Question about HP LaserJet 3050 All-In-One Printer
HP Laserjet 3050, 2605dn, 1022n
My printers (all network printers) takes a long time to respond to any print job and I have tried everything. Any help will be much appreciated. My email is [email protected]
  • decmacs Jan 16, 2009
    Yeah, I do also have the same problems. It took 1 hours just to print 2 pages out of 10 pages left. Any solutions?
  • 320 Answers
Do your printers have built in print servers? go into printer properties advanced settings there you will find what is called priority default for this is 1 on hp change this setting to a higher number and this should improve your response time to print
Posted on Sep 11, 2009
    Problem Solver:
  • 16 Answers
You need to discern whether it is what your are printing, your computer or a network issue.
Start notepad and type a few characters. If the printer prints fine then you might need a different emulation to print with such as a postscript driver instead of pcl.
If notepad prints slow then you either have a computer or network issue. Print from notepad on another pc. If that prints fine then check the pc you are using.
If the other computer prints slow also then check your network for throughput issues.
Posted on Sep 10, 2009
    Scholar:
  • 169 Answers
What you can do is go ahead and uninstall and reinstall the printer drivers.This should fix the problem.If you want further support you can avail free technical support on
http://tinyurl.com/m7ghqz
Posted on Jun 19, 2009
  • 61 Answers
One time un reinstall the all printer drivers Before u go to C:\WINDOWS\system32\spool\drivers\w32x86.then delete all folders and files
Posted on Mar 28, 2009
6ya staff
SOURCE:
Usb light link
HP LaserJet 1022 is a "host-based" printer so it must be connected to a PC. Load the driver on PC first and connect the USB cable when software tells you to do so.
Will not work on a Linksys print server.
LaserJet 1022N & LaserJet 1022NW have "special" HP print servers that can support HP host based printers.
Nov 27, 2013 | Linksys Wireless-G WPS54GU2 Print Server
HOW TO CHECK IP OF THIS NETWORK PRINTER
  • From Start button and select Control Panel.
  • Select "Hardware and Sound" and choose "Devices and Printers.
  • Right-click on you HP printer you want to check the IP address of and click on "Properties".
  • Click on the "Ports" tab. The first number listed is the IP address of the printer.
Aug 28, 2012 | HP LaserJet 1022n Printer
Hp laserJet 1022n printing multiple copies when copies are set to 1
Had this same problem found a working solution here http://www.tomshardware.com/forum/59912-3-1022n-printer-stop-printing.
Just disable bidirectional support in the printer properties worked for me
Jan 06, 2012 | HP LaserJet 1022n Printer
Printer hp laserjet 1022n prints junk charcters
Go to hp.com, then support and services, in that site you can contact online and ask their specialist.
May 30, 2011 | HP LaserJet 1022n Printer
Hi, I rested my HP 1022n Printer, now with old IP address its not printing, how can get my printer new IP address ? and please tell me how can take Test report of same printer, i tried pressing Green(go)...
Every network printer or print server has a unique IP address associated with it. This address is either configured manually or set using an automatic network protocol such as the boot protocol, reverse address resolution protocol or zeroconf. You can normally find the IP address of a printer on the printer's control panel or by printing the configuration page. Select the printers and faxes tab from the control panel. Right click on the printer those you want to find the IP address and click properties. Then click on the ports tab to display the IP address of your printer.
Nov 25, 2010 | HP LaserJet 1022n Printer
Printer Not Woking In Network
1. check that not any firewall or antivirus software blocking your printer.
2. try to look in paper settings what format you sending to the printer. is it letter format or A4 or what ? it should be A4.
have you tried to connect the printer with USB? or have you connected the printer with a network cable.?
Jul 03, 2009 | HP LaserJet 1022 Printer
HP 9040n NOT RESPONDING
Try connecting this printer to a different network wall point in the building. If still no change then move back to original wall point and try changing the connection at the Switch end in the comms room.
If still having problems then try pinging the printer to see if it gives time out or execessively high pings. Got a PC on the network and in windows open a "command" prompt and type ping -t XXX.XXX.XXX.XXX where the address of the printer should be place of the x's.
If linux open a console and type the same thing ping -t XXX.XXX.XXX.XXX.
Regards
Please dont forget to rate!
Regards
Feb 28, 2008 | HP LaserJet 9040n Printer
HP LaserJet 3050 All-In-One Printer Logo
226 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
