Question about Brother DCP 115C All-In-One InkJet Printer
Cyan=blue??? - Brother DCP 115C All-In-One InkJet Printer
  • 1,110 Answers
Yes, in the color printer/copier industry, Cyan is the same as Blue.
Posted on May 29, 2010
Testimonial: "tnx"
Printer will not print blue, prints pink instead
Blue is made from magenta (pink) and cyan ( sky blue), if your blues are coming out pink then they are missing the cyan component.
In your machine this could be caused by a blockage in the printhead, the cyan cartridge being empty, an electronics fault, a boma pump fault (the squishy black thing on the base of the cartridge). Check your cartridge first - if it feels lighter than the other it is probably empty. Sometimes there is a fault where the entire contents of a cartridge (usually the cyan) can be emptied in a matter of days or less. If the cartridge is unusually empty compared to the other colours - refer it to HP.
Mar 13, 2015 | HP Officejet Pro L7780 All-In-One InkJet...
I have a KonicaMinolita Magiccolor 3730DN. It's showing a Fatal error code OF54H.
Cyan image unit is having problem getting it toner or the toner for cyan bad also the cyan image unit are either the drum or the toner 3 party if they are GET the right ones MINOLTA>
CYAN=BLUE
Jan 29, 2014 | Minolta magicolor 2200 DeskLaser Printer
Instead of Bule print DC12 prints Violet
Hi there! The blue color is becoming violet because the Cyan and the Magenta toners are not getting mixed in the proper 100:100 ratio (100% Magenta and 100% Cyan make CMYK Blue). Since the print is violet, the culprit is the Cyan toner. Now, first, get the Cyan Developer Assy checked if there is enough developer in it. If no, get it refilled by a proper tech and manually mix about 50 grams of the Cyan Toner with the developer. Also get the tech to check the trimmer gap on the Developer Assy with a metering gauge. If yes, next check the Cyan dispenser motor located on the backside of the Toner Housing Assy. It is probably broken and not dispensing any toner to the Cyan Developer Assy . Additionally, check for the Cyan Dispenser Auger blockage or jam. It is located under the Cyan Toner Cartridge in the Toner Housing Assy and also check the auger under the Cyan Developer Assy. After sorting these out, you should get proper CMYK blue from the 10th or 12th page once you resume printing.Let me know. Regards
May 26, 2011 | Xerox DocuColor 12 Color Copier
I just replaced the cyan cartridge and I get 4 blue lines that print where they should not be. If I print a blue picture - those line tend to be a lighter blue. I have taken the cartridge out and replaced...
Obviously you need to return the Cyan cartridge to where you got it. It is bad. Is it OEM Samsung or is it remanufactured. If it is remanufactured then it will usually say "for use in" or "remanufactured" somewhere on the box.
Either way it sounds like you need a replacement cartridge under warranty.
Sep 14, 2010 | Samsung CLP-600N Laser Printer
What is cyan ink
It must be referring to the cyan color cartridge.
"Cyan" refers to the blue-green color cartridge.
Most printers have either 2 cartridges (black and multicolor), or 4 cartridges( black, magenta, yellow, and cyan).
See here:
http://en.wikipedia.org/wiki/Cyan
Hope this helps.
Jan 13, 2010 | Brother MFC-5440CN All-In-One InkJet...
Installed a new cyan cartridge, but the blues show up as pink..
I can assure you that you got a bad colour ink cartridge. However, you may try this: get a small ply of tissue paper and place over the printing head, with your mouth and some good measure of pressure **** it. Repeat a couple of times and all the three colours: cyan, magenta, and blue will show up; otherwise replace immediately. Good luck
Apr 30, 2009 | Xerox Phaser 6180N Laser Printer
HP CP1700 - no cyan or blue printing
Try taking a look at your printheads. Have they been installed for some time. You may need to change them. Start with the Cyan first.
Inkworks
866-381-0541
Oct 24, 2008 | HP cp1700 Color Inkjet Printer
Cyan toner does not rotate to front to be change
um... Cyan is blue isn't it?
Magenta Pink,
Yellow = Yellow and
Black = black.
Oct 02, 2008 | Dell 3010cn Laser Printer
Printer turning page blue
Color copiers have four drums. black, yellow, cyan(blue) and magenta. try making a copy in single color mode. make one in all the colors mentioned above. If they all come out normal and the cyan (blue) one doesnt, this could indicate a bad cyan (blue) pcu and or developer.
Apr 09, 2008 | Office Equipment & Supplies
Brother DCP 115C All-In-One InkJet Printer Logo
51 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
