Question about Yamaha HTR-5730 Receiver
Humming coming from the speakers
Five speakers plus Subwoofer connected to a Yamaha HTR-5730 AV Receiver connected to an LG HD TV
  • marilee524 May 29, 2010
    The humming is coming from all speakers. The receiver is actually connected to the Direct TV receiver with audio/video cables (brass connectors).
  • marilee524 May 30, 2010
    It is not a "buzz" coming from the TV set. It is a humming sound coming from the speakers even when the TV is turned off. There has always been a hum, but it seems to be worse since we got the new HD Direct TV receiver.
    Brigadier General:
  • 8,546 Answers
From all speakers?
How is the audio connected to the TV (be specific)?
Keep in mind that a TV is not generally an audio source as its programming always comes from something higher up the audio food chain than itself. Get the audio to your receiver from whatever THAT is, not the TV.
Posted on May 29, 2010
  • David Dunn
    David Dunn May 30, 2010
    I can't make assumptions. That's why I asked.
    Next question, since it wasn't stated: is this just a TV-related audio buzz or is it always there?
    Did it EVER work without the buzz? If so, what changed just before it started?
    Or, you could just offer everything you know and suspect about the symptom and its arrival so we can dispense with wild guesses.
    Does it buzz during speaker set-up?
  • David Dunn
    So is it there when OTHER sources are selected?
    Make sure all analog signal and speaker cables are routed away from power cables and magnetic fields.
    When you got the new box did something change re: the cable TV wiring? Maybe there's a bad coax cable ground or shield connection.
    From my own experience: is there track lighing turned on when it hums?
    Disconnect ALL external devices at the receiver one at a time and see which, if any, have an effect on the hum. Then follow it.
How do I turn the subtitles off for the yamaha HTR-5730 AV receiver? When I hook the cable up directly to the TV, there are no subtitles, but when the video output goes through the receiver, subtitles
The receiver manual may list it under "CC" (closed captions) instead of subtitles. Also, don't just check your AV receiver; try checking the setup menu on your TV, and look at the TV remote. See if there's a CC setting that may be turned on, either through the TV setup (probably under the "Display" or "Video" tab) or because you've accidentally pushed the CC (or Subtitles) button on the TV remote.
Nov 26, 2014 | Yamaha HTR-5730 Receiver
How do I reset my yamaha receiver htr5730
http://www.retrevo.com/support/Yamaha-HTR-5730-Receivers-manual/id/1075bh230/t/2/
Page 52
1 Hold down STEREO on the Front Panel
"Factory Preset" appears on the front panel
2 Press STEREO to select the desired setting.
'Reset' To reset to factory presets
'Cancel' to cancel without making changes
3 Press STANDBY/ON to confirm your selection
Jan 15, 2011 | Yamaha HTR-5730 Receiver
Problem with a subwoofer output..
Check your settings in the Receiver Main Menu. Go to Speaker settings, then to Subwoofer, and select "Yes" or "On" or it may say "LFE or Both" choose "Both" Hope this helps. If you still have a problem, post a comment and I can help you some more
Aug 11, 2009 | Yamaha HTR-5730 Receiver
No sound from surround speakers or rear speaker
is there a switch in the back for surround on/off
Apr 14, 2009 | Yamaha HTR-5730 Receiver
HTR-5930
To get audio from your TV through your AV receiver, please connect stereo audio cables from an available AV input on the rear of your receiver such as D-TV/LD or CBL/Sat. Then refer to your TV owner's manual for more information about audio output to an amplifier. You may have to turn off the internal TV speakers in order to get any output from the TV into the AV receiver.
Feb 17, 2008 | Yamaha HTR-5930 Receiver
My yamaha htr 6050
Make sure you speakers are turned on on the receiver,
Jan 23, 2008 | Yamaha HTR-6030 Receiver
AV Receiver
Hello MCKing,
This is the place you need!!! Just send your question(s) and I'll be happy to help you find a solution.
cancerags
Jan 01, 2008 | Yamaha HTR-5730 Receiver
Connecting a Yamaha VX7 Subwoofer on my Yamaha HTR 5730 AV Receiver
Hello srqwrk,
You can connect the VX7 to the 5730 using an RCA Y cable like the one shown in the picture below. You get your one connection for the receiver and 2 for the VX7. These are available at any electronics store. Remember that the cable should be long enough to go from the receiver to where subwoofer will be placed.
Hope this helps. Let me know.
cancerags
Nov 26, 2007 | Yamaha HTR-5730 Receiver
Yahama HTR-5730
Here's the manual; http://www.yamaha.ca/av/PDFs/Manuals/2004_receivers/HTR5730E.asp See if you find a solution in there - if not please ask again and we will see what we can do :)
Apr 16, 2007 | Yamaha HTR-5730 Receiver
Yamaha HTR-5730 Receiver Logo
239 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
