Question about Jenn-Air JJW8230D Electric Double Oven
I have a Jenn-air range with a error F1 code and the upper door remains locked. How do I clear code and get door unlocked ?
  • jdebenny May 29, 2010
    I need fix that clear the problem
    President:
  • 1,194 Answers
The F1 error code indicates a failed transistor in the ERC (electronic range control).
To clear this code, perform this test:-
This test is easy to perform and will help you determine whether the Electronic Range Control (ERC, control board) or touch pad is defective when the F1 code is displayed.
With some models, the ERC and the touch pad are one single unit and therefore this test is not necessary. The entire assembly must be replaced.
If you have any doubts in your ability or safety of the repair, please contact a qualified appliance repair technician.
1. Disconnect the power to the range by either unplugging the power cord, or turning the power off at the circuit breaker. Always make sure the power as been disconnected properly before beginning this test.
2. Access the control panel.
3. Disconnect the touch pad ribbon from the ERC.
4. Re-assemble the control panel. Make sure to check for any additional defects such as frayed or lose wires that could be causing the problem.
5. Turn the power back on.
6. Wait up to an hour for the F1 code to reappear. This could be accompanied by an alert such as a beeping sound.
7. If the F1 code reappears, replace the ERC. If it does not, replace the touch pad.
Posted on May 29, 2010
    Brigadier General:
  • 3,917 Answers
Thanks for contacting Fixya.com
The error code means that the Power to element relay is energized during time of display.
This is a problem in the wiring harness and it is shorted or you need to change the power relay board (PRB). If it is a double oven, you need to change second oven board.
Thank You
If you donot have further queiries please donot forget to accept the solution.
F1 code
Good Afternoon landstardad, thank you for allowing me to assist you!
Typically error code F1 indicates that a runaway temperature (overheating) issue has been detected. Let's try reprogramming your range by either unplugging it or flipping the household circuit breaker off. It is important to wait roughly ten minutes and then turn your range on. If the error code does not clear, at this point, I would suggest contacting a professional to proceed further. Most likely the RTD Probe (Resistance Temperature Detector) or the EOC (electronic oven control) will need replacing. Hope this helps!
Feb 01, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Our oven starts beeping and then displays a F 1 code and shuts down.
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Aug 12, 2011 | Jenn-Air Ovens
F1E1 error happened repeatedly, jenn air says cut
F1 - E1
EEPROM checksum error
1.
Disconnect power for at least 30 seconds.
2. Re-apply power and observe for
at least one minute.
3. If code re-appears, replace control board (also
called ERC or clock).
Note: Applies to all F1-E...
codes except F1-E3.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Jenn
Air Range / Stove / Oven Fault Codes#ixzz19GMNtS3r
Dec 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn air oven door locked after getting an F1 message after the self cleaning was done..help i cant unlock it
F1 touch pad / ERC test This simple test will help determine
whether the ERC (Electronic Range Control or Clock) or the touch pad is
defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single
assembly, in which case this test is not necessary. Simply replace the ERC
(Clock).
Warning: If you feel in any way uncomfortable performing this test or
making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound)
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Dec 10, 2010 | Jenn-Air JJW8530C Expressions Collection...
F1 error code and constant beeping and oven shuts off.
Hi gwhiz03,
If you are having error code F1 with your Jenn-Air double wall oven this is because you have a defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
Hope this helps.
Thank you for using FixYa.
Feb 10, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
F1 fault code on Jenn-Air jwg 8130
hi,
The F1 ErrorOn a number of ranges this can mean a number of things, the most common being a failed ERC(EOC, Clock assembly)or a faulty touchpad. Firstly if you are using a recent Maytag range it may pay to test the oven sensor as described above as this may cause an F1 error if faulty (may apply to some other ranges as well) this is not a common cause but is worth discounting. To check the ERC and touchpad
Gain access to the back of the ERC
Disconnect the ribbon cable that connects the ERC to the touchpad
Check nothing will short when power is reconnected
reconnect the power and switch on
Watch for F1 and listen for the beep
If you get the F1 and the beep this means the fault is with the ERC and it will need replacing
If after 30 mins you do not see the F1 error and hear the beep, replace the touchpad
or follow the link for more info:
http://www.appliancefactoryparts.com/applianceshvac/help-center/fault-codes/fault-codes-ranges.html#Admiral
thanks for your question.
Jan 03, 2009 | Jenn-Air JGW8130DD Gas Single Oven
My oven is in lock mode after i had cleaned it. I can't open it now and the lock light is on.
Control panel and oven door lock
The oven door and controls can be locked to avoid unintended use of the oven. The oven doors and controls cannot be locked if the oven is in use, or the oven temperature is 400°F (205°C) or above. The current time of day will remain in the display when the controls and oven doors are locked.
To lock the control panel and both oven doors:
  1. Press and release Cancel.
  2. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” appears in the display and “Lock” flashes while the controls and oven doors lock. Both oven doors lock. “Lock” remains lit in the display.
To unlock the control panel and both oven doors:
  1. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” disappears from the display and “Lock” flashes while the controls and oven doors unlock.
Dec 22, 2008 | Jenn-Air Electric Double Oven
Oven does not work
According to the manual, the self cleaning latch could be stuck.
If the oven door is open, press STOP/CLEAR to clear display, then depress and hold switch plunger for 6 seconds (Located in the upper right corner of the oven front) and the oven door will unlock.
If the oven door is locked, press STOP/CLEAR to clear the display then apply pressure to the upper right corner of the oven door and the door will unlock. If the "F" code reappears, contact a Sears trained repair specialist.
Sep 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Error code F1
I had the same problem and found this post:
http://fixitnow.com/wp/2006/03/11/maytag-amana-jenn-air-and-magic-chef-range-f1-codes/
The oven had been cleaned earlier in the day and the touch pad ribbon connector was shorting. I cleaned it with rubbing alchohol and blow dried the whole board for good measure. Hooked everything back up and haven't had a problem since.
Jun 08, 2008 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air JJW8230D Electric Double Oven Logo
63 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
