Question about Kenmore 22422 Top Load Washer
Remove control console
How do you remove the control console?
    President:
  • 1,937 Answers
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Next, see the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=21da0f4d3ec79a79606fdc2a913c8c7c
Some washers don't have endcaps that pop off.
For these, slip a thin wide blade putty knife from the front of the washer under the ends of the console and you should be able to feel a clip disengage.
Posted on May 29, 2010
How do I remove the center console of a Isuzu Ascender
why not read on alldata.com, its all there,
remove a screw?
  1. Block the wheels to prevent the vehicle from moving.
  2. Remove the rubber ash tray inserts and rubber mat from the console.
  3. Remove the floor shift control knob. Refer to Floor Shift Control Knob Replacement.
  4. Remove the center console shift lever bezel, Buick only. Refer to Console Shift Lever Bezel Replacement (Refer To List 1).
  5. Remove the console storage compartment. Refer to Front Floor Console Compartment Replacement.
  6. Remove the center console retaining screws.
  7. Adjust the parking brake to the full-up, or fully engaged position.
  8. Release the 2 forward trim extensions ears attached to the lower instrument panel (I/P), Buick only.
  9. Slide the console rearward and raise the rear of the console in order to expose the electrical connectors.
  10. Disconnect the electrical connectors, as necessary.
  11. Adjust the parking brake to approximately the halfway position.
  12. Remove the center console from the vehicle.
  13. If replacing the floor console base, remove the following and retain for transfer:
    • 13.1.
      Remove the HVAC control module (if equipped).
    • 13.2.
      Remove the armrest.
    • 13.3.
      Remove the HVAC module and duct assembly.
    • 13.4.
      Remove the cupholder.
    • 13.5.
      Remove the HVAC upper duct.
or read the FSM (buy one) factory service manual, its all there every step and photos too, (all cars. are like that)
or
http://www.scantool.net/software/alldata-diy-1-month-subscription.html
log in, and see that. and more.
Feb 05, 2015 | 2006 Isuzu Ascender
I just read you post on replacing the heat controls on my 1998 Ford Contour. Thanks for the good reply. A few more questions on that, Can I replace only the selector switch DEFROST/AC/FLOOR/PANEL? Do I...
SECTION 412-04: Control Components 1998 Contour/Mystique Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 09/14/2001 Climate Control Assembly Removal
  1. Remove the radio chassis. For additional information, refer to Section 415-01.
Audio Unit
Special Tool(s) st1445a.jpg Remover, Radio
415-001 (T87P-19061-A)
Removal
  1. NOTE: Make sure the audio unit key code is available before disconnecting the audio unit electrical connectors and note the audio unit station presets.
    Using the special tool, detach the audio unit.
    • Insert the Radio removal tool into the locating holes until they click into place.
    1. Pull the tools gently to the left and right of the audio unit to release the locking tangs.
    1. Pull the audio unit out of the instrument panel.
  1. Remove the audio unit.
    1. Disconnect the power electrical connector.
    1. Disconnect the audioline/speaker electrical connector.
    1. Disconnect the antenna cable.
Installation
  1. NOTE: When installing the audio unit make sure the rear support engages on the carrier.
    To install, reverse the removal procedure.
    • Enter the audio unit keycode and re-program the pre-set audio unit stations
  1. Remove the floor console. For additional information, refer to Section 501-12.
Floor Console - Vehicles with Automatic Transaxle Removal
  1. ani_caut.gif WARNING: Wait at least one minute after disconnecting the battery cables before removing the floor console. Failure to follow this instruction may increase the possibility of accidentally deploying the air bag(s) and may cause personal injury.
    Disconnect the battery ground cable.
    • Wait one minute.
  1. NOTE: Contour shown, SVT similar.
    Remove the rear floor console screws.
    • Move seat fully forward.
  1. Fully apply the parking brake.
  1. Detach the shift indicator selector bezel.
  1. Detach the shift bezel from the selector housing.
    1. Remove three bolts.
    1. Detach shift bezel from the console.
  1. NOTE: The rear floor console must be raised to disengage the front retaining clips.
    Raise and remove the rear floor console.
  1. Remove the four front floor console retaining screws.
  1. Detach the front floor console.
    1. Set the gearshift lever into position 1.
      Partially remove the front floor console.
