Question about Sanyo DS25390 TV
Buzzing sound coming from unit - Sanyo DS25390 TV
    Genius:
  • 1,043 Answers
You may have an issue either with a transformer or a capacitor in your power section, or there may be a cold solder joint or bad ground in your audio section. Unless you have the experience and tools to work on the power board I would strongly advise against trying to fix it yourself. There are lethal voltages inside TV's that must be dealt with correctly.
Posted on May 29, 2010
I checked my speakers there not blown out still making buzzing sound. Why?
the buzzing sound is an symptom or indication that there is a defect on the output audio system from your unit. A good audio system does not give out a buzzing sound.
Check for shorted audio wire coming from your audio unit going to the speakers
Feb 23, 2016 | Audio Players & Recorders
Color Tv
Buzzing nois of this kind can come from a short or from disturbance.
Aug 11, 2008 | Sylvania 6413TC 13" TV
HEARING A BUZZING SOUND COMING FROM UNIT WHEN THE UNIT STARTS. COULD THIS BE THE BEARINGS GOING OUT IN THE MOTOR
If throttling sound comes it may from bearings or non alignment of blower wheel. But in your unit I think, it's freon flowing.Some times it may happens from to non serviced unit for long time. Service your unit. Helpful?
Jan 04, 2011 | Heating & Cooling
Buzzing sound when aux heat comes on
Sounds like it could be a effiency function to warn you that the heat elements are on. Check your thermostat manual and see if you can turn this feature off. If this is not a feature then the thermostat may be wired wrong or something in the circuit may be trying to short out.
Jan 04, 2010 | Honeywell Electronic Programmable...
Goodman a/c unit outside not coming on. buzzing
Sounds like compressor is bad...taken out by a bad contactor.
Aug 17, 2009 | Heating & Cooling
Outside Unit blowing air but not cooling and slight buzzing sound
The compressor is not coming on and some part of that unit has failed. Do you hear any clicking sounds along with the buzzing sound? Recommend that you shut the unit down (remove power from it) until a service tech can listen to it try to start up.
The power company-installed load management system is probably a red hearing. That system will either fully turn off the unit or allow it to turn on/start up.
May 08, 2009 | Heating & Cooling
There's a buzzing sound coming from my central air conditioner unit outside. The fan is quiet but I hear a buzzing sound. Should that be happening? Sounds like there's something loose.
Things that are not broken: The big relay that powers the compressor often hums or buzzes when the unit is running. Several brands of heat pumps keep their reversing valve "on" any time the thermostat is set for "cool". They buzz, too.
If something really is loose, the only way to fix it is to look at the machine and take off panels until you find what is buzzing.
Jul 20, 2008 | Heating & Cooling
Compressor problem?
The buzzing is your compressor trying to start. It is going off on internal overload caused by heating up of the motor windings.If you have an amp meter you could check the amp draw of the comp against the locked rotor amps listed on the tag You could try to have someone test your run capacitor, which looks like a can. Could be round or oval with wires coming off it. Or try a hard start capacitor and relay to bust it loose if compressor rotor is stuck. If that doesn't do it the comp is bad.
Jun 10, 2008 | Ruud UBHC Air Conditioner
Fan not blowing
Even when the power is off at the unit outside the thermostat will supply power to the contactor of the outside unit. This may give a hum or buzz as you stated. If when the power is on to the outside unit the fan tries to start but only hums the motor may be bad. Does the compressor start and run?
May 06, 2008 | Weather King 10AJA2501AH Air Conditioner
Loud Buzzing Sound - Rear of TV
It is probably the color wheel that needs replacing.
Oct 05, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Televison & Video Logo
151 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
