Question about IBM TravelStar 40GN 40 GB Hard Drive
THE SYSTEM LOADS BUT IS NOT SEEN IN
THE SYSTEM LOADS AND IS READY TO USE BUT IS NOT SEEN IN "MY COMPUTER"
    Brigadier General:
  • 10,406 Answers
Click Start
Click with the SECOND (usually the RIGHT) mouse button on My Computer.
Click Manage.
Click Storage
The "Disk Administrator" will start, and your disk-drive may show up as being "unformatted".
Use this utility to create a partition, and to format the partition.
Then, the "empty" partition will show-up in My Computer.
Posted on Jun 15, 2010
The blue screen appers and then nothing but the splash screen loads
This means your never getting to the Operating system. Can you do any DOS hard drive diagnostics? I know a lot of my question depends on what kind of computer stuff you have from the past but many troubleshooting methods still attempt to see if hardware is working using Disk Operating System tools such as chkdsk and so.
If the DOS operating can not access the hard drive- it may not be spinning up or the boot sector may have been damaged by a trojan horse or virus. I have repaired the boot sector with a dos command before. There are many other issues that can also cause this it is not just one thing. It can be badly seated memory chips, capacitors on the motherboard that have puffed or leaked. I have even had a processor overheat due to fuzz and grease as it was used in the kitchen in the processor heat sink- cleaning is all it needed. If you can not get past the CMOS screen then that would point to a hardware problem. Just some thoughts- it probably needs to be seen by a good Computer Technician.
Sep 23, 2012 | Computers & Internet
Windows XP RAM 1.9Gb but BearPaw 2448TA Pro nit started-error: Insufficient Memory
Check if your system matches the requirements of the software. I can't seen to find the model you have given but make sure you have enough hard drive space, make sure you don't have loads of applications and services open (Task manager will tell you) & make sure your graphics card has enough memory for the software to run.
Feb 25, 2011 | Mustek Systems BearPaw 2448TA Pro WIA...
I am have problems booting hdd. I can get into bios only when I have switched the jumper. hdd's are running and ae seen in the bios. why can I not get the hdd's to boot up?
It sounds like you have lost the boot sector on the hard drive.
Try loading your opperating system from your system CD. If it loads OK then run your system CD and choose "Repair System" when prompted.
Hope that helps.
Oct 25, 2010 | Computers & Internet
Everything comes on but wont start wont even turn over ever since my house was struck by lighting
seen the film, war of the worlds, when all the cars went dead, well so has yours, in the same way,its called Electro Magnetic Pulse.and it kills all your relays.and computer engine management systems.this is not an easy job as you will have to connect to a diagnostic machine while you are searching for faults,unless you are a dab hand at car electrics,get it done by qualified vehicle technician.
each system has a potential fault,and you have loads.
Jun 18, 2010 | Cars & Trucks
Do this work whit my mother board ? M2N68-LA (Narra6)
yes, but the wattage is depending on your cpu loads,
hope this thing helps
Jan 22, 2010 | OCZ StealthXStream / 600-Watt / ATX /...
Non system disk replace and strikw any key when
make sure in bios you set as booting option thru hard disk if it is there then re formate the system and install the os again.
Jan 04, 2010 | Compaq Armada E500 Notebook
Sony VAIO PCG-8X2L will not boot. it loads the VAIO logo and sticks right there. no bios no post.
You have a currupt bios firmware. You need to pull out your battery, and disconnect the Cmos battery. Next leave it for at least 24 hr. to make certain you clear Cmos. Now get the latest bios update and have it ready to install. Make certain your a/c power supply is attached during this process. Put in a bootable cd with the firmware on it and see if it loads the new Bios firmware. You can then try to boot the Laptop or PC. I have had good luck doing it this way on most laptop's. Good Luck Phil
I have seen some cases where it is a motherboard problem, but not very often. I have also seen where it is caused by defective memory. You may want to test your memory in another laptop or borrow a chip to see what happens.
P.S. Here is the link to your bios firmware.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCGTR3AP1
Dec 10, 2009 | Computers & Internet
Annoying buzz coming out
i have a similar problem, and i've seen loads of stories about the same problem from these speakers, it's a shame because otherwise these speakers are pretty good :(
The speakers seem to pick up interference, especially when the volume is low, they also sometimes give out periodic buzzes, but this could be individual faults with equipment.
Jun 11, 2009 | Logitech X-240 Computer Speakers
Hard drive will not boot, seen by bios but not seen by OS
if you can get into safemode
click start then run
type msconfig
in general tab click normal startup mode load all drivers etc.
then click okay or apply
restart and then if a box appears click do not show again
hope this helps if not let me know
Jan 22, 2009 | Panasonic ToughBook 52 Notebook
Dell B120-loads but no log on page seen
I have the same problem with my Inspiron 8200 - it's the video driver. The system will load but then no log on screen. The solution until you can get an updated driver is to do a power-off reset.
Dec 14, 2008 | Dell Inspiron B120 Notebook
IBM TravelStar 40GN 40 GB Hard Drive Logo
83 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
