We have a Panasonic TV / VCR combo model PV-M 2079 assembled in January 1999. The programing menu keeps flashing across the screen both in English and I-con format. We lost the remote so have only the buttons on the TV to work with.
  • 566 Answers
Hi there
To answer your question;
The first thing to do is to reset the tv/vcr.
To do that , turn the power on and hold the "play" and "FF" buttons down simultaneously for more than 5 sec, the set will shut off.
When you turn it back on it will be in first time setup.
Then you can use the channel up and down buttons to select the items and vol+ to change the values.
Once the first time setup is done the display will stop flashing.
Hope this help and feel free to ask any question before you accept this answer.
Cheers
Posted on May 29, 2010
  • lc_rehm May 30, 2010
    Followed your first instructions and get a "auto clock set proceeding" then get screen "auto clock set is incomplete -- push action to set clock"
    have pushed channel and vol buttons because I don't have an "action" button, but nothing happens
    tried pushing "stop" which cancels the entire set up procedure. turn tv off then on and the set up screens are still flashing.
    I don't care about the clock can easily do without it.
What is the TV remote controller code for a Panasonic Model # PV-C1320?
Hello
Universal remote codes for Panasonic TV/VCR combo are:-
0374 0381
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Mar 04, 2011 | Panasonic PV-C1320 13 in. TV/VCR Combo
Remote Code for Comcast DVR
See http://www.comcast.com/corporate/customers/customer_support/remotes.html
You will most likely have to use a VCR code and program it to the AUX button.
Feb 26, 2010 | Panasonic PV-C2541 25 in. TV/VCR Combo
I lost my remote control for my tv/vhs panasonic omnivision
how do you access the menu without the remote panasonic omnivision tv vcr combo
Mar 31, 2009 | Panasonic PV-C2010 20 in. TV/VCR Combo
I have a Panasonic TV/VCR combo my kids deleted all the channels out of it, and we don't have the remote. Tried getting codes from the cable company but didn't work. Model # PV-C1321A Model # 120V AC60Hz...
A universal remote can be programmed for your tv/vcr. Then you can access the menu to auto program your tv. Otherwise there should be a button on the front that allows you to access the menu and then auto program the unit.
Feb 18, 2009 | Panasonic PV-C1321 13 in. TV/VCR Combo
Panasonic PV-C2061
simultanosly press STOP/REW buttons on TV unit, menu pops up.
then use VOL and CH button...follow instructions....
Jun 23, 2008 | Panasonic PV-C2061 20 in. TV/VCR Combo
Remote code for PV-M1349
The secret is that the VCR code turns the set on/off and the TV code controlls the volume...try this:
Program the Verizon remote AUX button using the panasonic VCR codes until it turns the set on/off, program the remote for TV using the panasonic TV codes until it controls volume, then program the STB button to control all 3... STB, TV, and AUX. If you are missing any VCR or TV funtions try another respective panasonic code until all functions are available.
Panasonic VCR codes are 1089, 0062, 0189, 0252, 0643, 1062.
Panasonic TV codes are 0277, 0078, 0677, 1437.
To figure this out, I had to use the "what if none of the codes worked" section and figured I'd try the VCR codes since the TV codes would not turn it on/off.
Good Luck!
Nov 25, 2007 | Panasonic PV-M1349 Combo
Panasonic TV/VCR Remote Problem
Hold down the play/repeat button on the TV itself for 5 seconds. That toggles in and out of demo mode. ;)
Nov 17, 2007 | Panasonic PV-M2048 20 in. Combo
Manual code to program remove for panasonic pv m2023
The remote control for Panosonic model 2023 does not work from a distance. But it works close by
Can you help?
Soundar
Nov 15, 2007 | Panasonic PV-C2061 20 in. TV/VCR Combo
Tv Combo will not work with replacement remote
my panasonic tv model no. PV-DF2704, program light is blinking and I don't know how to cut it off. It is causing my tv to cut off. My remote control will not work. I bought it second hand. I program a universal remote and it works for a little while, but I can not set my tv for cable. Please help me if you can.
deborah from Louisville
Nov 12, 2007 | Panasonic PV-DF2704 27 in. TV/VCR/DVD...
Wont' turn on
The unit shutsdown for a reason ,is sensing trouble somewhere,it could be mechanical problem or an electronic problem,either way it needs service.An estimate will tell you whats wrong and if it is worth to you to repair.Good day
Sep 05, 2006 | Panasonic PV-DF2035 20 in. TV/VCR/DVD...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
