Question about Kb Toys Moon Shoes
Assembly instructions for moon shoes - Kb Toys Moon Shoes
Just got back from buying the Crescent Moon Series 13 snowshoe. Looked online and that series is for woman. Is that a problem for a man to wear?
Are they your Size?
What is your Weight?
If you are a LARGE MAN, it could be an issue but if your Foot fits into the shoe, and you are a normal stature, you are ok.
Feb 12, 2014 | Crescent Moon Snowshoes Crescent Moon Gold...
Where can I get assembly instructions for the rubbermaid 60" garment organizers? I was recently reassigned from one military post to another and the movers disassembled the closets, but I threw away...
I saw that you put this problem under as a shoe problem, but it is more of a assembling or hardware type problem. Changing the category from a show problem to something more suitable can help you get the problem answered sooner and by a non shoe expert.
May 19, 2011 | Clothing Accessories
Instructions and diagram,to remove and replace rear drum brakes
1984 Ford Tempo - Rear Drum brake drum/shoes
REMOVAL & INSTALLATION
See Figures below instructions
1. Raise and safely support the vehicle with jackstands.
2. Remove the wheel, tire, hub and finally, the drum assembly.
3. Using a spring removal tool, remove the horizontal securing spring at the top first of the assembly.
4. Pull the adjuster locking plate away from the shoes.
5. Remove the lower horizontal securing spring.
6. Unfasten one of the 2 shoe hold-down springs and remove the pin.
7. Remove the brake adjuster.
8. Remove the remaining hold down spring and clip.
9. Lift the brake shoes assembly off the backing plate and wheel cylinder assembly. Be careful not to bend adjusting lever during the removal process.
10. Remove the parking brake cable from the parking brake lever.
11. Remove the horseshoe retaining clip and spring washer and slide the lever off the parking brake lever pin on the trailing shoe.
To install:
12. Apply a light coating of high temperature grease at the points where the brake shoes contact the backing plate.
13. Apply a light coating of lubricant to the adjuster screw threads and the socket end of the adjusting screw. Turn the adjusting screw into the adjusting pivot nut to the limit of the threads and then back-off 1 / 2 turn.
14. Assemble the parking brake lever to the trailing shoe by installing the spring washer and a new horseshoe retaining clip. Crimp the clip until it retains the lever to the shoe securely.
15. Attach the parking brake cable to the parking brake lever.
16. Attach the lower retracting spring to the leading and trailing shoe assemblies and install to backing plate. It will be necessary to stretch the retracting spring as the shoes are installed downward over the anchor plate to inside of shoe retaining plate.
17. Install the adjuster screw assembly between the leading shoe slot and the slot in the trailing shoe and parking brake lever. The adjuster socket end slot must fit into the trailing shoe and parking brake lever.
The adjuster socket blade is marked R or L for the right or left brake assemblies. The R or L adjuster blade must be installed with the letter R or L in the upright position, facing the wheel cylinder, on the correct side to ensure that the deeper of the 2 slots in the adjuster sockets fits into the parking brake lever.
18. Assemble the adjuster lever in the groove located in the parking brake lever pin and into the slot of the adjuster socket that fits into the trailing shoe web.
19. Attach the upper retracting spring to the leading shoe slot. Using a suitable spring tool, stretch the other end of the spring into the notch on the adjuster lever. If the adjuster lever does not contact the star wheel after installing the spring, it is possible that the adjuster socket is installed incorrectly.
20. Inspect your work to make sure it is correct.
21. Install the hub/drum and wheel/tire assemblies and adjust the wheel bearings.
22. Lower the vehicle and check brake operation.
Fig.1 Exploded View of Rear Brakes - 1984 Ford Tempo
Fig 2. Remove the brake shoe upper retaining spring with a suitable removal tool.
Fig.3 Removed retaining spring - note spring direction.
Fig.4 Remove the adjuster lock plate. Note the direction of the tab.
Fig.5 Remove the lower retaining spring.
Fig.6 Remove the Hold Down Spring - note brake spring tool used.
Fig.7 remove the shoe adjuster. Note direction of the adjuster spline.
Fig.8 Remove the hand brake cable.
Fig.9 Remove the final brake shoe.
Fig.10 All removed parts in order and properly oriented for re-assembly.
