Question about Brother XL-2600
Take apart Brother xl-2600i
I am trying to open up a brother xl-2600i after it stopped working. (Motor works but needle does not move. Already tried bobbin settings). I have removed all screws from the back. Its seems to be stuck at the top part of the machine. I do not see any screws in that area.
  • anantshah Jun 01, 2010
    Need documentation/instructions on how to open up brother xl2600i
  • 10,865 Answers
Hello. Get a can of a penetrating lubricant called WD-40 with a tiny application tube. Give the problem area a squirt and let it sit for a few hours while the lube penetrates and lubricates the mechanism. This alone may solve your problem. J.
Posted on Jun 01, 2010
  • 652 Answers
May need to pry open off clips. Sounds as if belt may be broken.www.thefind.com/search?query=brother+xl2600i+parts
Posted on May 29, 2010
  • anantshah May 29, 2010
    I am trying to pry it open but seems like something is holding it back from the center of the machine where the wheel is in the front of the machine. Is there some kind of instructions somewhere? I checked the user manual and it does not have any.
Brother xl 2600 needle hitting feed dogs
Could be several reasons! Check that your needle is not bent, Make sure that you are using the needle is the needle size required BT specific machine. Make sure timing is checked by ttechnician.
Jul 05, 2014 | Brother XL-2600I
I just bought a brand new Brother XL 2600I and it was working great for the first day , next morning i change the thread to actually sew not just test strips . I keep getting bunches of thread or if i
Most likely your top thread is not threaded correctly. Unthread and rethread. Check with your manual to make sure you have threaded correctly. Thread bunching up on bottom indicates top thread is threaded wrongly.
Mar 05, 2014 | Brother XL-2600I
Brother XL-2600i upper tension too tight even when set to ZERO
I agree with you to take it back & buy another brand
Sep 30, 2012 | Brother XL-2600
Brother xl-2600I
try changing the needle
try tightening the top tension one number or letter at a time till the stitch look better
take the bobbin out & reinsert the bobbin into the bobbin case, also make sure the bobbin is not damaged
clean under the needle plate & in the bobbin area for loose threads or lint
May 22, 2012 | Brother LS-2125 Mechanical Sewing Machine
Thread jamming
try changing the needle-flat side goes to the back of the machine
rethread the machine top & bobbin--make sure to use every top thread guide
clean under the needle plater & in the bobbin area for lint or loose threads
make sure the thread doesn't come off the thread take up lever
Apr 03, 2012 | Brother XL-2600I
Can't sew because my bobbin doesn't work
it's very possible that the sewing machine is out of time
sewing machine shop can tell you for sure
Feb 26, 2012 | Brother XL-2600I
Needle hitting bobin case and case is loose. How do i fix it?
sounds like you need a new bobbin case
try a new needle & if it still hits the bobbin case the machine could be out of time
& would have to be retimed at a sewing machine repair shop
Feb 15, 2012 | Brother XL-2600I
Using a universal pleating foot, starts out fine then I break a needle, 5 so far. It hist the pressure plate. Using a straight stitch, needle is centered. Bobbin is treaded correctly. Needle is straight at...
Sounds like the needle is hitting the moving part of the pleater once you get going, getting bent then striking the needle plate too.
Its not going to do the machine any good if you keep striking it with the needle as you'll end up putting the timing out.
As the pleater is a generic type it is probably best to stop trying to use it on your machine.
Jun 26, 2011 | Brother XL-2600I
Brother XL-2600 Logo
689 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
