile dryer does not heat at times
Sounds like one of two things.
1) you have a bad connection, specifically, a loose connection that is making contact once in a while.
2) one of the "overheat thermostat switches" is failing.
If you wish to fix it yourself, you will need to dismantle the machine and have a testing instrument to look for the problems.
Be advised, however, if you take it all apart and it happens to be on a "I will be working now, thank you very much" cycle, you may not find anything!
It really needs to be "not working" for the flaw to show up.
Be blessed.
Feb 22, 2013 | GE Profile Harmony DPGT750EC Electric...
My ge dryer model dpgt750ec1pl is running but no heat i was wondering if this style dryer is suppose to show some fault codes i thought it was the heat assembly but since itsnot showing any codes i thought...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101./
Apr 25, 2011 | GE Profile Harmony DPGT750EC Electric...
GE profile harmony dryer electric won't heat after first load
Did you end up replacing this thermistor? If so did that solve the problem? We are having the same issue and I don't want to waste time and $$.
Dec 22, 2009 | GE Profile Harmony DPGT750EC Electric...
DescrI have a GE profile harmony electric dryer model #dpgt750ec1pl. About 5 minutes into a drying cycle the blower shuts down. There is still heat but no air coming out of the dryer duct. Any suggestions?...
Aug 07, 2009 | GE Profile Harmony DPGT750EC Electric...
OUR G.E. PROFILE DRYER MOD.# DPGT750EC1PL STARTS AND RUNS LIKE NORMAL, BUT THE BLOWER DOES'NT BLOW. WHAT DO WE NEED TO LOOK FOR SO WE CAN GET THIS DRYER RUNNING? THANKS.
The fan motor must be tested by energizing it and reading volts from timer control. If the fan is faulty it must be replaced, if there is no volts from timer control, then either wiring harness or timer control assembly must be replaced.
Jul 04, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Harmony electric dryer model DPGT750EC1PL- very little heat - small rattle - takes hours to dry load of laundry... any ideas?
Check the following to address this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 06, 2009 | GE Profile Harmony DPGT750EC Electric...
Ge harmony dryer not heating up dpgt750ec1pl
If you hear the blower ramp up when you start the dryer and if slowly ramps down or quits all together then you need to replace the blower. If the dryer heats at all then look at the blower.
Jun 20, 2008 | GE Profile Harmony DPGT750EC Electric...
First use the dryers service mode and see what trouble code you are receiving.
It's called "Field Service Mode"
1. Press the POWER key to turn the dryer on.
2. Press HELP. The main help screen is displayed.
3. Press and hold MY CYCLES and BACK simultaneously for 3 seconds. Press EXIT to return to the HOME screen.
There's a 95% chance that it is your blower and your dryer should confirm that.
I just recently replaced the blower in my GE Profile Harmony as well. While I had my dryer apart, I also cleaned the heck out of it. Excellent opportunity to take your vaccum cleaner and get all of those dust bunnies out!
I purchased the blower from www.applicancepartpros.com for about $146 S&H included.
Part No. AP3791484 Item: Motor asm-blower Price $133.05 Plus Shipping.
Mar 12, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer Logo
1,065 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
