Question about Yamaha Full-Size Keyboard
Hey there. I am looking to a part for my dgx 505.
Hey there. I am looking to a part for my dgx 505. Sustain input board with lcd contrast knob on it. Part number? It also has the usb input on the same circut board. I tried to fix a problem with the sustain pedal input, (resolder) but may have crossed something else?? My lcd display is fully dark. Dont know what to do.
Thanks for any infol
nick
  • 4,737 Answers
Even if it's dark can you see the displayed images/text/numbers? If so, it's clear that your Lcd is not receiving one input from the Pcb, I think there's no damage yet. This should be only with the display cable and the connectors, maybe on the display terminal or on the pcb terminal. Open the unit and again refit the lcd connector (flex cable). That'll fix your problem. Recently one of my friend had the same problem after we cleared out some dust. Hope this helps. Good luck. Thanks for using FixYa.
Posted on May 29, 2010
I have a yamaha DGX-620 but the screen is blue with some lines Please tell me what to do !!!!
Could be bad connection of the LCD glass to it's socket.
You need a specialist to look at that, very delicate.
If not----
Change the screen, probably the whole board with driver chip. Check with Yamaha.
Nov 24, 2017 | Yamaha Music
How do I adjust the screen contrast on this keyboard?
The contrast control knob is on the rear panel of the instrument.
Oct 20, 2015 | Yamaha YPG-535 88 Portable Electronic...
Screen is blanck can not see any of the database
If you haven't already, try to adjust the LCD Contrast by rotating the knob on the rear of the keyboard. If that doesn't help and if every thing else functions the Contrast pot is damaged or the LCD needs to be replaced. Those would be the most likely causes.
Dec 11, 2014 | Yamaha DGX 640 Keyboard Arranger
Yamaha dgx 620
Which connector are you looking for?
If mains adaptor input then try here
http://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idproduct=17018
Jan 21, 2014 | Music
I have a dgx-505 yamaha without the installation cd and i want to use it with my computer HP Windows 7 64bit. All the drivers i found only worked on XP, 98/99 and 32 bit.... PLEASE HELP ME!
I know this is an old post, but I just found my own solution to the same problem. I downloaded the 64 bit driver for the CP300 keyboard and it worked.
Sep 14, 2011 | Yamaha Full-Size Keyboard
I have a Yamaha dgx 330. I was playing it at my gig when all of a sudden my sustain pedal stopped working. It was working fine right before that. I could only play fast songs after that. I also have a Dgx...
Two possibilities come to mind.
These footswitches DO go bad and require servicing (east to work on) either cable breaks someplace due to vibration and flexure or the contacts get dirty inside... simple to disassemble and clean.
The other thing is polarity. I know you said it isn't polarity, however should you be holding or not holding it down and the power glitches, the keyboard may read a NEW polarity. Often the power can be very "dirty" at venues. Also sometimes the power cord connector can become marginal causing momentary power loss... USUALLY you would notice this happening.
Mar 06, 2011 | Music
A bought an Yamaha DGX 640 grand a week before and the note sustain for a longer duration and overlaps with the current playing notes. I checked the sustain in the function setting and it is also showing ...
The function setting is for the PANEL sustain (Page 68 of your manual)
The other method of sustain is by footswitch or pedal option. See page 13.
If you use a footswitch, it needs to be a normally open contact type. If you plug a Roland type in, it is opposite polarity and will sustain UNLESS the pedal is pressed. Make sure nothing else is plugged in the sustain jack... headphones that are inadvertently plugged in there would sustain.
Mar 06, 2011 | Yamaha DGX640 Music Keyboard
Yamaha Full-Size Keyboard Logo
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
