Question about PNY 2GB microSD Memory Card
Hi I'm trying to add pictures to my sd card using the adapter that it came with but it's say that the disk is protected I didn't put any potection on it. I see a lock arrow on the adapter but I don't see a lock switch. Just a empty space
  • 1,555 Answers
Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
Posted on May 29, 2010
WRITE potect
You didn't specify the make and model of your camera, so I'm assuming it uses SD cards.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 28, 2013 | Cameras
I was trying to upload pictures from a Olympus VG-110 micro sd flash drive. and i couldn't see the files saved in it.. why is this happening? Then we put the back the disk in the digicam and after turning...
SD cards (and most microSD adapters) have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
And yes, formatting the card will delete all the pictures on it.
Sep 13, 2013 | Olympus Vg110 Vg-110 Red Digital Camera...
Unwrite protect Micro SD card?
You have to be the computers administrator to change any values on any hard drive on your computer
click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
click start click to open on my computer you should see your sd card drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your sd drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
Jun 22, 2012 | SanDisk 4GB microSD High Capacity Memory...
How do i remove write protection from a camera disk?
You didn't specify the make and model of the camera or the type of "camera disk", so I'm going to assume your camera uses SD cards.
Oct 10, 2011 | Cameras
Everytime i try to take a picture it saysmemory card is protected reset switch on memory card
You didn't specify the make and model of your camera, so I'm assuming it uses SD/SDHC cards. If it doesn't, please reply to this post and provide additional details.
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jul 27, 2011 | Cameras
How do I remove write protection from micro scan disk chip?
if you will look into the side of your SD CARD. theres a small toggle switch there. just slide it to the other side inorder to disable the write protection
Apr 03, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How do I use the mico sd card on this player?
I would recommend here:
http://www.newegg.com/product/ProductList.aspx?N=2070070068+1053118914&Submit=ENE&SubCategory=68&Tpk=micro%20sd
It honestly doesn't matter what brand of micro SD you stick in your MP3 player, so I wouldn't worry too much. Micro SD's are much smaller, so no, you can't use a normal SD in a Micro slot. Most however do have an SD "shell" that you can stick your Micro into, and use just like a normal SD card. Also I know that MOST mp3 players allow you to add pictures, videos, etc, and having a Micro SD inside should allow you to add things directly onto it, so i dont see why you wouldnt be able to access the contents of the Micro from your MP3.
Hope this helps! :)
May 28, 2009 | Sylvania SMPK8854 Digital Media Player
My SD memory card says its "unwriteable"
There is usually a switch on the adapter you are using that is there for write protection. The Micro sd card does not have one. Make sure it is not in the lock "position". See this website for more on memory cards and common problems. http://www.retire-asia.com/microsd.shtml I cut a little piece from the site that might help you
"There is no switch on the Micro SD card itself, but a standard-size-SD adapter (which the MicroSD needs to be plugged into for use with a card reader) and SD cards such as the SanDisk 4/8GB have a sliding write-protect switch similar to a 3.5 inch floppy disk. Data cannot be written if the slider tab is in the 'lock' position. The tab could be damaged or missing altogether. This is probably the first thing to check if you have an SD card write error problem. Using sticky tape (Scotch tape etc) to cover the switch slot might solve this problem, but it may need two or more layers before it works. Some SD adapters need the tab to be placed somewhere between the lock and open positions before data can be written to the card."
Mar 03, 2009 | SanDisk 2GB microSD Memory Card
Copying pictures from computer to memory card
i have seen this error and i dont know why it does that. you may want to try buying a micro disk setup that fits into a sd adapter that will fit in your camera.
then you can take out the micro disk when full and put it on a usb adapter and plug right into a usb port.
i know this sounds like more work but so far i havent had a lock up on that or error yet. go to tigerdirect.com if you want to see the different adapters for the sd disk and micro disk and usb etc....
maybe this might help
Jun 22, 2008 | Kodak EasyShare C330 Digital Camera
Motorola i880 phone.
check that the write protection on the disc is not on its a little switch on the card
Dec 04, 2007 | Motorola Mobility i880 Cellular Phone
PNY 2GB microSD Memory Card Logo
282 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