Apr 17, 2011 | 1984 Ford Tempo
Remove replace rear brakes on ford t bird 1996
1989-97 Vehicles Drum Brakes (Let me know if you need the Disc Brake Instructions)
  1. Raise and safely support the vehicle.
  2. Remove the rear wheel and tire assemblies, then remove the brake drum.
    Fig. 4: View of the drum brake assembly with the drum removed
    Fig. 5: Use a commercially available brake spray to clean the
    components before removal
  3. Install Brake Cylinder Clamp D81L-1103-B or equivalent, over the ends of the
    rear wheel cylinder.
  4. Disconnect the parking brake cable from the parking brake lever.
    Fig. 6: Detach the parking brake cable and conduit from the
    parking brake lever
  5. Remove the 2 brake shoe hold-down retainers, springs and pins.
  6. Spread the brake shoes over the piston shoe guide slots. Lift the brake
    shoes, springs and adjuster off the backing plate as an assembly. Be careful not
    to bend the adjusting lever.
    Fig. 7: Lift the brake shoes, springs and adjuster off the
  7. Remove the adjuster spring. To separate the shoes, remove the retracting
    springs.
  8. Remove the parking brake lever retaining clip and spring washer. Remove the
    lever from the pin.
    Fig. 8: Drum brake components - 1995 vehicle shown
    Fig. 9: Exploded view of the drum brake components, removed
    from the vehicle
    To install:
  9. Apply a light coating of caliper slide grease to the backing plate brake
    shoe contact areas.
  10. Apply a light coat of lubricant to the threaded areas of the adjuster screw
    and socket. Assemble the brake adjuster with the stainless steel washer. Turn
    the socket all the way down on the screw, then back off 1?2 turn.
  11. Install the parking brake lever to the trailing shoe with the spring washer
    and a new retaining clip. Crimp the clip to securely retain the lever.
  12. Position the trailing shoe on the backing plate and attach the parking brake
    cable. Position the leading shoe on the backing plate and attach the lower
    retracting spring to the brake shoes.
  13. Install the adjuster assembly to the slots in the brake shoes. The socket
    end must fit into the wider slot in the leading shoe. The slot in the adjuster
    nut must fit into the slots in the trailing shoe and parking brake lever.
    Fig. 10: Install the adjuster assembly in the slots in the
    brake shoes
  14. Install the adjuster lever on the pin on the leading shoe and to the slot in
    the adjuster socket.
  15. Install the upper retracting spring in the slot on the trailing shoe and the
    slot in the adjuster lever. The adjuster lever should contact the star and
    adjuster assembly.
  16. Install the brake shoe anchor pins, springs and retainers. Remove the brake
    cylinder clamp tool
  17. Install the brake drum, wheel and tire assemblies and lower the vehicle.
  18. Apply the brakes several times while backing up the vehicle. After each
    stop, the vehicle must be moved forward.
Oct 07, 2010 | 1996 Ford Thunderbird LX
REAR BRAKES SHOES INSTALLATION HOW TO INSTALL
This is a pretty straight forward repair. Normally the hardest part of the repair is dis-assembly of the rear brake assembly components and retaining clips. There is a special tool, set of pliers you can purchase to simplify some of this but typically you can do the job with a Pair or Regular pliers, pair of Needle nose pliers and a large blades flat screw driver. For step by step instructions and illustrations of the work area I recommend the Haynes Repair manual for your vehicle.
Sep 30, 2010 | 1999 Mercury Cougar
Picture or directions for repairing rear drum brake
Brake Shoes Removal & Installation Duo-Servo Type To Remove:
  1. Raise the vehicle and support it safely.
  2. Remove the tire and wheel assembly.
  3. Remove the brake drums.
  4. Using a brake tool, remove the shoe return springs.
  5. Remove the shoe guide.
  6. Remove the hold-down springs and pins.
  7. Remove the actuator lever and pivot.
  8. Remove the lever return spring.
  9. Remove the actuator link, parking brake strut, spring retaining ring.
  10. Remove the parking brake lever and washer.
  11. Remove the shoe assemblies.
  12. Remove the adjuster screw and spring from the shoe assembly.
To Install:
  1. Use brake cleaning fluid to remove dirt from the brake drum. Check the drums for scoring, cracks and for out-of-round; service the drums as necessary.
