Question about Lincoln Electric Plasma Cutter, Pro - Cut 25
Start cutting and the safety light comes on - Lincoln Electric Plasma Cutter, Pro - Cut 25
    Problem Solver:
  • 17 Answers
Usually it could be one of two things. The first thing to check for is to look at the contact and make sure it is not melted down and ensure its in good shape. The second thing that could do this, would be not enough air pressure. This air pressure is used to blow away the molten metal you are cutting.
Posted on May 31, 2010
2002 660 grizzly red light reverse light comes on then it starts to cut out
sounds like your reverse sensor is bad and the cdi limits rpms while in reverse as a safety thing.
Dec 06, 2016 | Yamaha 2004 Grizzly 660 Auto 4x4
I have a 2001 660 raptor and when I'm driving it the reverse light comes on and it cuts out what it making it do this?
i would think this is a wiring fault , there will be a sensor to indicate forward speed and if the vehicle thinks it's in reverse gear ie the reverse lights coming on then ,there is a safety cut off of the engine,i would start at the light cluster wiring and check for good connections to the chassis as this is the earth return , any bare wire that could touch the body and cause a shorrt, if nothing found remove the bulb's and road test if the same thing happens then i would think the safety switch would need attention,take to a dealer as this may be a known fault , keep me posted if you wish
Sep 29, 2014 | Cars & Trucks
L have got ford telster v6 ,everytime the engine starts to heat theres a hold light reflect on the dashboard and it cut itself everytime l get to th stop sign what may b the cause
it is a safety fixture for people like you, who do not respect gauges, if the lite come on is for a reason, too hot or nor oil pressure, well do that in some engine, obviously you did not respect the signs. that this make sense to you !!
Apr 14, 2014 | Cars & Trucks
Car cuts out when driving
I would suggest stopping by your local advanced auto parts, or mechanic. have them hook up to the OBD2 and run a diagnostic on the vehicle. that will give you a head start on what the problem is.
Feb 02, 2013 | Mercedes-Benz Cars & Trucks
Yamaha Ybr 125 engine cuts out when I put it in gear
Hi, Supersonicjo and the usual suspects are:
1. Faulty wiring to any safety switch.
2. Safety switches loose at the mounting point.
3. Faulty kickstand safety switch.
4. Failed kickstand safety switch circuit diode.
5. Stretched side stand spring.
6. Side stand not coming up far enough to disengage switch.
7. Faulty clutch lever safety switch.
8. Faulty neutral safety switch.
9. Clutch not properly adjusted.
10. Clutch plates sticking, forward lurch
For more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Stalls when put in first gear
https://yamahaclub.com/forums/topic/35411-yamaha-ybr125-fires-up-in-neutral-but-dies-the-second-it-goes-into-gear
Yamaha YBR125ED 2005 Service Manual
OEM parts for Yamaha
YAMAHA YBR125ED Owner Manual
Feb 01, 2013 | Yamaha Ybr 125 Motorcycles
Why does the abc light come and truck cut off
automatic brake control sounds like a safety interlock setup which is designed to shut the truck down when a defect is noted that is serious enough to require attention..look at brake fluid level first, then start checking the other brake components for issues..good luck
Jan 20, 2013 | 1997 Ford F150 Regular Cab
2005 Honda VFR 800 FI Interceptor dies when put in gear
Hi, Anonymous and the usual suspects are:
For more information about your question and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Engine cuts out when put in gear
Bike Cutting Off When Put in Gear
1998 2001 Honda VFR800FI Service Manual VFR800 Moto Data Project
https://www.partsfish.com/page/oem-parts-for-honda
Honda VFR800 Owner Manual
Dec 21, 2012 | 2005 Honda VFR 800 FI Interceptor
When we closed the door to start the dryer, it would not start. The light comes on so we know that there is power. Why would this all of a sudden happened? No signs of any trouble before??
Have you checked for a broken belt? There is a safety switch on the belt tensioning arm which cuts power to the motor if the belt breaks.
Jan 12, 2011 | Dryers
HELP! My SILVIA cuts out the safety switch
maybe element in machine make problem,maybe is gone make problem,check element
Aug 23, 2009 | Rancilio Silvia Espresso Machine
Sony sxrd --cuts off after a few seconds then cut itself back on.
Symptom shows lamp is weak and requires replacement.
Please buy Sony original lamp for TV safety and good picture result.
May 31, 2009 | Sony Televison & Video
Open Questions:
See all Lincoln Electric Plasma Cutter, Pro - Cut 25 Questions
Lincoln Electric Plasma Cutter, Pro - Cut 25 Logo
635 people viewed this question
Top Lincoln Welding Tools Experts
Jim Goldsmith
Jim Goldsmith
Rob Emerson
Rob Emerson
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
