Question about Garmin StreetPilot C330 GPS Receiver
Garmin c330 download problems
I have down loaded the files to update the map info. in my garmin c330. I think I have the garmin set to host mode. My problem is that when I try to download the update to the garmin I am asked to identify the com port. All the com ports listed give me a message of "com port not found" When I click on the download using the usb port I get a message that says no usb devices found. When I go to "my computer" it shows the garmin on the screen but I still get the update to download from my computer to the garmin c330. I'm stuck, help.
    Problem Solver:
  • 5 Answers
Sounds like a windows XP home problem.
Posted on Aug 09, 2010
Free map updates for Garmin c330
Garmin has released new maps. Most of their units are entitled to a free update if the unit was purchased recently Just a heads up to anyone who recently purchased a C330. According to Garmin's tech support, the map udate 2008 is not free to those of us that recently purchased a C330. Only to those who purchased a C340 and up. Their excuse is that it is a "low end" unit, and also that the memory cannot hold the full US maps on the DVD. Gee, I can purchase the update for $69.99 and load a subset of the maps if I want, according to the person in tech support, but I cannot receive it as a free update. So, apparently buyer beware if you purchase Garmin's "low end" units. You will apparently not be able to receive a free update of maps, even if the unit you buy is already out of date.
Aug 23, 2009 | Garmin StreetPilot C330 GPS Receiver
How do I upload Maps update for Streetpilot c330.
Installation Instructions
  1. Download the self-extracting archive file for your Streetpilot c330 onto your hard drive.
  2. Connect your Streetpilot c330 to a free USB port on your PC with the correct PC interface cable.
  3. Unzip the files in the archive by running the downloaded executable file.
  4. Follow the instructions provided by the launched update application on your computer.
Get the update here:
http://www8.garmin.com/software/StreetPilotc330_610.exe
Mar 19, 2009 | Garmin StreetPilot C330 GPS Receiver
Updating Garmin C330
TO GET 2009 MAP IS NOT EASY! Software update is, from the Garmin site you can update software easily BUT THE MAP... you must purchase for $69.99 OR if you're a technical person who knows the following instructions you can save some $$$
search torrent for
"CNNANT2009-1 MapID 396"
under torrent sites, you know what you're doing.
Use these instructions if you have downloaded it.
Download these first:
cgpsmapper.exe
gmaptool.exe
MapSetToolKit.exe
and MapSource where u can directly get from Garmin site
http://www8.garmin.com/support/download_details.jsp?id=209
Create these folders on the root drive: (I will choose one to make things easier, you can change)
C:/grmtmp
C:/grmtmp/extract
Connect your GPS to USB, and BACKUP then remove
X:/Garmin/gmapprom.img and gmapprom.sum (may be gmapsupp.[img+sum]) approx. 1GB
1) Copy gmapsupp.img from this torrent to C:/grmtmp;
2) Extract gmaptool.exe, cgpsmapper.exe and mapsettoolkit.exe to C:/grmtmp/extract
3) Open a command prompt, and navigate to the extract folder ("cd/grmtmp/extract")
4) Run "gmaptool -S ../gmapsupp.img" Note that is -(CAPITAL S), lower case s is for different option
5) The above will extract files, you will get some warnings about 10 degrees. Ignore them.
6) Run "cgpsmapper mapset00.mp"
7) Run "MapSetToolKit"
8) In MapSetToolKit, press "Install A Existing Mapset"
8a) TDB File: "mapset00.tdb
8b) Overview map: "mapset00.img"
8c) Registry name: "WhateverYouWant" (I did "Grm2009.1Update")
8d) Leave TYP files blank, and hit "Install"
9) Close MapSetToolKit and run MapSource
10) Ignore any requests to unlock map, not ready yet.
11) Go to "Utilities-Get Unit ID" and Find Device with your GPS plugged in USB. Write down Unit ID.
12) Run Garmin Unlock Utility, Enter that Unit ID at the top.
13) Select under "Select Map Product"
14) Ender 396 for the FID/MapID, use the Generate button to get 25char code.
15) In MapSource go to "Utilities-Manage Map Products"
16) Go to "Unlock Regions" Tab, and hit "Add...", enter 25char code, comment optional
17) Now on the main MapSource screen, type 'm' to enable map tool.
18) You should see a large white rectangle, with rectangle outlines (these represent NA maps)
19) Click and drag to select them all, you can click "Map Set Name" if wanted.
20) Click the "Send to Device" button. Wait an hour. Enjoy.
Feb 26, 2009 | Garmin StreetPilot C330 GPS Receiver
Host mode
on the main screen push the wrench>push system>goto gps mode>hit normal> change normal setting to GPS OFF now it will allow you to update. Whew that was a buggar to figure out!!!
Jan 08, 2009 | Garmin StreetPilot C330 GPS Receiver
Cannot upload update
Problem resolved. It seems to have taken several hours for gps to update.
Thanks anyway.
Jul 21, 2008 | Garmin StreetPilot C330 GPS Receiver
I Would like to update my Garminc330. I have a glitch in the map (tells me address doesnot exist, when I know it does)
Hello mjs91411,
The Garmin maps updates page appears to be down at the time this is being posted, but the page to get updates for your GPS is https://my.garmin.com/maps/updates.htm.
You can also sign into the My Garmin page at https://my.garmin.com.
Best regards,
Ken
Go Ahead. Use Us.
May 20, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c330 update
What are you trying to update, firmware or maps? Firmware updates ae free from Garmin. Just go to www.garmin.com and download the WebUpdater. If you are trying to update the maps, these are available for purchase in CD or SD card formats, also from Garmin or your local retailer. They should be approx. $70.
Mar 23, 2008 | Garmin StreetPilot C330 GPS Receiver
Putting maps on sd memory card
(Untried)
For C330 owners that want to have both Canada and US 2008 map update on their GPS this is what you have to do.
Must have:
1 - Street pilot C330
2 - 512mb SD card
3 - SD card reader of some form (some cameras will suffice)
4 - Garmin 2008 Map Update North America
What to DO:
1 - connect the GPS to the computer
2 - Insert the Map update disk
3 - Install the Lower 48 states, United States
(Reason - the C330 has around 1000mb of memory and the "US 48 states" map uses around 900mb" while Canada uses 400mb...which is why you will need that 512mb SD card later)
4 - Once the GPS is updated with the US map. Browse the Map update disk contents. This can be done with going to "My Computer" right click on your CD/DVD drive and click on "Explore"
5 - Open the folder called "img"
6 - Copy the file called "gmappromU.img" file is around 430mb. (This is the map file for Canada)
7 - Insert your SD card into your card reader and connect it to your computer. A window should pop up. If not you should see it on your "My Computer"
8 - Once you have navigated your way into the SD card directory. Create a folder on the SD card named "garmin" (no caps)
9 - Go into your newly created "garmin" folder right click and paste the "gmappromU.img" file. (This may take upto 20 to 30 mins)
10 - Once the process is complete, Rename the "gmappromU.img" file to --> "gmapsupp.img" (watch for spelling, no caps at all)
11 - Remove the SD card, Turn off your GPS, Insert SD card into GPS.
12 - Turn on GPS, let it load, and there you have it, the FULL North America Map.
When you are searching a state or province (depending where you are located) it will give you an option which map to use, Canada/Alaska or the lower 48 US states. Select your map and you are set to Go.
Feb 01, 2008 | Garmin StreetPilot C330 GPS Receiver
POI menu with custom POI does not appear anywhere on the C330?
You need to use Garmin POI loader to input custom POI. After loading POI's they will show up in "My Favorite" under "Custom POI"
Jan 10, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
268 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
