Question about Husqvarna 28cc Gas Line Trimmer
Husqvarna 324L 4 stroke, runs fine, but leaks gas, from carb whil
Husqvarna 324L 4 stroke, runs fine, but leaks gas form carb while running
    Problem Solver:
  • 15 Answers
Gasket is worn out. You can buy a generic gasket set from your local lawn shop
Posted on May 31, 2010
Husqvarna 128Ld wont run after 30 seconds
put the correct spark plug in it and no a CJ8 isnt the right plug !!!
Dec 21, 2013 | Husqvarna 128LD 28cc 2-Stroke Gas-Powered...
Husqvarna Problems
Have you changed the fuel tank vent.? Could possibly be a vaccum being created in the fuel tank, starving the carb of fuel.
May 21, 2013 | Husqvarna 128LD 28cc 2-Stroke Gas-Powered...
Spitting gas out of carb with new carb and plugs
could be the coil getting hot and loosing spark
Feb 22, 2013 | Garden
Gas runs through carbarator
if it is a 2 stroke engine replace the carb, if it is a 4 stroke try replacing the needle and seat. if the gas is running through the carb in a 4 stroke make sure you change the oil before trying to start it as you will have gas in the oil thinning out the oil and over filling the crankcase
Feb 12, 2013 | Troy-Bilt Garden
My chain saw will not start. I gave it to a guy who messed up the carb adjustments. Need to know the initial carb setting.
Turn both jet screws CW to stops (lightly), then back each out CCW 1-1/2 turns. This is a basic setting and should allow the engine to start and run. Start the engine and allow to warm up, then pull the throttle full on. Turn the H needle CW until the engine starts to speed up, but still 4-strokes. Correct adjustment is when the engine 4-strokes running free, but immediately 2-strokes when cutting. Release the throttle and adjust L needle so that the engine idles fairly well, but allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Jul 11, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Chain saw carburator settings for husqvarna 61
Turn both screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and the engine should start and run. Allow the engine to warm up, then pull the throttle full on. Turn the H jet screw CW until the engine starts to speed up, but still 4-strokes. Proper adjustment occurs when the engine is 4-stroking, but immediately 2-strokes when cutting. This gives best power and lowest heat. Release the throttle and adjust L jet CW until the engine idles fairly well, but will allow the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Jun 06, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Carb adjustments/ rule of thumb
Assuming that the adjustment screws 'H' and 'L' have slotted heads, turn both CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and the engine should start and run. Allow to warm up, then pull the throttle full on. Turn H CW until the engine starts to speed-up, but still 4-stroking. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and adjust L CW for fairly smooth running, yet allows the engine to 'follow the throttle'. Adjust idle speed so that the chain stops turning, but the engine keeps running.
May 21, 2010 | Husqvarna Chain Saw 20" Bar
4 stroke engine runs then fades, runs then fades- cylcing
You need carburetor work.
Youwill need to disassemble the carburetor and spray withcarb.cleaner.
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
The smoke is more than likely because it is flooding. There's too much fuel getting into the carburetor. The choke may be sticking.
If you need further assistance just let me know.
Jim
Nov 28, 2009 | Husqvarna Garden
I have a husqvarna 55. I put in a new carb, coil,
Preset both needles about 1-1/2 to 2 turns CCW from CW stop. Set H needle first after warm-up. At high speed, engine should 4-stroke with no load, but smooth out with light load(cutting wood). Set idle speed so that it will keep running, then adjust L needle so that engine tries to follow the throttle, but idles fairly smoothly. Readjust idle speed so that the clutch is not trying to drive the chain.
Aug 02, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 28cc Gas Line Trimmer Logo
372 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