  2. Check the wheel cylinders by carefully pulling the lower edges of the wheel cylinder boots away from the cylinders. If there is excessive leakage, the inside of the cylinder will drip fluid; repair or replace as necessary.
  3. Check the flange plate, which is located around the axle, for leakage of differential lubricant.
  4. Lightly lubricate the parking brake cable, parking brake lever where it enters the shoe and the backing plate-to-shoe contact points. Use high temperature, waterproof, grease or special brake lube.
  5. Install the parking brake lever into the secondary shoe with the attaching bolt, spring washer, lockwasher, and nut. It is important that the lever move freely before the shoe is attached. Move the assembly and check for proper action.
  6. Lubricate the adjusting screw and make sure it works freely.
  7. Connect the adjuster screw and spring to the bottom portion of both shoes. Ensure the spring does not interfere with the adjuster rotation when installed. The primary (smaller shoe pad area) to the front and secondary shoe (larger shoe pad area) to the rear of the vehicle.
  8. Install the shoe assembly. Ensuring the shoe webs are positioned correctly against the wheel cylinder.
  9. Install the parking brake cable.
  10. Secure the primary shoes with the hold-down pin and spring.
  11. Install the parking brake strut and the strut spring.
  12. Install the actuator lever and pivot, securing the assembly with the hold-down pin and spring. Install the actuator link and spring.
  13. Install the return springs.
  14. Check the operation of the self-adjusting mechanism by moving the actuating lever by hand.
  15. Adjust the brakes and install the drum.
  16. Adjust the parking brake.
  17. Install the tire and wheel assembly.
  18. Lower the vehicle.
Leading-Trailing Type To Remove:
  4. Raise the lever arm of the actuator until the upper end is clear of the slot in the adjuster screw.
  5. Slide the actuator off the adjuster pin. Disconnect the actuator spring from the shoe.
  6. Remove the hold-down spring assemblies and pins.
  7. Pull the bottom ends of the shoes apart and lift the lower return spring over the anchor plate. Allow the shoe ends to come together and remove the spring.
  8. Remove the shoe assembly, along with the upper return spring and the adjusting screw assembly.
  9. Remove the upper return spring and the adjusting screw assembly from the shoes.
  10. Remove the retaining ring, pin, spring washer, and parking brake lever.
Typical rear drum brake assembly (Leading/Trailing type) 93026g52.gif
To Install:
  1. Clean adjuster wheel and the backing plates with a suitable cleaner. Lubricate the backing plate contact points, levers and adjuster with a suitable lubricant.
  2. Assemble the parking lever, spring washer (concave side facing the brake lever), pin, and retaining ring onto the rearward shoe.
  3. Install the adjuster pin in the forward shoe with the pin projecting 0.276 in. (7mm) from the side of the shoe web where the adjuster actuator is installed.
  4. With the brake shoes resting on a flat surface (the shoe with the parking lever to the rear of the vehicle), install the upper return spring.
  5. Install the adjuster screw assembly with the spring clip facing the backing plate.
  6. Place the shoes in position on the backing plate. Do not place the lower shoe webs under the anchor plate.
  7. Install the lower return spring, spread the bottom of the shoes and position the shoe against the backing plate.
  8. Install the hold-down pins and spring assemblies.
  9. Install the adjuster actuator over the end of the adjuster pin so the top leg engages the notch in the adjuster screw.
  10. Install the actuator spring, being careful not to over-stretch it more than 3.27 in. (83mm).
  11. Install the parking brake cable to the lever.
  12. Adjust the parking brake if the shoes will not totally retract.
  13. Install the drum, tire and wheel assembly. Adjust the rear brakes and lower the vehicle.
Aug 17, 2010 | 1999 Chevrolet Suburban
I need replacement bands for shoes that are frayed
http://www.bigtimetoys.com/contact.html Big Time Toys, LLC
708 Berry Road
Nashville, TN 37204
Moon Shoes Replacement Rubber Bands
Send a check for $7 to Big Time Toys at the above address for a pack of 50 replacement rubber bands.
