Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
I have a Robinair 34700, after the function recover when discharges of oil rises and the cooling gas so that the exhaust pipe freezes.
  • Hasan Khan Amran
    Hasan Khan Amran May 29, 2010
    I do not understant what do you want so say!
    President:
  • 180 Answers
Dont worry this is normal function.
Posted on Jun 16, 2010
I have a 34134z that will not recover or charge
You may need to replace compressor. Open compressor test port (located on one of the pipe line which come to compressor from top of spin-on filter) and fixe a vacuum gauge on it. press recover from menu and check compressor suction for 13''Hg. If compressor has no suction then its need replace.
NOTE : if you do not have a vacuum gauge then after opening cap from test port, press recover from menu and then gently press small valve on test port with a small L-key to feel suction of compressor. if the compressor discharging air instead of suction, replace compressor.
Jun 11, 2014 | Robinair Cool Tech 34700Z Recovery,...
Robinair
The amount of oil moving with the gas is minimal as it is only what passes the pistons as lubricant that travels with the gas. The receiver dryer catches most of the oil that is moving. New compressors have the correct amount of oil so if you have the need to add oil check what is in the dryer and that will all that you need to add. If the system has excessive oil in it you will experience problems in the tx valve as the oil blocks up the opening.
May 17, 2013 | Robinair 34288 Cool-Tech R-134A Recovery...
Robinair 34700 hi-p
Disconnected Air Purge lines. It was under high pressure (careful).
Feb 29, 2012 | Robinair Cool Tech 34700Z Recovery,...
34700 unit when in the vacuum mode it sends R134 into the oil recovery bottle tank
Please check oil drain sensor(switch) or oil drain solenoid for any debris. If both are check OK, then check Vacuum,Recycle and charge solenoid for any debris or damage. Replace/rebuild as needed. Hope this will help you
Nov 03, 2010 | Robinair Cool Tech 34700Z Recovery,...
I have a robinair 34788 machine and when I am recovering a system for service the recover feature no longer completes down to the oil drain. Its like it gets stuck on recover.... and by that I mean it...
It's sound like problem with oil drain solenoid or harness. please check harness of oil drain solenoid. If harness is ok & connected with relay board then you need to replace oil drain solenoid.
Oct 11, 2010 | Robinair Cool Tech 34700Z Recovery,...
Robinair 34700 recovery problem
It sound like one of the pressure trunsducer is not working or disconnected from the manifold assy.or from ISV tank.Please check Low,High and ISV tank pressure transducer
Jul 08, 2010 | Robinair Cool Tech 34700Z Recovery,...
I have a Robinair 34700, during vacuuming and recycling I lose about 200 g refrigerant gas.
Don't worry this is normal.Because while machine is running for vacuum or recycle mode,automatic air purge device will active for some time & it will purge air from ISV.
May 28, 2010 | Robinair Cool Tech 34700Z Recovery,...
Model Robinair 34700 Series 21699 Date 09/97 very slow when recharging system? Same problem on any vehicle. Tried closing off high side and running the vehicle ac n/g Any Help Thanks Tony
Please do the following 1# Check your machine ISV tank liquid line quick connector.it's seems to be very tight,open little & try to charging.2# Rebuild charging solenoid.
Jun 23, 2009 | Robinair Cool Tech 34700Z Recovery,...
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
256 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