  1. Disconnect the cigar lighter electrical connections and remove the front center console.
  1. Remove the control opening finish panel.
    1. Remove the four screws.
    1. Disconnect the headlamp dimmer switch electrical connector.
    1. Remove the panel.
  1. Remove the climate control assembly screws.
  1. Remove the climate control assembly.
    • Disconnect the electrical connectors
    • Disconnect the vacuum harness connector.
Feb 01, 2011 | 1998 Ford Contour
Only cold air is available, what can I do to fix the blend door temporarily
I would repair the problem if I have to disassemble the varioius parts to get at the air doors --- In-Vehicle Temperature Sensor Removal & Installation To Remove:
  1. Remove the climate control head.
  2. While pressing the retaining tabs inward, remove the in-car temperature sensor.
To Install:
  1. While pressing the retaining tabs inward, install the in-car temperature sensor.
  2. Install the climate control head.
Air Door Actuators/Motors Removal & Installation Air Inlet Door (Recirculation) Vacuum Motor To Remove:
  1. Remove the instrument panel.
  2. Remove the air inlet door motor mounting screws. CAUTION
    Do not attempt to bend any part of the air inlet duct door lever.
  3. Rotate and remove the air inlet door vacuum control motor.
To Install:
  1. Rotate and install the air inlet door vacuum control motor.
  2. Install and tighten the mounting screws.
  3. Install the instrument panel.
Defroster Door Vacuum Motor To Remove:
  1. Remove the passenger air bag module from the instrument panel.
  2. Disconnect the vacuum line and remove the mounting screws. CAUTION
    Do not attempt to bend any part of the defroster airflow mode door lever.
  3. Rotate and remove the vacuum control motor from the defrost door lever.
To Install:
  1. Rotate and install the vacuum control motor on the defrost door lever.
  3. Connect the vacuum line to the vacuum control motor.
  4. Install the passenger's air bag module.
Floor Console Register Duct Vacuum Motor To Remove:
  2. Remove the right-side instrument panel insulator.
  3. Working from the passenger's footwell, disconnect the vacuum hose.
  4. Remove the screws and the floor console register duct vacuum control motor. CAUTION
    Do not attempt to bend any part of the floor console register duct door lever.
  5. Rotate and remove the vacuum control motor from the floor console register duct door.
To Install:
  1. Rotate and install the vacuum control motor onto the floor console register duct door.
  3. Connect the vacuum hose to the floor console register duct vacuum control motor.
  4. Install the insulator under the dash.
  5. Install the floor console.
Panel/Floor (Heater Air Damper) Door Vacuum Motor To Remove:
Panel/floor door vacuum control motor shield ford-10-00-403.gif
  1. Working through the driver footwell, remove the two screws and the shield. CAUTION
    Do not attempt to bend any part of the airflow mode door lever.
  2. Label and disconnect the two vacuum hoses.
  3. Remove the vacuum control motor mounting screws.
  4. Lift, rotate and remove the panel/floor (heater air damper) door vacuum control motor from the door lever.
To Install:
  1. Install the panel/floor (heater air damper) door vacuum control motor on the door lever.
  3. Connect the vacuum hoses in their original positions.
  4. Install the shield on the vacuum motor.
Temperature Blend Door Actuator To Remove:
  1. Remove the integrated control panel.
  2. Remove the right-side lower instrument panel insulator.
  3. Lower the glove compartment.
  4. If equipped with Electronic Automatic Temperature Control (EATC), remove the 2 remote climate control module screws and position the module aside.
  5. Remove the temperature blend door linkage shield.
  6. Disconnect the temperature blend door electrical connector.
  7. Remove the temperature blend door actuator mounting screws.
  8. Remove the temperature blend door actuator.
To Install:
  1. Position the temperature blend door actuator on the plenum.
  2. Install the temperature blend door actuator mounting screws.
  3. Connect the temperature blend door electrical connector.
  4. Install the temperature blend door linkage shield.
  5. If equipped with Electronic Automatic Temperature Control (EATC), reposition the remote climate control module and install the 2 mounting screws.
  6. Raise the glove compartment.
  7. Install the right-side lower instrument panel insulator.
  8. Install the integrated control panel.
Nov 05, 2010 | 2000 Ford Taurus
How to fix my Whirlpool Cabrio washing machine F1 code that keeps popping up whenever I turn on the washing machine.
