Question about Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum
Light on moterhead
The normal green light on the moterhead goes red and we appear to lose suction within the moter head
  • jimntrish May 12, 2008
    Our Dyson has just done the same thing. serviced with new motorhead not even 12 months ago now. Nothing stuck in the motorhead such as hair or anything. Undid the floortool cover so check where the brushes sit. Brushes rotate freely when not in use. slight black discolouration around air vent to motor. Suspect either burnt out motorhead (although when only picking up dust, would not be due to overuse!!!) no smell from motorhead, just does not run and light is green. possible fuse blown with machine???? Please advise. Tx.
  • nickyshouse Jan 17, 2009
    I have the same thing i think! red light has replaced the green one... the brush head does not spin and it will not pick up. The vacuum does have the same suction when using the hose so i don't want to go and buy a new cleaner if this is simple to repair... Help my floors need de fluffing!
Update.... I just rand Dyson help line and the only thing they suggest is to purchase a new head - if all possible causes have been eliminated ie. clearing roller of fluff etc. They are £40.00 direct from Dyson. Just ordered mine!
Posted on Jan 17, 2009
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=34218&thid=498154
Light on moterhead
Posted by Arnold2 on Apr 08, 2008
The normal green light on the moterhead goes red and we appear to lose suction within the motor head
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I checked with some of my contacts in the vacuum business and they told me that it may not be a United States vacuum and it might be a Canadian or European vacuum and may not be customer friendly to service, if you have a contact with a MAC or Snap On dealer or a metric auto store – as far as the green light on the powerhead the green light is supposed to let you know if the carpet is clean and the red light is supposed to be that the carpet is dirty, and laos it could be that your belt is loose and needs changing – a suggested belt change is every 4 to 6 months --- show them the screw and they might have something to fit or release the screw head, as per the removing of the wheel and replacing the electric cable, check with your local vac dealer or you may want to check with the Dyson dealer website and or phone # listed below:
http://www.dyson.com/homepage.asp
Contact Us
1-866-MY-DYSON
(1-866-693-9766)
Dyson Customer Care is available 7 days a week.
· Mon - Fri: 7am - 8pm, CST
· Saturday: 8am - 6pm, CST
· Sunday: 9am - 6pm, CST
questions@dyson.com
Don – The Vac Man
Go Ahead. Use Us.
Posted on May 02, 2008
How to trouble shoot a brush warning light
What color light are you referring to? If it is one of the green lights that is normal for the up and down adjustments. If it is the red one that is another issue. If it is the red one, what does it do while it is on? Does it flash or is it on solid?
Jun 17, 2014 | Windsor SR12 Sensor Bagged Upright Vacuum
Poor wand suction
your cyclone assembly may need to be striped down and cleaned also remove the exhurst filter located under the bin.
Oct 15, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
My Kenmore bagless intelliclean vacuum is making a loud noise mainly when it is vacuuming on the highest setting (when the light is red). We have taken it apart and cannot find a clog. It has also lost...
This might help, it was posted on a previous problem but is the same issue you are having it seems: "Here is a possible solution. If the vacuum sounds normal when the green light comes on, then the issue is a suction bypass. Kenmore built a suction bypass in to help cool down and protect the motor should someone either never clean the filter, empty the canister or somehow manage to clog the hose. There is a spring holding the bypass closed and is overridden by vacuum suction. I guess the spring becomes weak, allowing high suction to pull it open which in turn reduces suction so it closes again. It can do this several times per second making a loud racket and slightly affecting performance until the sensor goes green, then the vacuum suction is too low to overcome the spring tension thus why it sounds fine then. The trick? The very hard way (what I did) was to open the vacuum, open the casing where the spring is and pull it apart slightly to increase the spring tension. The easy way is to put tape over the hole where the bypass is. The inlet is under the hose track on the back on the right side as you're looking at it. The hole is about the size of a quarter and you'll see fins across the hole. The tape would keep the suction. The motor would still pull back the bypass but since tape is applied, there would be nothing to reduce the suction thus keeping performance and reducing the noise. However, this circumvents the intended design so you do so only at your own risk."
Dec 27, 2010 | Kenmore Progressive Bagless Upright with...
I have unscrewed all the screws and can't get bottom off.
Mar 10, 2010 | Kenmore Progressive Bagless Upright with...
No suction
Check the tube that leads down to the brush head for clogging as well as any motor or HEPA filters. If that still shows nothing, take the cover off the brush head (like you're changing the belt) and look for obstructions in there. Usually, if you have low suction on the accessory hose, the problem is with a motor filter, HEPA filter, or a clog where the hose goes into the unit. If you have good suction on the accessory hose but none on the floor, it's usually in the brush head (clog or broken belt) Good luck
Feb 28, 2010 | Euro-Pro EP602 Bagless Stick Cyclonic...
Wiring schmatic for kenmore canistar vacuum
Generally, there are two wires inside the unit which connect to the wiring going down the suction hose.  Since the unit is a/c...it doesn't matter which of them goes to which terminal.  The wires are switched in some cases.  Look for the open terminal.
Dec 19, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Suction loss when handle is tipped back to clean carpet
can any one help,
Our Dyson Animal vacuum has plenty of suction when it is upright and the attachments are being used off the hose, but when the handle is tipped back to begin cleaning carpets the beater head is getting no suction. As the handle is being tipped back you can hear what sounds like a flapper valve in the body of the vacuum opening and then all the suction just goes away.
Nov 19, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Samsung Quiet Storm 9048R hose break
OK ART THE FITTING THAT CONNECTS TO THE HOSE SHOULD HAVE TWO SMALL SQUARE HOLES OPPOSITE EACH OTHER YOU NEED TO PUSH TWO FLAT HEAD SCREW DRIVERS IN AT SAME TIME TO RELEASE THE SECTION THAT THE HOSE SCREWS INTO POP THIS APART THEN REMOVE THE SMALL PIECE OF BROKEN HOSE AND SCEW HOSE BACK ON REPLACE INTO FITTING SO THE SQUARES POP BACK INTO PLACE AND START VACUUMING HOPE THIS HELPS GLENN PS ANY VACUUM SPECIALIST WOULD BE ABLE TO HELP WITH THIS SMALL PROBLEM IF YOU WANT TO MEET ONLINE ABOUT THIS I WOULD BE MORE THAN HAPPY TO ASSIST
Nov 14, 2008 | Samsung 5528R Vacuum
Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum Logo
282 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Roger Potts
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
