Question about Riccar Sewing Machines
Shuttle hook install - Riccar Sewing Machines
How do I put the shuttle race and the shuttle hook back into my front loading sewing machine?
You didn't provide the make & model of your machine, but one of these may be helpful:
install bobbin shuttle Google Search
Dec 21, 2016 | Sewing Machines
MY BOBBIN CASE HAS FALLEN APART AND I'M NOT SURE HOW TO PUT THE PIECES BACK TOGETHER.
Sounds like you are describing the hook. Perhaps the owner's manual would be assistance. We don't know the make/model of your machine so are really unable to help. There are some videos on YouTube that show how to install a shuttle and bobbin case, but machines differ.
Set up the shuttle race for RS2000 Series
Brother LS30 Inserting Bobbin Vertical Shuttle Hook
How to Clean and Maintain your Sewing Machine at Home Front Loading Bobbin
Mar 14, 2016 | Sewing Machines
How do i put the shuttle back correctly to stop needle hitting shuttle
If you are inserting the shuttle and locking it in place but the needle continues to hit, the needle may be bent. If a new needle is installed and it continues to hit, most likely the needle/hook timing is off. Take it for service.
Feb 23, 2016 | Sewing Machines
Necchi 3537 manual is useless. How do I put bobbin shuttle hook back into the machine?
HINT: before you install the shuttle, make sure to place a drop of sewing machine oil around the outer edge of the shuttle and lightly spread it around the outer edge (you should do this about every time you change a bobbin). Sorry, you'll probably need to be familiar with removing and installing the shuttle. Have patience! Once you've done it a couple of times, you'll wonder why it was so difficult.
It usually helps if you can tilt the machine back about 45 degrees so it is supported by something (pillow, cushion) so you can get good visibility into the bobbin area.
Raise the needle so that the take-up bar is at its highest point.
Make sure the outer hinged door on the shuttle area is open. Inside that open door is a metal unit that is shaped like a "C". The shuttle makes up the other part of the "C". The two C's face each other and complete the circle. Grasp the shuttle by the projecting bobbin pin. (Perhaps the photo & videos will help you in placing the shuttle (you'll probably need to wiggle it around a little until it pops into place.) Once the shuttle has snapped into place and you've closed and latched the outer cover, you can install the bobbin case.
Necchi Zig Zag Shuttle movement
Necchi Oscillating Shuttle
Jan 04, 2016 | Necchi Sewing Machines
Shuttle hook has come loose
Bring it in for service, if you do the repair and do it wrong (and you will) then it could cost you hundreds of dollars to replace the shuttle. Pay a little now, or tinker with it and pay a lot later...
Mar 29, 2014 | PfaFF Sewing Machines
WHERE CAN I FIND THE SHUTTLE HOOK FOR MY LS2125
try these sites--you may have to email them about the part
sewingpartsonline.com
sew4less.com
sewvacdoctor.com
a1sewingmachines.com
May 08, 2012 | Brother LS-2125 Mechanical Sewing Machine
Should the machine have some oil? Where? It is a Bernina Activa 130
The Activa range is fitted with a light-weight part-plastic hook/shuttle that Bernina claims does not require oiling. However, this does not mean it shouldn't be regularly cleaned and I'd recommend that it is also lightly oiled at the same time. Remove the bobbin case, press the metal lever to the top left of the bobbin door and the black plastic hook/shuttle retainer should pop open so that the hook/shuttle can be removed, or it will just drop out anyway. Use a cotton bud to firmly clean around the inside edge of the hook race (the round piece that the hook/shuttle sits in. Give the whole thing a good clean to make sure any surface grime/fluff is removed. Put a small drop of oil on the running surface of the hook race - the recessed groove around the inside edge, before replacing the hook/shuttle and holding in place by pressing the hook/shuttle retainer back until the securing lever clicks back into place. Rotate the handwheel once to distribute the oil and off you go. Dont overoil but do this regularly and your machine will run much quieter and produce a consistent stitch formation.
Jul 07, 2011 | Bernina Activa 130
How to install bobbin
In the shuttle area there is a silver round piece- called the shuttle race cover. It has a black ear on the right and a black ear on the left. Push the right ear to the right, and the left ear to the left and the silver ring should come out. Behind the silver ring is the bobbin case stuck in the hook. Remove that, jiggle it, move it, just work the bobbin case out of the hook. Now put the hook back in the machine. In the machine there is a driver that looks like a half moon. Your hook looks like a half moon- make a full circle out of both of them. Re-install the race cover, pushing the left ear to the right and the right ear to the left to secure the race cover, and your problem should be solved.
Jul 07, 2009 | Necchi Sewing Machines
Can't reassemble shuttle hook and shuttle race
the hook driver (still in machine) is 1/2 moon shape. The hook is also 1/2 moon shape. If you set the machine on its back, it's easier. Set the hook 1/2 into the other 1/2 of the hook driver to make a circle. Then put the hook cover on (machine still on its back) with the tabs for the twist locks pointed out. Needle gaurd to the top of the machine. Snap the twist locks in place and viola!
Kent
Mar 16, 2009 | Baby Lock BL1556
Shuttle hook
Hello ZAckofun
The shuttle hook will be covered by a plate called the RACE. Its a flat steel plate that sits over the hook and is snapped in place by 2 black coloured snaps.
Looks like you are trying to operate the machine without the race on. try that and it should work.
Nov 27, 2007 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
73 people viewed this question
Top Riccar Sewing Machines Experts
Tally Girl
Tally Girl
Joseph Mueller
Joseph Mueller
Are you a Riccar Sewing Machine Expert? Answer questions, earn points and help others
