Question about KitchenAid 30 in. Architect KECC507KSS Electric Cooktop
My cooktop burners say control lock,,how do u un-lock
The center says all off control lock
  • 8,197 Answers
May I get the make and model # to help you more
Posted on May 29, 2010
The red padlock icon that usually unlocks with the 5 second touch of a finger won't unlock the cooktop.
Have you tried disconnecting the whole cooktop from the main supply for about 5 minutes? Sometimes when reconnected the fault goes away.
Nov 28, 2015 | Cooktops
What does F1 mean
The Fault Code/s will show up in the appliance Display
F0 - No Alarm Signal
Replace Main Electronic Control
F1 - Door will not Lock
Check door lock. Is Door Lock Getting Power
F2 - Door will not Un-Lock
Check door lock. Is Door Lock Getting Power Supply? Check Control Thermostat
F3 - Self Test Error
Disconnect Appliance from Mains Supply, Wait 5 Minutes and then Reconnect to Mains Supply
F4 - Shorted or Open Circuit Oven Temperature Sensor
Replace Oven Temperature Sensor, Check Sensor Harness Connection between Sensor and Control Unit
F5 - Relay Contacts Failed - Sticking
F6 - Power Board Temperature Too High
Check Correctly Installed, Check Cooling Fan Assembly, Ducting and Airways
F7 - Incorrect Polarity - Mains Supply
Check Mains Connection - Live & Neutral round the wrong way
F8 - Power Supply to Interface Problem
Check Wiring Harness, Replace Main Electronic Control
F9 - Procesor is Auto Resetting
Apr 05, 2015 | Electrolux White Westinghouse Stove Range...
Adjust flame
Do not attempt to do this task yourself, you should call a Gas Safe engineer to solve the problem.
Jun 29, 2013 | Verona CTG424SE Gas Four Burner Cooktop,...
GE profile JP969 fault code F113
I took the cooktop apart I removed the terminal from the main electronic board . The left front burner has 2 white wires and 2 yellow (my case). The 2 white wires lead to the RTD sensor.With an electric meter set on OHMS check continuity between the two wires leading to the RTD sensor .If the reading is more than 1030 ohms is good if not than you need to replace the whole burner that comes as a complete unit with sensor and ribbon heating element.I found it on line for $114.00 +shipping.I wish they sold only the sensor but it would've been too cheap and not worth it for the makers . All connections to that burner are very easy put back together . Some suppliers may ask for as much as $175-$195 for the complete unit .
Apr 11, 2012 | GE 36 in. Profile JP969 Electric Cooktop
I have bosch pgl985uc burner problem. The center burner will not stay lit.
I have the same problem especially with the center burner, but now am having increasing difficulty with two other burners. Those will eventually stay lit if I depress the knob for 20 - 30 seconds. The center burner will not stay lit, even when keeping the knob depressed for 2 - 3 minutes!
Mar 19, 2011 | Bosch PGL985UC 36 in. Gas Cooktop
NOT WORKING BURNER ON MY VIKING 6 BURNER COOKTOP VGSU 36IN
Is the little center post of the removable frame over your burners in the little notch where it is supposed to rest?
Aug 18, 2008 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Thermadore cooktop SGCS365RS
if its one of the center burners witch has the auto on off for extra low its the moduel under the handle
Potentiometer
Jul 19, 2008 | Thermador SGS36GS Gas Cooktop
Replace dcs gas cooktop re-ignition module
donho1,
most likely the problem is the switch places onto the shaft of the valve. to replace the switch, you would need to remove the burner cap and port rings. you will see a large brass nut that needs to be removed on all 4 or 5 burners. next you would need to remove the nut in the center of the simmer port ring which is also the venturi for the main burner. you must be careful when removing this nut as they have a tendancy to lock onto the jet holder and could be hard to remove (don't strip or break the venturi or holder).....after you remove those nuts, the burners and top can be removed (watch the igniter wires). you can remove the switch by removing the retainer clip that holds the switch onto the valvestem.
Dec 17, 2007 | Cooktops
KitchenAid 30 in. Architect KECC507KSS Electric Cooktop Logo
188 people viewed this question
Top KitchenAid Cooktops Experts
vince
davenpdx
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