Hello, error F1 means primary control failure and to resolve this you’ll have to replace the machine control assembly. To remove and replace the control you’ll have to unplug the washer and then remove three screws from the rear of the console assembly. Pull console towards front of washer to hinge open and/or remove console. Then remove the one screw holding the machine/motor control assembly to the console tray and two plastic legs on the rear of the machine/motor control assembly that fit into the console tray.
Thanks
Jun 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Cuts off on F1. have to rest several times
Keypad/User Interface Failure
A fault code of "F" then "1" flashes when there is a primary control failure.
You will need to replace the machine/motor control assembly.
Page 14 and 16, in the manual link below will help you with this.
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
To Access/replace the CCU:
#1
Unplug the Whirlpool Cabrio power cord from the wall outlet. Turn off the water supply to the washing machine. Pull the washer away from the wall so that you can access the screws behind the control console. Remove the hex head screws securing the control console to the washer with a nut driver. The screws are on the lower rear edge of the control console.
#2
Lift the control console up, and rotate the console forward so that the face of the console is resting on the top of the washer. Locate the interface board cable connector to the right of the plastic tube on the back of the console. Pull the end of the connector straight out of the control console. The primary machine control is the box that the plastic tube connects.
#3
Place small pieces of masking tape around the nine wires connecting to the primary machine console. Label the wire locations onto the masking tape with a pencil. Grasp each wire at the connector with your fingers, and pull the wires away from the primary control. Pull the plastic tube out of the primary control.
#4
Locate the nut toward the bottom of the primary control. Remove the nut with a nut driver. Lift the front of the primary control slightly, and slide it down to disengage the retaining clips. Pull the primary control out of the control console. Insert the new primary control into the control console. Slide the primary control up to engage the lower clips. Secure the primary control to the console with the single hex head screw.
#5
Push each of the wire connectors into their respective positions on the primary control until they lock into place. Push the plastic tube hose over the port on the right side of the primary control. Remove the small pieces of masking tape from the wires.
#6
Position the control console back upright on the top of the washer. Secure the control console to the washer with the three hex head retaining screws. Slide the washer back against the wall. Turn on the water supply and plug the washer into the wall outlet.
TECH SHEET LINK: http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567037.pdf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$%
May 05, 2010 | Whirlpool WTW6400SW Cabrio Washer
It stops working and we get code F1.
#1
#2
#3
#4
#5
#6
Feb 20, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I need to change the gear selector knob how does
Shift Control Linkage The transmission range selector control linkage consists of the following components:
  • a floor mounted transmission range selector lever.
  • a transmission control switch on the transmission range selector lever.
  • a cable connecting the transmission range selector lever to the transmission manual control lever.
  • a brake/shifter interlock system.
  • an ignition/shifter interlock cable (3F719) connecting the reverse kick down spring (7219) to the steering column lock assembly.
Section 07-05: Transmission, Automatic—External Controls 1996 Mark VIII Workshop Manual
REMOVAL AND INSTALLATION Gearshift Lever Removal
  1. Place transmission range selector lever in OVERDRIVE. Remove console finish panel (04567). Refer to Section 01-12 .
Console Panel, Floor Removal and Installation
  1. Remove gearshift lever. Refer to Section 07-05 .
  2. Remove center A/C-heater instrument panel finish panel (04338).
  3. Remove instrument panel finish panel (044D70).
  4. Remove two screws retaining console finish panel (04567) to radio control cover (04530).
  5. Unsnap RH rear corner of console finish panel and then disengage three retaining clips from LH rear corner.
  6. Disconnect cigar lighter socket and retainer (15055), lamp and switch connectors and remove console finish panel.
  7. Remove two screws retaining console panel (045A36) to instrument panel (04320).
  8. Open glove compartment door (06024) and remove console glove compartment mat (047A74) in bottom of console glove compartment (06010) to gain access to two console panel-to-instrument panel console bracket retaining screws. Remove screws.
  9. To remove, slide console panel rearward and up.
  10. To install, reverse Removal procedure. Tighten screws to 1.5-1.9 Nm (13-17 lb-in).
Item Part Number Description 1 046A44 Radio Finish Panel Assy 2 047A74 Console Glove Compartment Mat 3 045A36 Console Panel 4 N804234-S36 Screw (2 Req'd) 5 N800322-S36 Screw (2 Req'd) 6 N805180-S58 Screw (2 Req'd) 7 N806577 Nut (2 Req'd) A — Tighten to 2.5-3.1 Nm (22-27 Lb-In)
  1. Remove brake interlock cable and disconnect cable from range interlock cam.
  2. Disconnect transmission range indicator lamp/TCS electrical connector.
  3. Raise vehicle on hoist. Refer to Section 00-02 .
  4. Remove range cable retaining nut from transmission bracket. Disconnect shift cable and bracket (7E395) from transmission control selector connecting rod adjustment stud (7B415).
