Question about GE 30 in. JGP336 Gas Cooktop
Some cleaning solution got in the knob hole and the igniter started ticking and cause a fire. It was put out right away and unpluged. It this fixable, or should I replace the cooktop?
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on Aug 18, 2010
My cooktop has electric ignition that "clicks"
Take a q-tip and clean under where it clicks. Might have food or grease covering release hole.
Dec 06, 2017 | GE 36 in. JGP628 Gas Cooktop
We have a belling gas hob. Intially when we turn on the control knob it gave a ticking sound even after it got ignited. then when we were turning on one burner it gave ticking sound in all burners . but...
take out the control knobs. clean the grease and food partilcles if any using hot water and dish washing liquid .if the washer under the knob is stuck, put it properly and put the control knobs back into it carefully
Jan 11, 2010 | Stainless Cooktops
Stove top ignition doesn't stop ticking
My Dacor cooktop had a similar problem of continuously clicking igniters. I unplugged it a couple months ago and used a piezoelectric igniter to get it started. Then I looked in the Dacor FAQ and it said to clean the ceramic igniter posts with alcohol not water. I had to scrape some gunk off a couple of the posts with a knife before cleaning with alcohol. Now it works.'
I think the igniters use electrical conductivity to detect when they need to spark, so even slight invisible contamination on the igniter insulator can confuse the sensing system. Also they all seem to fire as a group, so all of them need to be clean because if any one of them is dirty then they will all malfunction.
Mar 22, 2009 | Creda Colonial 42352 23 in. Electric...
Ticking sound of gas igniter continues after off.
try to clean the place wen u remove the control knob,by using a vacium.
Nov 19, 2008 | Cooktops
Clicks occur in "low" position instead of "lite" position
Sounds like the switch electric sending unit needs to be Ither cleaned and dry good or replced. It's not hard at all, They are located under the knob switches, you will have to remove the knobs and the top cover, they look like a small square box wit a hole in the middle with two wires on the sides, just unplug the wires and lift the box off the switch rod. cleane them and dry them good and put them back.......that should do it.....Good Luck
Eddie Rentas
Tupper LAke NY
Jul 16, 2008 | Cooktops
MAYTAG GAS STOVE
One or more of the control switches has shorted out. This usually happens when you wash the knobs. Water stays in the holes and runs down the shaft when you put them back on. Maytag /Jenn air have had recalls on some models for this problem as it can start a fire under some conditions. UNPLUG THE COOKTOP UNTIL THIS IS FIXED!!! You can still light it with a match. Check Maytags Web site for information on this . Some switches can be seperated from the gas valve and replaced sererately. This may be worth fixing. Remove the wires from all switches and re connect them one at a time until you find out which switch/s are bad. If this was left clicking for too long you might have burned out the spark module. If the switches are part of the gas valve, and more than one is bad it may not make sense to fix the cooktop. Remember you can always just disconnect the switch that is bad , use the rest and light the broken burner with a long reach lighter.
Jul 07, 2008 | Cooktops
Ticking sound does not go off even after knob is turned to high or medium
A lot of questions on this site but very few answers. I have the same problem. After an overflow from a pot, the 2 front burners now won't light one rear one lights but won't stop sparking and the littlest one is fine.
Mar 30, 2008 | GE 30 in. Profile JGP933SEFSS Gas Cooktop
Spark continuously on
If you have recently cleaned it, you may have gotten moisture behind the knobs and into the spark switches. Be very careful not to let moisture get behind knobs. Very dangerous. If this is the case, they may dry out themselves and stop sparking. If not you may need to replace a spark switch behind knob.
Nov 20, 2007 | GE 30 in. JGP336 Gas Cooktop
Ticking Sound of spark igniter persists
Our GE cook-top burner igniter has started ticking even when the oven is shut off. Even after cleaning the bottom of controls the ticking persists. Any suggestions? Thanks
Aug 27, 2007 | GE 36 in. JGP628 Gas Cooktop
Electronic ignition
Alien, one of your burner switches either got wet or shorted out. These switches are located on the burner valve itself. Sometimes you can take a hair dryer, pull the knobs of the control valve and dry out the switch. If this doesn't work, more than likley one of the switches gone bad. Catriver...post back.
Sep 23, 2006 | Jenn-Air JGC9430 Gas Cooktop
GE 30 in. JGP336 Gas Cooktop Logo
157 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
