Question about Drive Medical BLUE 3 Wheel Compact Mini Phantom Scooter by S35002692 ()
Batteries won't charge
Phantom scooter 3 wheeler. battery doesn"t seem to charge. Brand new batteries, fuses are good. Charger just flashes red.
  • 177 Answers
Hi. Sounds like there is a faulty connection somewhere between the charger and the batteries. Are the batteries connected correctly. The charger uses the voltage level in the batteries to regulate itself. If there is a faulty connection, then the charge will not operate. Use a multi-meter to check if the batteries are connected correctly. There should be 24 to 26 volts across both batteries.
This fault can also be caused by a faulty charger socket. Check for any signs of melting or heat damage. There might also be a disconnected wire in the plug on the charger itself.Good luck. Neil.
Posted on May 29, 2010
Scooter batteries are completly discharged for a long time. the red light on. while connected to the 220v. All fuses are checked OK. the charger outlet is round 3 poles connector. you said it will not...
Use an automotive NON automatic style to charge the batteries individually. This may tale up to 72 hrs. to get the voltage up tp at least 10 volts. When that happens, the regular battery charger made for the scooter will finish off the charge. If the battery won't take a charge, then they're history.
Feb 09, 2014 | Pride Travel Pro 3-Wheel Mobility Scooter
I have a Pride legend three wheeler- I replace the battery charger because it would not charge the batteries. I pluged the new charger into the control module it will charge the batteries. Batteries are...
if I understanding this correctly , you cannot use the scooter why it is being charged, there is a inhibit pin that stops the scooter from being used,
All scooters are designed this way.
Regards
Dec 14, 2012 | Pride New Mobility Legend 4 Wheel Scooter
No power after replacing the battery
Check hoy Red wire the Red wire is the problem good lake
Nov 26, 2012 | Polaris ATV
Phantom battery won't charge
Hello
Are you sure your battery charger is working correctly. Have you tried it on another battery? Possibly, there is a wiring problem, or your battery is the type that needs distilled water - Try another known good and charged battery with your scooter before purchasing a new one to ensure that the wiring is not faulty.
ilona
Aug 02, 2017 | Drive Medical Mini Phantom Three Wheel...
I cant get my power chair jet 3 to charge batteries are good
Hi valentin 201
I have owned my own business for 3 years and have been working on scooters and powerchairs for 15 years. . In the future give as much info about the scooter as possible.
1. load test the batteries even if you think they are good, check anyway. Sometimes even new batteries won't hold a charge.
2. Your charger on the powerchair must have enough volts to open the charger inhibitor. That is, the charger won't even start up if your batteries are low. Both batteries need to have at least 20-22 vdc.
3. Some chargers have a 3amp fuse check that and repace if needed.
4. With a multi meter set on dc200 check your batteries. Red on one battery and black on the other. Check to see what you get for voltage. If no voltage reverse the lead wire to the other posts. Once you get a reading of 20+ volts watch the meter and plug in the charger, it should increase the volts on the meter. if not the charger is bad, replace. Charger should be 24-31 volts to be a good charger.)
One of these sugestions will fix the problem
Good Luck
Tim
May 03, 2011 | Jet 3 Ultra Power Chair
My father's strider mc dma 3 wheeler is fully charged and was working yesterday. After a night of charging, it now does not display any battery strength or move when levers are pressed. What do I need to...
1. Check all battery connections.
2. Load test the batteries, they may need replacing even if they are new
3. The charger has an inhibitor in it. That means if you don't have enough voltage going through it, it won't even turn on. We think that just because we plug it in it will work, not the case.
4. With a multimeter set on 200dc red lead to red terminal on one battery and black lead on the other. You should get a reading of at least 20 vlts dc. If no reading put the leads on the other terminals. Once you get the reading plug the charger in to see if the reading increases. If it does the charger is good. if not replace the charger. You will have to charge the batteries on a car charger to get them to 12 volts each.
5. If none of those work check the continuity of the front to rear harness. replace if you have a dead wire.
6.Lastly and most costly. your controller may be bad.
Good Luck
MIMOBILITY
May 02, 2011 | Health & Beauty
Hi there...I had not used my Hoveround MPV4 scooter for over a year and when I finally went to use it, the batteries were no good any longer as they would not hold a charge...so I just bought two brand new...
Hi Pam,
The new batteries should work right away. (Your old ones had gone solid from sitting for so long- charge the new ones at least once a week to keep that from happening, even if you are not using your power chair.)
You may want to check all of the connections to make sure they are tight especially on the battery posts, also make sure the fuses are not burned out. It's recommended to run the new batteries into the red (fully discharge) then let them charge for 8-12 hours to make sure the batteries get a full charge the first time out, but if you haven't done that, it should not cause any flashing lights.
You said that green lights were flashing (assuming on the controller); if all 10 bars (3 red, 4 yellow, 3 green) are flashing that indicates a poor battery connection. 9 bars means you need to do a brake reset. Check page 51 of your manual for controller light codes or check this link: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
If you have any other concerns, let me know. Good luck!
Oct 12, 2010 | Health & Beauty
CRT Scooter just quit working and doesn't accept battery charge.
Hi. There is often an in-line fuse for the voltage to run the controller. Often the charger feed goes through this fuse. Check the fuses. Sometimes the fuse is OK, but the contacts in the fuse holder are faulty. Also check the battery connectors, and where the battery leads are fixed to the batteries.
I have removed many connectors from battery leads and connected the leads to the batteries without in-line connectors.
Good luck. Neil.
Jun 01, 2010 | Drive Medical BLUE 3 Wheel Compact Mini...
Drive Medical BLUE 3 Wheel Compact Mini Phantom Scooter by   S35002692 () Logo
170 people viewed this question
Top Drive Medical Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you a Drive Medical Health and Beauty Expert? Answer questions, earn points and help others