  5. Lower vehicle. Remove range selector lever and housing retaining bolts and remove gearshift lever (7210).
Installation
  1. Install transmission range selector lever to front floor pan (11135) with retaining bolts. Tighten to 6-8 Nm (4-6 lb-ft).
  1. Connect shift cable and bracket. Tighten retaining screw to 3-4 Nm (25-35 lb-in). Install retaining clip and connect transmission range indicator lamp wire.
  1. Install console finish panel.
  1. Place the transmission range selector lever in OVERDRIVE and apply a 1.4 kg (3 lb) rearward force to the lever.
  1. Raise vehicle on hoist. Refer to Section 00-02 .
  1. Connect theshift cable and bracket to the manual control lever (7A256) and transmission bracket. Make sure manual control lever is in OVERDRIVE and tighten nut at bracket to 13-25 Nm (10-18 lb-ft).
  1. Lower vehicle and check range selector for proper operation.
Dec 07, 2009 | 1994 Lincoln Mark VIII
Will not begin cycle. F1 appears
#1
#2
#3
#4
#5
#6
Dec 02, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
How do you remove or replace the passenger airbag on a 99 contour , Is it a whole dash unit? What holds the drivers bag in the steering wheel? I assumed it was a tork but not sure. Where is the control...
Please rate as fixya if this helps.
the air bag control module is under the console.
  1. Disconnect the battery ground cable.
    1. Wait one minute.
  2. Remove the center console. For additional information, refer to Section 501-12 .
  2. Wait one minute.
  3. NOTE: Contour shown, SVT similar.
    1. Move seat fully forward.
  1. Disconnect the air bag control module electrical connectors.
    1. Depress the locking tang.
    1. Slide the locking bar back.
    • Disconnect the connector.
  1. NOTE: The air bag control control module is grounded by the retaining bolts.
    Remove the air bag control module.
    • Remove the three bolts.
driver air bag module
  1. Disconnect the battery cables.
  1. Rotate the steering wheel 90 degrees to access and remove the Torx screw. Rotate the steering wheel 180 degrees to access and remove the Torx screws.
  1. Remove the driver air bag module.
    • Disconnect the electrical connector.
    • Remove the air bag module.
  1. Disconnect the battery cables. For additional information, refer to Section 414-01 .
  1. Open the glove compartment, press the sides inward and lower the glove compartment to the floor.
  1. Remove the passenger air vent duct.
    1. Disconnect the duct from the heater box housing.
    1. Disconnect the duct from the instrument panel register and remove.
  1. Disconnect the passenger air bag module electrical connector.
  1. Remove the two retaining bolts securing the rear of the passenger air bag module to the cross-vehicle beam.
  1. sxp~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Support the passenger air bag module when removing the retaining nuts.
    Remove the two nuts from the front of the passenger air bag module.
  1. Remove the passenger air bag module.
    • Lower the front edge of the passenger air bag module, roll the passenger air bag module around the cross-vehicle beam lowering it into the passenger footwell.
Mar 15, 2009 | 1999 Ford Contour
How can i find out my parking brake adjustments on my 2003 ford escape?
Parking Brake Cable Adjustment Vehicle with low series floor console
  1. Remove the floor console front finish panel.
    1. If equipped, remove the manual transmission shift knob by turning counterclockwise.
  1. Remove the floor console rear finish panel.
    1. Apply the parking brake.
Vehicle with high series floor console
  1. Remove the floor console finish panel.
All vehicles
  1. Remove the adjustment nut clip.
  1. Turn the parking brake control adjustment nut so that the parking brake control stroke is three to five notches when pulled.
  1. Confirm the parking brake is applied.
  1. Install the adjustment nut clip.
  1. Install the floor console rear finish panel.
  1. Install the floor console front finish panel.
    • If equipped, install the manual transmission shifter knob by turning clockwise.
Jan 21, 2009 | 2003 Ford Escape
Kenmore 22422 Top Load Washer Logo
35 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
