Washer leaks water seem to leak from left side running inside the front panel(left side facing you)
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the section for the basket and tub assembly's
I'd pull the cabinet in order to get to the hoses going to and from the pump first.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
If the hoses are fine, check the shaft from the motor to the pump and check inside the pump to make sure the inlet and outlet aren't blocked.
I'd also check the gaskets at the bottom of the tub.
If you're reasonably mechanically inclined, these are easy fixes.
If you have to get to the gaskets at the bottom of the tub, see the following for how to remove the agitators, pump, motor, transmission, spin tube and basket.
(It sounds a bit complicated but it's not really that difficult.)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
You don't have to buy a special spanner wrench to remove the spanner nut. I've used a short 10" pipe wrench hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
As an aside, see the following Whirlpool Service Manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Depending on the problem (hoses or gasket) it's certainly less expensive than calling in a repair person.
Posted on May 29, 2010
Leaking water
What is the model number of your unit?
Nov 20, 2012 | Washing Machines
Bosch WFVC6450UC Washer leaks at bottom
How about loose fill hose connections?
How about incomplete shutoff of the internal fill control valve between wash cycles?
Sep 22, 2012 | Bosch WFVC6450UC Front Load Stacked Washer...
My Kenmore 700 series washer has been leaking water. When the tub is filling with water, water seems to leak along the front bottom edge of the machine in several areas. I'm left with a huge puddle of...
First ck to see if your water pump is leaking. It normally leaks when the machine is running not just filling. Also look at all the attaching rubber hoses under the machine and see if water is leaking down the back right side of the machine and then running around the frame to the front long shot but possible.
Aug 11, 2010 | Kenmore 15864/15862 Top Load Washer
Ge front loader leaks when filling
Leaks are probably going to come from one of 4 places:
  1. Door gasket: water should run down the face of the washer from the lowest point of the door.
  2. Water connectors: left rear of machine
  3. Soap drawer: water running down front of machine from the upper left-hand side
  4. Discharge pump and hoses: Right side.
Rear right would probably indicate a discharge hose leak. Front right would most likely be the discharge pump and/or connectors to it. Here's a diagram:
If you don't see any of the easily visible leaks (door, soap dispenser, connectors), try to
pop off the front access panel by removing the 3 bottom screws. Once removed try to determine where the leak is originating from...then we can troubleshoot more. If you find this advice helpful, please don't forget to rate me -- trying to get my Guru level so I can offer premium support
Jun 23, 2010 | General Electric WCVH6800J Front Load...
Washer is leaking. If facing washer, water is on
probablly water pump or hose tilt machine to view where water is coming from
Jan 17, 2010 | Kenmore HE2 Plus Front Load Washer
Whirlpool Front load washer - Water leaking
I would check to see if you have a hole or crack in the rubber boot inside the door. Open the door and seperate the fold in the rubber boot and check for a leak. If something sharp was left in someones pocket it will get stuck in this part of the bood.
Dec 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hi there... My Whirlpool Duet washer has recently sprung a leak! It leaks a small stream of water out of the bottom left side (as you would look at it from the front) and runs down the stand to the floor....
I had the exact same problem on my Whirlpool front loader (model# GHW9100LW1). It turned out to be a tear in the rubber drain hose (from tub to pump). There seemed to be some debris caught up in the drain hose, and what really did the damage was a piece of metal wire that broke off one of my wife's bra straps and made a nice tear in the hose. The washer leaked out of the left side as well and down the pedestal. The drain hose only ran about $13.00. To get to the hose you will have to remove the front tub seal (bellow) and the panel just above the pedestal. While you're in there it would be good to clean out the filter cap for the drain pump as well. Good luck!
Nov 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag A482 washer from 1985. Leaking water from
probably has a pin hole leak where it has been rubbing the tub. Does the tub have a seal at the top of it where it meets the top. Could be the seal is going bad.
Sep 07, 2009 | Maytag PAV2300 Top Load Washer
Water leak at front of washer
You should have a drain at the bottom of the rubber boot inside the washer. There is a possibility the drain hose clamp came loose or the boot has a hole in it. If you take the front of the washer cabinet off, you should be able to see where the water is coming from. Take the two screws out of either side of the door opening, pull on both sides of the front panel at the same time, tilt downward, and the panel should come off.
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
88 people viewed this question
Top Washing Machines Experts
