1996 COLORTRAK PLUS, TV, modle # F32672SB, service series CTC 186/7. after the tv is on for few minutes, the power goes out. If you push the on/off button several times, the tv turns back on, but will continue to turn off. Worth fixing?
  • gpac97 Apr 08, 2008
    For 6 mos
    I have a 1996 RCA colottrak plus tv, model #f32672sb. For the past 6 months, several minutes after being turned on, the power will turn off. prior to this event, the picture and sound are fine. If you push the power button on and off several times, the power will come back on, only to once again go off after several minutes. Worth fixing?
  • 3,037 Answers
Brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. If this does not correct the problem, then I would consider maybe getting that new tv. But I can provide further options for you to look into. Let me know what you want to do.
Posted on Apr 08, 2008
  • 2 more comments
  • Benjamin Patri
    Benjamin Patri Apr 08, 2008
    I would bet that your voltage regulator needs to be replaced if anything otherwise
  • Benjamin Patri
    The voltage regulator is in the power section
    (near the power entry of the set) which is mounted against a fairly big heatsink. Check it first and then check all the transistors in the area
    starting with the big ones.
  • Benjamin Patri
    if you are able to fix yourself, it would definitely be worth fixing, or if you have a friend that is good with electronics, just buy get him some drinks and I'm sure it will be an easy fix.
    Please keep me updated and be careful when working on it, make sure you unplug it and be careful about what you touch, mainly the capacitors
  • Benjamin Patri
    Benjamin Patri Apr 17, 2008
    Did the information I provide fix your problem?
    Please let me know how it turned out
    Genius:
  • 3,422 Answers
HI,
The only solution to fix this problem is to get it repaired by a technician.
Few troubleshooting steps you can try:
1)Do a hard reset by unpluging all the cords for 4hrs and then plug it back.
2)The whacking test is to just bang or smack the set with your hand on the back, side, top, etc., to see if there are loose connections or cold solder joints inside that are acting up. If so, the banging should knock them back to normal and the set should restore. You might have to use some creative banging and some have had to put a book or magazine under one corner to torque the chassis enough to get it to work reliably.
Goodluck,
Please don't forget to rate the solution as fixya..
    Genius:
  • 1,142 Answers
Since how long are you facing this issue
  • Anonymous Apr 08, 2008
    Do a flea power unplug the power cable leave it turned off for an hour this will drain the static power and try pushing the power button for 30 seconds without connecting the power then try connecting the power the issue should be resolved.
SOURCE:
Have a GE universal remote model number 24922-CL3 1349 what codes do I need to use so it will work with my RCA ColorTrak Plus 1996 model tv with model number F27638BC
If your GE remote is universal, you should be able to search all of its codes for one that will work with your RCA TV. If you search is unsuccessful, you may have to try another universal remote. Not all remotes contain all codes.
Sep 29, 2014 | Televison & Video
Hulu plus activation
I need to know more information to help for you.
Mar 07, 2018 | iPhone Apps
I have a rca colortrak plus and lost the remote. How can i set it up to work with a converter box? It is displaying in spanish and I can't change back to english
You may be able if can enter the menu to change from Spanish back to English--(very old set) by using vol or channel buttons to navigate--this is not certain but possible--idioma is word to look for--language.
Apr 25, 2012 | Televison & Video
How do i get to the input/video screen on the RCA F32672sb 32
If you have an old vcr hook the dvd player to the inputs on back of the vcr (RCA jacks) Run a coax cable from the "out" on the vcr to the back of tv. Turn the tv on channel 4 or 3 then put a tape in the vcr and push record then pause it. Or if the vcr has a tv/video button you can push or activate it and it should allow the dvd to play through to the tv.
Feb 10, 2009 | RCA F32672SB 32" TV
RCA Colortrak plus. Model# F32672SB Serial # 807560570 Chassis # CTC187CJ3 Manufacture Date Feb 1998 Service # F32672SBFM3 4/21/08- TV worked fine last night. This morning worked for about an hour. ...
It's probably a cracked solder joint in the power supply / horizonal drive stages. As the unit heats up the joint is seperating and breaking connection. It could also be a component failing when it gets hot. Usually the voltage regulator or Horizonal Output Transistor (both mount to heat sinks).
If you know how to solder and want to tinker, unplug the set for a couple days (to let the power capacitors discharge) and resolder and crystalized it cracked joints on the board(s) where the power stages, and flyback transformer are located.
If you decide to operate the set with the back off, please be careful. The high voltage on a TV can be 30,000+ volts.
Hope that helps,
Geno
Apr 21, 2008 | Televison & Video
TV Problem
The first thing is to check to see if the fuse is blown,if so replace with a 5 amp fuse,fuse is located near were the power cord connects to the board,make sure set is disconnected from power.
Feb 28, 2008 | RCA F32672SB 32" TV
Rca colortrak 2000
what is the chassis number of your set should be a ctc or ptk number?Post hat info and I should be able to give some advice on whats happening with your set.
Feb 18, 2008 | Televison & Video
Ctc 195 sereis tv
Try unplugging your set, If you didnt save the changes this should reset it back to default settings. If that desnt work, you will need to go bak into the service manual and adjust the horizontal size. Just write down anything you change so you can revert back if you have too.
Jan 22, 2008 | RCA P56950 56" Rear Projection Television
Occassional bad noise and picture
Bad ground connection in tuner.....good old set to fix and
older folks get attached and comfortable = why rock the boat?
If it lasts a couple more years.............................T.
Nov 28, 2007 | RCA F31672ET TV
RCA Colortrak Plus Model # F27672ET
Your set might have a leaky capacitor that takes a while to fully charge to the supply voltage as well as loose conections to the vertical Ic,sometimes you can identify it because it overheated and the insulation is peeling,sometimes they look normal but they are bad.If you are familiar with tv service you will have a place to check but if you are not too familiar seek the assistance of a servicer.
Sep 30, 2006 | Zenith IQC50H95W 50" Rear Projection...
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
Ekse
