Question about GE GSS20IEP Side by Side Refrigerator
Drinking water from refrigerator stopped dispensing immediately
Pulled refrigerator out and no crimped lines or water leakage anywhere
still continues to make ice, no problem there
  • GE Master
  • 1,606 Answers
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , turn on the dispensor light for several hours , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE also has a dispensor heater , pt # WR49X10173 which comes with instructions , to keep this from happening again .
Posted on May 29, 2010
Testimonial: "Determined that it wasn't the water line freezing up so my husband is next going to check/replace the valve if needed. If this doesn't resolve the problem, not sure what the next step is to correct the problem?! Thank you very much for this information!"
Frigidaire refrigeratyor ice maker doesn't get watyer
either your filter was put on in the wrong direction or when u replaced there were stuff in the line and it stopped up the hose or your have a crimp in the line
Dec 23, 2015 | Frigidaire FFHS2611LB Side By Side...
Water dispenser not working ice maker okay water line to valves okay appears line in door frozen
GE has a fix for frozen water line in freezer door. WR49x10173 is a heater kit that is installed in the dispenser area. It uses a minor amount of energy, but enough to keep the area warm. You have to pull off the dispenser board, remove the 4 screws to remove the dispenser cradle and unplug the wiring. Then follow instructions to crimp on the heater wires. Allow about 3 days for frozen water line to defrost. .
Jul 15, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
The refrigerator water dispenser started running without pushing the device. It won't stop unless the freezer door is open. We were just sitting in the family room and all of a sudden the dispenser...
Pull the fridge out and look behind it. You're looking for the water line that could possibly have valve shutoff. If not, follow the line back to the source. Could be tapped under the sink, could go anywhere. You are attempting to shut off water to the fridge without shutting water off to entire home. Worst case scenario is if you can't locate the fridge shutoff and you can't get it fixed today and you don't want to leave the freezer door open, locate the main water shutoff for the house and shut it off over night. Hope this helps.
Jan 26, 2011 | GE Monogram Side by Side Refrigerator
The water dispenser is really slow coming out and it takes however to make ice. There is no kink in the water line to the fridge.
water stopped dispersing out of water dispense, No indication as to why. New filter was instlled, checked water line, no leakage indicated, ice maker had been making ice prior to this, turned off ice maker to avoid motor burn out.
Dec 26, 2010 | LG LRSC-26922 Side by Side Refrigerator
No Water
With out knowing your model of Amana it will be harder to locate the problem. It is rare that both water control valves would stop working at the same time unless you had a crimp or a line blockage feeding water to the refrigerator. First I recommend you turn the water supply off to the rear. Second I want you to disconnect the water feed to the water control valve on the rear near base and lean the line into a bucket so you can have the supply line turned back on just to make sure there is no blockage or crimp in the feed line. Third if you have a self piercing tap valve to supply the water that may be the problem because the hole is small and easy to collect rust or other normal particles in the line. Next you need to check the voltage at the water control valve side for the dispenser. Have someone press dispense water while a voltage meter is connected to the dispenser side female plug. And last of all the door switch may be the only problem. It is designed that when the door is open the dispenser panel is off. If when shut the switch does not make a connection, the dispenser pane, ice maker and auger motor are turned off. Let me know what you find, Sea Breeze
Oct 12, 2009 | Refrigerators
Ice maker and the water dispensor is not working.the fridge is only 6 months old
does your plastic water line run from underneath your sink to fridge? if so maybe you put something under sink and crimped the little plastic water line. pull refride out some and then try water dispenser
Jul 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Whirlpool ED5RHEXNL03 water dispenser isn't working
On back of refrigerator there is a dual water control valve. One side may be defective. If you would like my help, let me know, Thanks, Sea Breeze
Jun 19, 2009 | Whirlpool ED2FHEXN Side by Side...
Kenmore side by side water dispenser has stopped
Most likely need to replace the water inlet valve. The water supply line should be directly connected to it. There are 2 valves bracketed together, 1 for the ice maker and 1 for the water dispencer. You will probably have to buy both valves, but want to do this anyway as the second valve will fail soon. Hope this helps.
Jun 14, 2009 | Refrigerators
Water dispenser problem
Did the man who installed it use plastic hose or copper pie? PLastic pipe can get crimpled (closed) and starve the water supply.
Simply move the refrigerator far enough away from the wall and see if the tubing is crimped. If it is copper and it is crimped- you should call the installer back to repair the copper pie. Once copper pipe is crimped- it is unusable and must be refitted with a coupling or union or some other proper repair.
Maybe this is all that is wrong.......
Hope this helpes!!!
May 30, 2009 | Whirlpool ED2FHEXN Side by Side...
GE GSS20IEP Side by Side Refrigerator Logo
486 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