Oct 23, 2009 | Kb Toys Moon Shoes
Remove and replace rear brake shoes on 2004 honda accord
Brake Shoes Removal & Installation To Remove:
  1. Raise and safely support rear of vehicle.
  2. Remove rear wheel assemblies.
  3. Release parking brake.
  4. Remove brake drum.
Rear brake shoe assembly
  1. Using an appropriate brake spring tool, unhook upper return spring from rearward brake shoe.
  2. Push retainer springs IN and turn to remove tension pins.
  3. Lower brake shoe assembly and remove lower return spring.
  4. Remove brake shoe assembly from back plate.
  5. Disconnect parking brake cable from lever and remove brake shoe.
  6. Remove parking brake lever from brake shoe.
To Install:
  1. Install parking brake lever to rearward brake shoe.
  2. Secure lever to brake show with a NEW U-clip.
  3. Pinch U-clip closed.
  4. Connect parking brake cable to rearward brake shoe.
  5. Install self-adjuster lever spring on front brake shoe.
  6. Assemble clevises, adjuster bolt and upper and lower return springs.
  7. Apply a light coat of grease (Molykote 44MA or equivalent) to sliding surfaces.
  8. Install brake shoe assembly onto back plate.
  9. Install tension springs.
  10. Using an appropriate brake spring tool, unhook upper return spring to rearward brake shoe.
  11. Install brake drum.
  12. Install rear wheel assembly.
  13. Lower vehicle.
  14. Adjust self-adjusting brakes by pressing brake pedal several times.
Jul 13, 2009 | 2004 Honda Accord
Changing rear drum brakes ona 1999 chevy dually
INSTALLATION PROCEDURE
  1. Install the parking brake lever (2).
  2. Install the spring washer (3). The concave side of the spring washer should face the parking brake lever.
  3. Install the pin (4).
  4. Install the retaining ring (16).
  5. Install the adjuster pin (12) in the shoe (15) so the pin projects 6.8 to 7.0 mm (0.268 to 0.276 inch) from the side of the shoe web where the adjuster actuator is installed.
  6. Apply brake lubricant or equivalent to the threads of the adjuster screw (14) and inside diameter and face of the socket (7). Adequate lubrication is achieved when there is a continuous bead of lubricant at the open end of the adjuster nut (10) and the socket (7) when the threads are fully engaged.
  7. Install the upper return spring (5).
    • Lay the shoes (1 and 15) on a clean, flat work surface in the position they will be in when installed on the backing plate.
    • The shoe with the parking brake lever goes to the rear of the vehicle.
NOTICE: Do not over-stretch the upper return spring. Damage can occur if it is stretched to more than 204.2 mm (8.04 inches) .
  1. Install the adjusting screw assembly.
  1. Lubricate the shoe pads on the backing plate with a thin coat of white lithium grease.
  2. Install the shoe and lining assemblies (1 and 15).
  3. Install the upper return spring (5).
  4. Install the adjusting screw assembly.
    • Do not damage the wheel cylinder boots.
    • Overlap the bottoms of the shoes so the upper shoe ends clear the wheel cylinder boots.
    • Make sure the upper shoe ends rest on the wheel cylinder piston ends.
    • Do not place the lower shoe web ends under the anchor plate until the lower return spring is installed.
NOTICE: Do not over-stretch the lower return spring. Damage can occur if it is stretched to more than 107.3 mm (4.22 inches) .
  1. Install the lower return spring (6).
    • Bring the ends of the shoe and lining assemblies (1 and 15) together over the anchor plate.
    • Hook the spring ends to the shoe web holes.
    • Spread the lower ends of the shoe and the lining assemblies to clear the anchor plate.
    • Position the shoes against the backing plate and release them.
    • Pull the spring into the groove at the bottom of the anchor plate.
  1. Connect the hold-down pins and the spring assemblies (8).
  2. Install the adjuster actuator (11) over the end of the adjuster pin (12) so the top leg engages the notch in the adjuster screw. NOTICE: Do not over-stretch the actuator spring. Damage can occur if it is stretched to more than 83 mm (3.27 inches) .
  3. Install the actuator spring (13). The free end of the adjuster actuator (11) must engage the notch of the adjuster nut.
  4. Connect the parking brake cable to the parking brake lever (2).
  5. Install the drum. Align the marks made during disassembly.
  6. Adjust the rear brakes.
  7. Install the tire and the wheel. Align the marks made during disassembly.
Jul 21, 2008 | 1999 Chevrolet 3500
Kb Toys Moon Shoes Logo
97 people viewed this question
Top Kb Toys Toys Experts
ray gallant
Are you a Kb Toys Toy Expert? Answer questions, earn points and help others
