Question about Samsung TV Remote Control
Have samsung tv and says volume not available - i
We have samsung tv and says volume not available - i think my 21 month old hit some setting on the remote...but volume won't work on the tv, on the samsung remote nor on the universal remote but it does work when i turn on the samsung dvd player (for the dvd's only) - is there something she hit on the remote that turned the volume feature off? I ahve checked everything. Or do you think the volume simply doesn not work on the tv because somehow the tv speakers blew? Please help and thank you very much!
IrishDruid
  • 2712 Answers
SOURCE: Universal remote for Samsung Hitron
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 24, 2008
andy4254
  • 226 Answers
SOURCE: Remote control has stopped working.
your remote needs to be put back in TV mode. press the tv button or slide the switch to tv
Posted on Apr 28, 2009
SOURCE: bn59 00463 volume works nothing else cant turn on
Step 1: Remove the batteries
Step 2: Press the power button (red button) on the remote control 5 times.
Step 3: Replace the batteries and your remote should work fine.
Posted on Oct 27, 2009
SOURCE: Samsung remote won't turn 630 LCD off. Only volume works.
yo moel
the way i did it was take the batteries out and hold powere button for 5 seconds put batteries back in and should be fine mate!
ahmed
Posted on May 17, 2010
SOURCE: We have an AK59-00104R remote
To program this Samsung remote to work with a TV, press the TV POWER button on the remote while entering a manufacturer specific code into the remote at the same time.
1. Switch the TV on. 2. Point the remote towards the TV. 3. Press and hold the TV Power button and enter the two-digit code for that brand of TV. If the code is compatible, the TV will switch off. 4. There may be more than one code for that manufacturer, so try them all until one works.
For Samsung TVs, one of the following codes should work: +01 +02 +03 +04 +05 +06 +07 +08 +09
Posted on Jan 29, 2011
Samsung led tv 5003 remote channel selector not working, must use cable company remote. Volume only works on samsung remote.
The cable company remote will have under settings a program code function for the remote. Setting the Samsung code will enable the cable remote to adjust the volume. Many TVs have more than one code. You may need to try several to get the right one.
the attached images are examples of this process. Your remote supplied from the cable provider will have its own unique process. Consult the info supplied with the remote. Access the help feature available with some cable services. Your cable provider may have the help function available on their Website.
Hope this helps?
Sep 28, 2016 | Samsung Televison & Video
My 'volume up button' on the tv is not responding. We use google chromecast so we have never used the remote, nor do I even know where it is. My tv is only 6 months old. Please help.
sounds like a call to the mfg is in order. should be under warranty if only 6 months old . but if you open it that might void warranty .so think smarter not work harder
Jan 10, 2015 | Element Electronics Televison & Video
I need to program my telus remote to turn my 46"
Press and hold TV, then OK at the same time. Let go of TV and OK, top buttons should quickly blink red then stop press the code 1019 then hit the bottom right button marked ENTER or OPTIONS
Remote should now work with tv.
To control volume and power at the same time... Press and hold STB and OK at the same time, let go, red blinking up top enter the code 977 STB should blink red a few times.
Hit STB, see if TV volume adjusts Hit POWER. see if both STB (Set Top Box) turns off and TV turns off.
All should be good.
If both TV and STB do not turn on/off, repeat the process for the code where you enter 977
Jan 29, 2011 | Samsung LN-T4661F 46 in. LCD HDTV
Volume buttons stopped working
Check in the TV's AUDIO menu for anything related to turning on/off speakers. Also, unplug RCA's that you may have hooked up to the Audio OUT ports. Some video inputs may not have a sound input associated. The only one I can think of would be VGA, but even that would be rare.
Dec 05, 2009 | Samsung RS105N Remote Control
Frozen samsung TV - wont turn off
since you say you have had it just a short time
call samsung and request service for your set this is a problem and will get worse
if its just a couple months old parts are still in warranty and not sure of labor there is a warranty statment in the owners manuel
Nov 01, 2009 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
I have an older Phillips Magnavox TV Mar 2000 model number TP3284C102 and the remote died. I am trying to program a new remote (a samsung) I hit the set button and run the channels but cannot get it to...
The code number should be listed in the manual sheet for the remote control, or from the Samsung web site. If not found, a new OEM remote for the Philips TV is available from Amazon for $21.
Oct 18, 2009 | Philips TV Tuner Video Capture PCI Card -...
Remote code SAMSUNG
I have a samsung HT-AS720S surround system it is 21 months old. the right speaker has popping and static coming from it, had to disconnect it. Moved wire to another speaker-same thing. Contacted samsung tech to help, went through a number of test they said I have to send it in for repair. Warranty is only one year.
I also have a problem with the sound when watching tv it goes from normal to very quit, it's irritating-no matter how high I turn it up the base goes up but volume stays down. On shows that are on DVR all sound is good. Watching a DVD is also good.
Please help
Nov 05, 2008 | Audio Players & Recorders
Sharp Aquos 32"
TV is under warranty. Get a tech to look at it. It could require a new IR sensor, a firmware upgrade or a system reset that only a tech can do called an Industry Initialization that is in the service mode only
Jun 24, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
15 DAY OLD TV
Make sure you are hitting the right menu button. Samsung thinks they are dummy proofing their tvs. You cant get to anything they do not think is pertinent at the time. Make sure you are hitting the write button on the remote. Try to hit menu on the tv and see if that works.
Feb 04, 2008 | Televison & Video
Volume on Remote powers TV on and off?
This unit has upgrades available for this set. I am not at my shop now, but, I think the problem you described is usually cured by this upgrade. The set is under warranty, contact: 1-800-Samsung for a local servicer. If you need additional help, respond to this post and I'll reply.
Aug 26, 2007 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung TV Remote Control Logo
942 people viewed this question
Henry  Thomas
Henry Thomas
